Page 25 of 32 FirstFirst ... 151617181920212223242526272829303132 LastLast
Results 601 to 625 of 799
Thread: 2018 what did you do to your e38 today?
  1. #601
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    ^Jamos,
    the C Pilars on my DINAN are trash. I got replacements at the local JY. However, the replacements are the usual fleet material, and the DINAN is a more modern material, like a fine checkered gray cloth. If I peeled off the felt, would I be able to peel off the newer material and re glue to the good Pilar’s without damaging or stretching the fabric? Have never done this type of work.
  2. #602
    Dec 2011
    Lancaster CA
    On DINAN
    1. New chain tensioner, no more rattle at start up
    2. Replaced rear tires with 275/40/18. The PO had the usual staggered MPars but he had all tires in 235/50 size, must have got a good deal. Looks better now and seems to ride smoother.
    On iL
    Removed the Alpina lip to install on the DINAN, the iL may be destined for a part out
  3. #603
    Jun 2013
    Toronto, Ontario
    '95 740i
    Kouks, yeah for sure! The c pillars are pretty easy, the only tricky spot is the top corner than faces the front of the car - just peel off the old material, use a nylon bristle brush to remove the old glue (I used a drill brush) and reveal the black underlayment. Basically just cut a square big enough to cover the c pillar, apply some fabric glue (I use permatex heavy duty, it's by far the best I've used) let it soak in for 10-20 seconds, then spray another coat on top of that from about 15-20" away and it really covers nicely, then lay the cloth over top from bottom to top or whatever way you're comfortable with, then start trimming it away. There are 101 ways to do this, but that's the way I've found that produces quality parts every single time. If you try to cut it to shape first, and mess up on applying it, the whole piece is ruined.
    Again, the black underlayment will show exactly how to cut your material once it's on there (wrap the top over, bring the front face over the top and down) - very VERY straight forward once it's in your hand.
    Scatter brained and I don't want to even dare read what I've just wrote hahah
    || 1995 740i || M60B40 || DUDMD || ̶o̶r̶i̶e̶n̶t̶ ̶b̶l̶u̶e̶ Mercedes Brilliant Blue Metallic || Style 168 Wheels 1" Spacers ||
  4. #604
    Jul 2017
    New Jersey
    1998 740 il
    New fog lights in
    Sent from my SM-G960U1 using Tapatalk
  5. #605
    Oct 2017
    Auckland, New Zealand
    2001 E38 740i, 99 750i
    Finished all the front suspension swap out and removed the boot hydraulic pump, changed and topped up the fluid, back to 100%. Boot actually opens and closes!
    Need a wheel alignment now
    1999 750i Individual
    2012 F10 M5
    2014 i3
  6. #606
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    Jamos did you dye the door card to the caramel color? Looks good regardless!!!
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
  7. #607
    Jun 2013
    Toronto, Ontario
    '95 740i
    Yup I did! One of these days I'm going to update my build thread with all sorts of progress! In short, I cleaned them up, and dyed them with dye from http://leathertouchupdye.com they're incredible guys! (redid my seats, console, everything)
  8. #608
    Jan 2017
    North Carolina coast
    2001 740iL Prod 4/2000
    Serviced the ac this morning. It was taking 4-5 miles at 65 to cool down, and at idle the aux fan would cut in/out and the output was noticeably warmer.
    Recovered just short of 16 ounces of refrigerant. Pulled a hour long vacuum to 400 microns, charged 24 ounces of R134A and an oil charge (which has
    2 ounces of R134A as a carrier). Running in 'max' at idle doors open, the system settled to 45 psi on the low side, 245 psi on the high. Aux fan was varying
    between full blast and somewhere in the midrange. Used the garden hose on 'jet', rinsed the condenser off as well as could be done without disassembling the
    bumper and aux fan. Full cleaning of the condenser and radiator saved for a later date.
    Road test achieved 42 degree air exiting the center vents with ambient temps at 88, high humidity.
    On return and idling, the compressor was much quieter, no droning whine. The sled is happy.
  9. #609
    Dec 2011
    Lancaster CA
    ^I have a droning whine when the AC is on, I'll need to recharge and do the oil thing too.
    Aquilla told me that Arm and Hammer toothpaste works wonders at cleaning old plastic light covers. So today I tried it on my yellowing rear clears on the DINAN, and sure enough, all the yellow is gone. Then I used Meguire's Plastix Polish and got a nice clear lights.
    Also tried it on my son's e39 front plastic headlight covers and worked pretty well there too.
  10. #610
    IL
    2000 740i sport
    Really cheap turtle wax rubbing compound and a little elbow grease works wonders as well...
    Quote Originally Posted by kouks View Post
    Sent from my SM-N910T3 using Tapatalk
  11. #611
    Nov 2016
    Hansville, wa
    2001 750il Chrome line
    Well I guess the cooling system would get me sooner or later. I was on the track and the upper hose blew off the water pump. The worst part was driving back to the pit knowing that there might be no water left. After I got parked I saw what had happened and was sure the water was pumped out in about three seconds. I track buddy gave me a ride to the autoparts store and I picked up some coolant and hose clamps. I put the bandage on and used Timm's method for filling and to my surprise the car started and ran just fine. It did have several hours to cool down and I started it a few times to make sure the pistons did not burn into the cylinders.
    Back at home I got new upper and lower hoses and because my water pump sounded like a bucket of bolts that got replaced as well. So here comes my BMW complaint. So you have one hose, It has a fixed clamp on each end, a plastic fitting and an O'Ring. That's seven possible failure points. A normal car has a hose and two clamps. That makes three, WTF? I looked at a Zionville and they have the same lame connections.
    Okay I'm done. It is still a great car to drive. At least it was a simple mechanical fix instead of all the mystery software and sensor crap.
    01' 750il Chromeline
    95 M3 LS swapped
    07 M5 Manual
    06' M5, Spartan wheels and a 507hp V10
    00' 740il Dinan, CAI, Romulus exhaust, Stage 5 engine and transmission tune, 750 brakes, camber plates, strut tower brace. Sold
    00' 323i wagon for daughter
    03' 525i wagon for the wife, sold
    98' 740i for the daughter, wrecked
    92' 525i with over 200k, wrecked
    02' R1200 CLC, hit by a bus and broken in half. That one made the news!
    It's like herpes there is no cure but if treated properly you can live with it for the rest of your life
  12. #612
    Carmel in.
    95 740i, 92 ACSchnitzer
    Got my H&R springs this week, now waiting on all my shocks etc to arrive. Detailed the heck out of it this week for an upcoming big car gathering on the 25th. One day at a time.
    Lets get the party started before it's my bedtime.
  13. #613
    Dec 2009
    Dallas,TX
    '98 E38 740IL, '01 740i
    Got into trouble... Again lol
    Ran both of my battery cables until I hit a snag with the secondary.
    Sent from my SM-N950U using Tapatalk
    TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, M-pars, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, 2.50" X-Pipe, Shadowline, E53 4.6is Cluster, Lacewood interior, Chromeline, 3.15, Bilstein B6+H&R Stage II's. - SOLD 06/21
    BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
    WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, 3.15 LSD Rear diff.
  14. #614
    Aug 2013
    Finland
    1999 540i M-sport
    Quote Originally Posted by purplecty View Post
    I do with professional kit, always great result.
    For example my Audi.
    And the round lenses on e38
    Lähetetty minun ONEPLUS A5010 laitteesta Tapatalkilla
    -E34 M60B40 + Tremec TKO 600 (sold)
    and sadly no old BMW anymore, only high powered Seat Leon Cupra 4Drive as a daily driver.
  15. #615
    Mar 2018
    Louisville, NE, USA
    1998 BMW 740iL (5/97)
    Still trying to find money in the meager budget to get the trans fixed...
  16. #616
    Dec 2011
    Lancaster CA
    DINAN 7: Replaced spark plugs, and found three of the plug shafts with plenty of oil, so VCGs are next. Gives me a chance to repaint the VCs.
    iL: Collected more dirt sitting in the driveway.
  17. #617
    Jun 2013
    Toronto, Ontario
    '95 740i
    Poor iL! I love your attitude, "Leaky Valve covers, awesome!!" Hahah
  18. #618
    Aug 2013
    Finland
    1999 540i M-sport
    Went for a little drive, washed it up and checked engine bay for leaks and etc, topped a little p.s oil
    Have to take off my flexible lip and put it back, as it is rubbing always on every bump, it moves and shows those ugly brown lines.
  19. #619
    Oct 2017
    Cocoa Beach Florida
    2001 BMW 740i
    Willing to Learn
    ^Jamos,
    I'm quickly becoming a BMW fanatic, have a 2001 740i with almost 200,000 miles. I've been doing a lot of work on it lately, timing chain guides, PS hoses, engine mounts, complete front end replacement, a/c and p/s pulleys, misc. Anyway, looked up "Pilars" and JY finally kicked in. Nice car. Just saw the 675 H.P. Dinan M5. What makes your car a Dinan? (Upgrades?) Forgot to mention the plugs and VCG and powder blasted and painted the covers.
  20. #620
    Oct 2017
    Cocoa Beach Florida
    2001 BMW 740i
    AC Whine
    ^Jamos,
    Kouks: Have the same whine on my AC; have you learned what it is yet? I have the perfect chance to replace the belt pulley wheel if it's that, has a little noise/chafing while turning it.
    Quote Originally Posted by nike32 View Post
    Sweet ride. My "rich" Uncle used to say, "wonder what the poor people are doing today", as he cleaned his very large yacht; always wondered why he didn't have someone other than his niece doing it with him?
  21. #621
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Well, the engine still ticks. Pretty noisy outside. Quiet inside. Drove 425 miles flawlessly. Comfortable as hell. Tires had been slightly scallopped on the outside edge but after some new guide links and four wheel alignment they seem to have flattened out. Doesn’t really matter because by the end of this summer they’ll be toast anyway.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
  22. #622
    Aug 2013
    Finland
    1999 540i M-sport
    Did a machined polish, for the first time.
    To remove swirl marks.
    Photo quality are bad, as hard to get what I was trying to photo.
    On first photo, there is swirls, and on the second one, they are almost all gone.
  23. #623
    Dec 2011
    Lancaster CA
    Quote Originally Posted by Jerry Scholder View Post
    Yes, DINAN is a company that re-chips and ads mods to the drivetrain for increased power. Mine does not have 675hp for sure, but just by feel, I’m guessing mine is upgraded from the 289hp engine to about a 340hp engine, plus the trans shifts are adjusted to make the car feel more zippy. The car drives like a normal 740i or iL when I want to drive normal, however, when I mash it down it comes to life and even surprises me with acceleration. The mods are on top of a Sport drivetrain on this 740i. They include a Cold Air Intake, an intake manifold from an M60 engine, which is the predecessor to the M62 in most e38s and has larger air chambers, an engine and trans re-chip, and a modified exhaust. Basically, the mods are made to increase mass flow through the engine, thus more power.
    https://www.dinancars.com/
    If the whine only exists when the AC is on, then it’s most likely the compressor. I’ve been told to ad oil to the AC fluid and it will go away. That’s a job for professionals.
    If it whines all all the time, then you probably have a pulley problem.
  24. #624
    Aug 2013
    Finland
    1999 540i M-sport
    Can't stop looking at my paint after I did fast polish with swirl removal abrasive.
  25. #625
    Oulu, Finland
    See my sig
    Ordered new springs for the seven... Current drop is too much for the roads that we are driving. So 45/35 drop changes to 30/20.
    Getting old, eh?
    Current rides: E65 730dA '04, F10 520dA '11, E34 520iA '91
    Old rides: E46 316Ti, E53 X5, E38 728iA, E39 528iA, E46 318i Touring, E38 730dA, E36 316i, E36 328iA Cabrio, E38 728i, E38 750i, E36/3 320i, E36 318i, E39 530dA Touring, E38 740i, E39 528iA, E34 525iA, E32 750iL, E32 730iL, E34/2 525TDS,
    E34 525i, E28 518i, E34 535i, E34/2 525iA, E30/5 325i, E34 535i, E28 520i https://www.instagram.com/zener__/
  1. 2017 what did you do to your e38 today?
    By Jamos in forum 1995 - 2001 (E38)
    Last Post: 01-03-2018, 12:14 AM
  2. 2016 what did you do to your e38 today?
    By 1badturboe38 in forum 1995 - 2001 (E38)
    Last Post: 01-01-2017, 07:03 PM
  3. 2015 What did you do to your E38 today?
    By Mayorchuck in forum 1995 - 2001 (E38)
    Last Post: 01-06-2016, 03:36 PM
  4. 2014 What did you do to your E38 today?
    Last Post: 01-01-2015, 03:13 PM
  5. What did you do to your E38 today???
    By kooljess in forum 1995 - 2001 (E38)
    Last Post: 01-30-2014, 12:28 AM
