Most of times If the car is heating only on one side then the auxilary water pump is broken or damaged, etc.
But first try to disconnect the harness of the heater valves, typical they should go into the Open position and provide the car with the engine heat, If that works then you know the issue and its quite easy to replace ( atleast on a 725 ).
Theres also a Chance of air being trapped in the heater core or generally in the cooling system. If the car's warm, put the heat all the way up to 32°C(89.6? °F) and Put the Fan Speed to the lowest setting, then rev up the car to 3k rpms 2 - 3 times, then increase the Fan speed and hold the rpms as high as you would normally when you cruise on the freeway. This way helped me getting the air out of the heating system.
Incase nothing works and everything stays the Same, then unfortunately you have to replace the heater valves or try fix them, Theres a repair kit for the valves or you can also replace the auxilary pump itself with a surely working one. Incase you decide to buy the heater valves, i bought them for 25€ including shipping If that helps in any way. Good luck!!
I just installed yesterday a set of Meyle HD front arms (uppers and lowers) along with sway bar links. Bought the sway bar bushings too but they looked ok and I was really tired (had to do a pick-a-part run to get the bolt that I bent!) No more clunking when braking or driving over a sharp bump and no more shimmy around 60. There is still a slight vibration which can only come from tie rods or idler arm so that will be taken car of later (probably spring). I was going to do a transmission service but when I got under the car realized that I got a kit for a 4HP30 and I have a 4HP24 so that's on hold BUT did noticed a cracked guibo and squished transmission mounts so that's also getting on the to-do list.
Jimmy Moreno
BMW CCA 115551
1986 535i, Arctic Blue
2012 X5 XDrive 501, Sparkling Bronze Metallic
drove it today had to charge the battery since the car was dead.. Damn winter
El Cid 1999 ILDUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
Thanks, so I removed the harness to the heater valves and it seems I have no change in symptoms. This indicates the driver side valve is not functioning as it should now be in the open position?
Does this look like the kit you used : Heater Valve Repair Kit Compatible with BMW Cars - Set of Heater Repair Parts - No Need to Buy a New Valve, Suitable for Self-Repair E39, E38, E53, E34, E32, E31, E65, E66, E60, E61 https://www.amazon.com/dp/B077PYJLF7..._8H8iCbK3A9NNK
finally got my 16:9 bezel in and then promptly forgot that I dont have my car today
TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, M-pars, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, 2.50" X-Pipe, Shadowline, E53 4.6is Cluster, Lacewood interior, Chromeline, 3.15, Bilstein B6+H&R Stage II's. - SOLD 06/21
BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, 3.15 LSD Rear diff.
Who’s this - you on here? Homewood Lake Tahoe, California. Came up here to go skiing and I see my car’s twin in the driveway next door. Quite a coincidence.
Yes, there's a high chance of the heater valves being faulty. What about the passenger side? Does it heat while the harness is removed?
Yes that's the repair kit, but maybe try finding a new used heater valve that works since that may come cheaper than the repair kit itself. And there are risks if you decide to repair your old heater valves. Just like Myro said, mind the screws, they tend to brake off, and the plastic brackets.
Might have bested the SAS... time will tell.
Did a few punch list items: washer pump and level sensor, reaimed nozzles, cabin air filters, license plate light. Red triangles are gone... sort of miss them... but I am sure they will be back.
2001 750iL DD74441
Stock
RIP: 2003 540iA Sport GS56111
H&R front springs, Ultimate Cup Holder, Euro Dash & Armrest, Grom, BavSound Stage1
Worked some more on correcting the paint... Oh, and removed the "740iL" badge.
Current: 2007 Z4 M Coupe (blue/black)
Previous: 2001 740iL Sport (black/black), 2000 528i Sport (black/tan), 1995 318is (black/black), 1991 318is (white/black)
Last two weeks I’ve done:
Front struts
Sway bar links
Oil pan gasket
Motor mounts
Today I tackled the much needed paint correction and sealed with Sonax spray and seal which is everything everyone says it is. I got it on promotion through a detailing buddy and I promise it’s the easiest way to get a glossy finish and giving good amount of protection
Unsure. My dad might be taking it. I can tell that my 6k price was low for what’s going on in south Florida. My cars twin, 130k miles no TCG work, sold in two days $6500. Don’t even know a good price point for mine. Car is almost to the point of needing nothing. Also put in a new expansion tank. Still have a minor oil leak I’m trying to chase down but it’s very small amount
Right before Christmas one cold (for CA) morning I started the car and the secondary air pump started screaming bloody murder. Drove it that way for a couple weeks since I was busy with family stuff over the holidays. Today went to local JY and there sitting without a front bumper was a 01 740iL I knew well (took some part for the M62TU for my sons e39) and the SAP was ready to go, a couple 10mm bolts and $20 later I was in business.
When I removed the bumper I realized all the DINAN hardware for the SAP was still installed, so got my CAI I bought from AquillaBMW and installed everything. Runs just fine. Does it have more power? Not that I could tell just running around the neighborhood. I'm of the opinion, like others, that a CAI does little to increase power, the software is where the money is at. But it looks cool.
Also, I had the parts in the garage so...
New sway bar links, New sway bar bushings, New wishbone struts. Along with the new traction struts and new complete steering links/pitman arm/idler arm etc, I did before Christmas, the front suspension is complete. Tomorrow it gets an alignment.
Got 2 new key fobs from the dealership at $300 a piece. It is worth is though to remotely lock the doors.
Gorilla Monsoons
Sent from my SM-N960U using Tapatalk
Nice Purp... you're gonna like that sound. One of the first mods to the sled, after a MkIV.
where do we start... bought the car a few months ago and have gone through it to fix everything I could find wrong (and preventative) so I could enjoy it and have it be as reliable as possible:
- all 4 struts and mounts
- complete suspension rehab front and rear (all control arms, thrust arm, carrier ball joint, tie rods, steering pitman arm, etc etc)
- monsoon speaker upgrade
- Valve cover gaskets
- Timing cover gasket
- Vanos Gaskets
- intake manifold gasket
- valley pan gasket
- Front Crank Seal
- Timing Chains, Guides, & Tensioners
- Water Pump & Thermostat
- Fan Shroud, Fan Clutch and Fan
- New Spark Plugs, and oil change
- new all 4 tires
- paint correction and ceramic sealant
- 4 wheel alignment
- GROM audio DSP adapter with Aux input
- Fixed glove box latch
as expensive as this car has been, I must say, it is an absolute pleasure to drive. On the highway it's like riding on clouds!
drove it today
2019 thread now available. Thread closed.
