Page 5 of 5 FirstFirst 12345
Results 101 to 117 of 117
Thread: 2018 what did you do to your e38 today?
  1. #101
    Finland
    See my sig
    Oil filter housing gasket, new oil+filter, fuel filter, oil pressure sensor replaced.
    All messy.
    And washed the car.
    Current rides: E38 730dA, E39 528iA
    Old rides: E36 316i, E36 328iA Cabrio, E38 728i, E38 750i, E36/3 320i, E36 318i, E39 530dA Touring, E38 740i, E39 528iA, E34 525iA, E32 750iL, E32 730iL, E34/2 525TDS,
    E34 525i, E28 518i, E34 535i, E34/2 525iA, E30/5 325i, E34 535i, E28 520i
  2. #102
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 Ava
    Franko - how do you charge the battery on the new keys now?
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
  3. #103
    Chicago, IL
    98 740IL & 00 740i sport
    Quote Originally Posted by TxDarth View Post
    They do not need to charge because they are easily replaced un like the original Dymond keys that can't even be opened without cutting them open which is why they are rechargeable in the ignition
    Sent from my SM-N910T3 using Tapatalk
    155,000 Miles
  4. #104
    May 2015
    Australia
    4/'98 E38 735iL
    Hi guys,
    I ordered my BC extreme lows last week, fingers crossed they arrive this week. One question about the SLS delete...
    Why doesn't anyone just loop the m10x1 line connectors [the yellow paint marked connectors in the pic]? Unscrew, bend and screw them into each other. Clean and tidy, with all the parts already fitted on the car. The fittings are male on each end, with a female-female joiner in the middle, so everything is there to loop both ends of the car.
    Am I missing something?
  5. #105
    Jul 2016
    San Diego
    1998 E38 750iL
    Quote Originally Posted by jazigk View Post
    Hi guys,
    It may be a bit tight to make those bends on the original lines and you run the risk of cracking them. Instead of that I used an additional piece of brake line with the connectors already on it which you can usually find in stock at NAPA. You use it in place of the janky zip tied rubber hose.
  6. #106
    NYC
    99 IL/13 SXT/04 Audi A4
    easy just open up the diamond keys and change the batteries, its easy you can open the key up with your finger nails.
  7. #107
    NYC
    Open up the key to show TxDarth how easy it's to open up and change the battery.
  8. #108
    Mar 2004
    Tyler, Tx
    Quote Originally Posted by franco90 View Post
    You must have some strong fingernails - my diamond key was a bitch to open even with a Dremel...
  9. #109
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    It’s aftermarket key shell, it’s not glued
    Follow me on Instagram @nordmanmg
    Your current situation is not your final destination
  10. #110
    Mar 2004
    Tyler, Tx
    Quote Originally Posted by NordmanMg View Post
    Ah so........ said the blind man as he picked up his hammer and saw.......
  11. #111
    Indy
    2001 Touring, '95 740i
    Finishing up a set of 18's style 5's for the 740.
    Lets get the party started before it's my bedtime.
  12. #112
    Rutland, Vermont
    E38, E83, E30, F150
    Quote Originally Posted by gaspump View Post
    Nice! Polishing the lips and stuff? Looks great! I polished the style 42's for my 530 several years back. Lot of work!
    Those 18" style 5's will look awesome on your car. Where'd you grab those?
    2001 740i Sport | 2008 X3 | 1988 325i Vert | 1995 Ford F-150
  13. #113
    Indy
    Thanks. They came with the car at sale, but had seen better days. Lots of sanding, buffing, lots of elbow grease put into these things. I've polished these as much as I will, they are what they are, but they do look nice.
  14. #114
    Rutland, Vermont
    E38, E83, E30, F150
    Yeah they get really nasty.
    https://www.bimmerforums.com/forum/s...ject-Completed
  15. #115
    Apr 2017
    Hampton va
    95 740i, 89 735i,
    Quote Originally Posted by oldroller View Post
    If at all possible you should remove the broken bolt from the hub. The forces from the serpentine belts are considerable.
    When you consider that BMW balances even the little power steering pump pulley, smooth harmonics make these cars
    what they are, the Ultimate in driving experience.
    But we all do what we have to in a pinch... The good thing is the broken bolt in the hub is 'unloaded', and could possibly be walked out
    if not too corroded or damaged, leaving the threaded hole ready for a new fastener. Worst case scenario would be using a left handed
    drill bit to 'bite' into the bolt and back it out. Working slowly and carefully, obviously. Good luck!
    What would be the best way to get it out?
  16. #116
    Jan 2017
    North Carolina coast
    2001 740iL Prod 4/2000
    this or similar, drill bolt center and remove with extractor bit...carefully.
    https://www.amazon.com/Irwin-HANSON-...+extractor+kit
  17. #117
    Apr 2017
    Hampton va
    95 740i, 89 735i,
    I went and bought all the stuff to drill it out and took everything apart. Harmonic balancer and all come to find out it wasn't even broke to far I ended up just using grip pliers20180218_143700_HDR.jpg20180218_143700_HDR.jpg20180218_143700_HDR.jpg20180218_143700_HDR.jpg20180218_143700_HDR.jpg
  1. 2017 what did you do to your e38 today?
    By Jamos in forum 1995 - 2001 (E38)
    Last Post: 01-03-2018, 01:14 AM
  2. 2016 what did you do to your e38 today?
    By 1badturboe38 in forum 1995 - 2001 (E38)
    Last Post: 01-01-2017, 08:03 PM
  3. 2015 What did you do to your E38 today?
    By Mayorchuck in forum 1995 - 2001 (E38)
    Last Post: 01-06-2016, 04:36 PM
  4. 2014 What did you do to your E38 today?
    Last Post: 01-01-2015, 04:13 PM
  5. What did you do to your E38 today???
    By kooljess in forum 1995 - 2001 (E38)
    Last Post: 01-30-2014, 01:28 AM
