Page 9 of 9 FirstFirst 123456789
Results 201 to 222 of 222
Thread: 99 Fern Green - RSI Top Mount - BWs366 - 30-3300 Meth
  1. #201
    Bellingham, WA
    e30
    Exactly, until someone puts an O2 sensor equally spaced on each individual cylinder, I have no belief that they are all equal. Or anywhere near that.
    Sent from my E6782 using Tapatalk
    Then you also have sensor to sensor variability
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  2. #202
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by wazzu70 View Post
    Yeah, this is the exact reason why I literally tossed an AEM WB over a bridge years ago. Literally.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  3. #203
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    Took the car out for some pulls last night with the big nozzle from AEMs meth kit. Car dropped .4 points I see 11-11.3 on initial drop when boost comes on and then smoothens out to about 11.5 at WOT some of my load values will make the car see slightly higher 11.8, Iíll need to log those higher AFR values. There is no more driving this car in the rain, haha even at 10lbs 3rd was slipping and the BOV was screaming on every lift off
    Turbo drain- I need to get some better quality -10 drain fittings, it was the only part of the build I used eBay fittings and they are leaking a little so I bought some -10 earls pros from jegs. When they arrive itís going to be fun taking the hose off the pan full of oil to build a new drain line....
    as for my sticky ICV, has anyone ordered parts from these guys?
    https://www.fcpeuro.com/products/bmw...EgL4SPD_BwE#qa
  4. #204
    Royalest of Oaks
    Jeep JKU, Ford Kuga
    FCP comes up a lot, you should be fine.
  5. #205
    Virginia
    97' m52 turbo
    Before buying an ICAV for $170.00 I would recommend posting / looking around on here for one. Bought one for like $30, basically new.
  6. #206
    Nov 2014
    Bellingham, Wa
    1995 325i, 1998 M3 Coupe
    FCP euro is great and offer lifetime warranty. They are also in Arizona so shipping to WA is quick.
  7. #207
    Mar 2013
    THE DIRTY THIRD
    '95 M3 / '95 Supra
    Spent almost $1K with FCP not too long ago and the transaction was smooth coupled with fast shipping. No complaints what so ever from me and I'd buy from them again.
    '95 M3 GT35R
  8. #208
    Manchester, N.H.
    96 332IS 6466 turbo
    I have 3-4 of these. Don't pay $170.
    1996 332IS
    Built 3.2
  9. #209
    Dec 2016
    North New Jersey
    1989 325is, 1995 M3
    Quote Originally Posted by JPE36M3 View Post
    Turbo drain- I need to get some better quality -10 drain fittings, it was the only part of the build I used eBay fittings and they are leaking a little so I bought some -10 earls pros from jegs. When they arrive it’s going to be fun taking the hose off the pan full of oil to build a new drain line....
    Good to hear as I ordered the same kit to build my lines with.
    FCPEuro is great. I try to order as much as I can through them. Even their free/normal shipping gets to me within 2-3 days tops. They're in CT and I'm in NYC.
  10. #210
    Dec 2016
    North New Jersey
    1989 325is, 1995 M3
    Took the car out for some pulls last night with the big nozzle from AEMs meth kit. Car dropped .4 points I see 11-11.3 on initial drop when boost comes on and then smoothens out to about 11.5 at WOT some of my load values will make the car see slightly higher 11.8, I’ll need to log those higher AFR values. There is no more driving this car in the rain, haha even at 10lbs 3rd was slipping and the BOV was screaming on every lift off
    Do you remember off the top of your head which AN fittings you used for your lines? 45*, 90*, 180* etc.
  11. #211
    Feb 2009
    Hackettstown, NJ
    1998 328i
    Following. This is exactly the manifold and turbo I want, just seeing if its worth driving almost an hour for E85.
  12. #212
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    Quote Originally Posted by 96bmftw View Post
    I had this delema, I did not want to get stuck somewhere with a tune setup for e85 with no pumps around - so I went with pump gas and AEM meth. I’m super pleased so far so don’t be afraid of meth/pump combo
    Quote Originally Posted by Chaz17 View Post
    If this is the manifold and turbo of anyone’s choice you’ll need to buy a Cummins flex drain and purchase a steel -10 male bung to weld onto the end. The rest of the hose will be a 45 degree off the Cummins drain to a 90 at the aluminum bung on the pan. Make sure these are male/female hose end fittings.
    trust me the Cummins flex drain is the shit and makes life so much easier, super happy with it
  13. #213
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    peak boost 10.15 lbs, Meth system on a switch
  14. #214
    Vancouver, B.C., Canada
    '97 M3
    It sounds great.
  15. #215
    Mar 2012
    Birmingham, AL
    99 m3
    Whereís that wot 2-3-4 you promised me?
    1989 535i - sold
    1999 Tiag/Dove M3 - sold
    1998 Turbo Arctic/black - current
    2004 TiAg/Black - Current
    PTE6870 | 1.15 ar | Hp Cover, Custom Divided T4 bottom-mount, 3.5" SS exhaust, Fx725 twin ceramic, Dual Turbosmart Compgates, Turbosmart Raceport BOV, 3.5" Treadstone Intercooler, 3.5" Vibrant resonator and muffler, Arp 2k Headstuds | Main studs | 87mm Je pistons | Eagle rods | 9.2:1 static compression, Ces 87mm cutring, Custom solid rear subframe bushings, Akg 85d diff bushings, 4 clutch 3.15 diff, 14mm diff bolt conversion, Poly engine mounts, UUC trans W/ enforcers, Custom Ms41 id1700 E85 tune..... BUILD THREAD
  16. #216
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    Update
    updates, running 10.5-12lbs of Boost with Meth now through the big s366, heres a video of the front end finally together and some pulls
    click!
    https://youtu.be/Pu09dwFdj2M
    cars really coming together, cannot tell you how happy I am I did this project at the moment.
    I really got hands on with painting and did some of the base coats and clear coats as well as half of the prep job, I do suck at masking. We are going to cut and buff the new and old paint surfaces this week and see how she shines. I had my 90 degree nozzle at the back of the head give me some scares my head gasket was leaking but it was just a loose hose at the back of the head/90 nozzle leaking along the head gasket, thats been fixed. the idle control valve didn't solve my random at stoplight brief lean condition at idle, I cant find any hoses leaking boost/vacuum or sucking shut, also did this on both fuel pumps ive ran so far, so I'm assuming my injectors are being picky at idle for this issue. cant find anything else wrong with the build at the time, so im enjoying it. brought some friends out for a ride and they cannot believe how hard these cars pull with a big turbo even in lower boost like this.
    Since the car has been cleaned up its breaking necks everywhere, 3.5" open exhaust slammed with a turbo popping through the hood must be to blame haha or maybe the BW whistle has em I don't know but im loving it, all the work was worth it in the end to say you did it and didn't buy it finished or settle for a turbo "kit", just put your head down and do it.
    need to possibly move the intercooler back 1" to make clearance for the brake duct/charge pipes to not press on the bumper pulling the sides down..
    that BW whistle is a real thing, for 550$ if anyone is considering this turbo for your s52, you should stop considering and just buy it for the price its been amazing. Boost builds by 3200 rpms and reaches peak near 4,000
  17. #217
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Looks good! Did you repaint the whole car of just the new pieces?
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
  18. #218
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    Recently had some warm idle temp's around 210 degrees that would sometimes reach 213. Under WOT and normal driving conditions the car would cruise at 205 degrees, this seemed really warm to me. I checked my Tstat and I had a 92C in the car which must have came factory. That puts the release temp at 198 degree's.
    With help from Butters and Zack, I went to a local autoparts store and grabbed a 180F or 82C tstat and installed in the car. Bleeding the car is always a pain in the ass, the car wanted to heat up, so after jacking up the front end, opening both cap and bleeder screw, heat on full blast and a few shutdowns the car was bled.
    Now the car runs at 194 degree's under daily driving and 196ish under harsh WOT, hot idle is 199 degrees.
    feeling much better about the temp's and a simple 20$ tstat fixed my worries. seems I've seen some people ok with temps 210-220 before they "cool down" but in my case I just wanted the car to be slightly cooler.
    I did buy a Koyo 48mm 3 core radiator in case this summers temps bother me and my old Mishimoto cant keep up.
    current cooling system is
    New OE clutch fan
    Mishimoto Radiator
    Mishimito Relocated and Elevated Expansion Tank
    Steward Water Pump
    82c Tstat and Aluminum Housing
    Mishimoto Hoses
  19. #219
    Virginia
    97' m52 turbo
    You had asked about meth and the drop in AFR awhile back. Figured I would let you know what I'm seeing with the largest nozzle.
    I was at about 11.6-11.8 at WOT now I see anywhere from 10.5 (low) and 11.3 or so (high). Which is great.
  20. #220
    Nov 2005
    Tampa, Florida
    TURBO 99 M3, CX-5
    Awesome thread, and congrats on the build! Enjoy the boosted life!
    Mod list - M50 manifold; TechniqueTuning Stg2, Apex Arc-8, ZKW euro, clear corners Mike R diffbrace, Koni Yell with HR race
    X-brace UCC tranny mounts -BLK/with enforcers, powerflex rtabs,lcabs, AAfanclutch, mishimoto rad, UCC Ultra-cerametallic Clutch.
    You will go through days of joy and days of sadness as the pursuit for power leads to madness...
  21. #221
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    Quote Originally Posted by 328iFun View Post
    yup nice with the AEM meth on the big nozzle im seeing 10.9 on initial kick down and will lean out to 11.3-11.5 depending on the pull/load variables. the numbers are sweet and the car feels strong! I don't think ill be doing any pulls without it since the car likes it so much I might as well leave the system on full time now.
    Quote Originally Posted by JuCo View Post
    thanks brother! once you go boost theres no turning back, only turning up!
  22. #222
    Virginia
    97' m52 turbo
    Yeah, I leave it on as well.
    I figure my egts are probably high with such a small backhousing anyway
    Sent from my SM-G960U using Tapatalk
  1. 99 fern green vert auto m3 part out
    By Hitmachine101 in forum Interior Lighting & Body Parts
    Last Post: 06-06-2013, 08:29 PM
  2. FS/FT '99 Fern Green M3
    By skylerwaite in forum 3 series & Z Series
    Last Post: 07-14-2010, 01:55 AM
  3. FS: 99 Fern Green E36 M3 Coupe
    By Lewcis in forum 3 series & Z Series
    Last Post: 06-01-2010, 09:51 PM
  4. 99 E36 M3 - Fern Green SE PA
    By speedracer228 in forum 3 series & Z Series
    Last Post: 10-31-2009, 01:36 PM
  5. 99 M3 Fern Green/Magma, 50,780 miles, all original
    By hein in forum 3 series & Z Series
    Last Post: 10-29-2007, 12:04 PM
