Page 8 of 11 FirstFirst 1234567891011 LastLast
Results 176 to 200 of 273
Thread: 99 Fern Green - RSI Top Mount - BWs366 - 30-3300 Meth
  1. #176
    Virginia
    97' m52 turbo
    It's a nice feeling to be able to move onto the 'next' step.
    I'm still running a 7lb spring with an eboost street 2 controller, and haven't really messed with it much. Hitting a 10 psi peak at complete WOT
    ...And it hasn't gotten old. Pretty sure it can take or keep up with anything around me. But I took Butter's advice. I have other slower vehicles to drive daily or often. When I need to, I take the E36 out....
    Glad you got it sorted !
  2. #177
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    no leaks! no strange nosies! just an N/A motor that finally came alive! or maybe thats me behind the wheel now????
    I turned it up to 60 percent duty cycle tonight. this will be the highest I try and run truboost with the small spring installed. In 2nd gear wide open pull, I saw flashes to 8lbs. So im sure in a higher loaded gear, it may go up to 10lbs... this car is TOO much fun, im ruined.
    It continues to turn heads, everywhere... most likely my front mount sticking wide open and straight exhaust, I don't care, im loving it.
    99 Turbo M3 - BWs366 - RSI - Fuse Fabrication - JE Cutring -
  3. #178
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    Went down to Fuse fabrication tonight on a rowdy cruise...
    IRODs new build.. just leaving with a fresh catch can install and 3.5" exhaust
    CLICK *** my new idle sounds and speed
  4. #179
    Vancouver, B.C., Canada
    '97 M3
    Wow, it’s been a long time since Rod had boost. Congrats to him.
  5. #180
    Nov 2013
    VA
    E36
    Glad you figured it out and enjoying boost. That being said, have you turned it up to 20lbs yet? lol
  6. #181
    Virginia
    97' m52 turbo
    Those front tires have to be rubbing like a mfer
    I'm flared, 245 and mine rub.
  7. #182
    Jun 2005
    south
    85 318i
    Good to hear you sorted out the issues, enjoy the car and be safe.
    My manifolds powering 8sec and over 1000rwp cars
    Home of the highest HP stock M30 in the world 550rwhp/622rwtq
    1/4 mile---> 9.81 @138 C4 Auto
    10.08 in car vid --->https://youtu.be/OiinFhUomjg
    Dyno vid... http://www.youtube.com/watch?v=C7aM7..._order&list=UL
  8. #183
    Feb 2016
    Tenneessee
    1997 BMW z3 2.8l
    Mind sharing what was causing your issues? Great build!
  9. #184
    Apr 2017
    Florida
    E36
    Congrats!!
  10. #185
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    got out and did some pulls today, one of these is with meth and the other is not AFRS are in the 11's with meth and without. the car is running 9.75 lbs right now and im loving it, im sure soon ill be turning it up. I do have a strange random lean condition at idle after small cruises with deceleration in neutral idling the car will randomly go way lean at idle and stumble for a quick second before correcting itself almost like my ICV is failing or hoses are still sucking shut. when the car stumbles it smokes for a brief second, must be the oil backing up in the big journal bearing turbo as the car dips into the 500 rpm range. this issue is very random and does not happen often. I did have all my valve seals replaced when the head was in the shop, my turbo drain does have some "S" shape in it with a little tiny bit of a flat section.
    CLICK
    heres a list of the codes that popped up randomly after my random, briefly lean AFR idle / RPM dip.....
  11. #186
    Nov 2013
    VA
    E36
    Did you have a check engine light with those codes?
  12. #187
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    I did
    I have a feeling my idle / lean issues are from my ICV sticking, I’ve cleaned it multiple times but when I pull it out sometimes it takes a hard shake to get it free each time so I think I’m going to replace it. Makes sense since revving the engine sends it back to normal idle height and also the issue is very random at best
    As as far as the gasoline issues I’m a loss ???
  13. #188
    Boston, MA
    E36 M3 Turbo
    My iac has been doing wonky things like that too also throwing idle speed plausibility code. The other codes you have should have been deleted items, evap & post cat o2 sensors etc.
    Sent from my SM-G930P using Tapatalk
    97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
  14. #189
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    Retorque head tonight and I’m gonna bump her up to 13-14 lbs with water Meth system in check, installing a fan relay so I can run my aux fan on a switch inside when I want. I’ll get some good GoPro videos here soon. Feels good to have the car coming together
    even at 10lbs the car was faster then a well maintained f80 m3 by a good driver, granted we only ran 2nd and 3rd gear
  15. #190
    Virginia
    97' m52 turbo
    Switch is a bad idea for fan... not sure on your ambient temps but it doesnt take long to over heat. I run a pusher and puller constantly. Or relay the aux with a low temp fan switch and low temp therm.
    Replace the icav. I tried cleaning mine made it worse. Replaced it with a good unit and it problems went away. No codes
    Boost will also create more heat. Especially since your top mount. And your IC is blocking air flow. Which is why I run them constantly
    True about the comparison against f80 m3 though. People dont wanna believe it until there in the passengers seat and the pedals to floor all the way till 4th. It's actually pretty amazing a car this old is soo capable. I had a good friend who drives a cobra daily who was very skepticle but
    made his admissions with time. Jealously more than anything
    Sent from my SM-G960U using Tapatalk
  16. #191
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    Quote Originally Posted by 328iFun View Post
    I kept my mechanical fan, cooling is great, that thing pushes tons of air. The aux fan on a well fused switch should be fine, don't see the difference between that and my meth system on a switch both blade fused and relayed. My new hood has huge vents, the temps inside the hood should be great with a massive opening above the turbo. The thought of a aux fan on a switch is JUST on demand stop light or traffic enabling extra air on hot days when im idling alot.
  17. #192
    Virginia
    97' m52 turbo
    Quote Originally Posted by JPE36M3 View Post
    I kept my mechanical fan, cooling is great, that thing pushes tons of air. The aux fan on a well fused switch should be fine, don't see the difference between that and my meth system on a switch both blade fused and relayed. My new hood has huge vents, the temps inside the hood should be great with a massive opening above the turbo. The thought of a switch is JUST on demand stop light or traffic enabling extra air on hot days when im idling alot.
    Ehh... not sure on your ambient temps where you live. If it's cool steadily wouldn't worry about it. Just have to remember to turn it on
    I had it on a switch when I lived on the OBX, NC for awhile and it overheated because I forgot to turn it on :-(
  18. #193
    Manchester, N.H.
    96 332IS 6466 turbo
    You should see around a .5 AFR drop with meth on. Go heavier on the meth. Not 50/50. Do a 70/30 or a 65/35.
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  19. #194
    Virginia
    97' m52 turbo
    Are you tuning to Meth or just dumping in with the current tune?
  20. #195
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    to be honest
    I realize we could most likely add some timing and pull some fuel to get the perfect meth mixture but I just wanted to spray to add some safety factor on a pump tune with our Seattle lack of e85 issue... so yes, im just spraying on a base tune. I used the medium nozzle, the car completely ate it up and loved it, so im going to try and use the bigger nozzle and see were the AFR's stand. if butters is right ill be too rich around 11.1-11.4 when I Start spraying with the big nozzle
    does anyone know were do I want my wastegate to start "cracking open" ??? on true boost there is a spring setting that asks when you want your wastegate to begin to crack open? say im running 10lbs, would I want the gate to open around 8lbs?
  21. #196
    Manchester, N.H.
    96 332IS 6466 turbo
    to be honest
    I realize we could add some timing and pull some fuel to get the perfect meth mixture but I just wanted to spray to add some safety factor on a pump tune with our Seattle lack of e85 issue... im just spraying on a tune, I used the medium nozzle and the car ate it up so im going to try and use the bigger nozzle and see were the AFR's stand. if butters is right ill be too rich around 11.1-11.4 when I Start spraying with the big nozzle
    That's not "too rich". Totally fine. Nice and safe. Remember its an average of the 6 cylinders. So, if this was a 3 cylinder and #1 was 12.0 #2 was 11.0 and #3 was 13.0 your gauge would read 12.0 and you would think your dead on. But, not so much. So, keep it on the rich side. Don't be afraid of that. 10.9-11.4 is where I like to be. I couldn't give 2 shits about the measly X% of power I'm leaving on the table. Keep it safe, keep it together. Once you crank that thing up to 17+psi, nothing in the road will catch you anyway. Unless you got a ton of hot rodders around.
    1996 332IS
    Built 3.2
  22. #197
    Virginia
    97' m52 turbo
    ^ awesome explanation.
    Just need to get my numbers that low. I agree on the safety factor as well
  23. #198
    Virginia
    97' m52 turbo
    What would cause 1 cylinder to be leaner then the others though?
    A vacuum leak or could it be mechanical ?
  24. #199
    '97 M3
    Intake air distribution, water/meth distribution, turbo exhaust manifold flow characteristics...... stuff like that...
  25. #200
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by chikinhed View Post
    Exactly, until someone puts an O2 sensor equally spaced on each individual cylinder, I have no belief that they are all equal. Or anywhere near that.
    1996 332IS
    Built 3.2
  1. 99 fern green vert auto m3 part out
    By Hitmachine101 in forum Interior Lighting & Body Parts
    Last Post: 06-06-2013, 08:29 PM
  2. FS/FT '99 Fern Green M3
    By skylerwaite in forum 3 series & Z Series
    Last Post: 07-14-2010, 01:55 AM
  3. FS: 99 Fern Green E36 M3 Coupe
    By Lewcis in forum 3 series & Z Series
    Last Post: 06-01-2010, 09:51 PM
  4. 99 E36 M3 - Fern Green SE PA
    By speedracer228 in forum 3 series & Z Series
    Last Post: 10-31-2009, 01:36 PM
  5. 99 M3 Fern Green/Magma, 50,780 miles, all original
    By hein in forum 3 series & Z Series
    Last Post: 10-29-2007, 12:04 PM
