Page 11 of 11 FirstFirst ... 234567891011
Results 251 to 273 of 273
Thread: 99 Fern Green - RSI Top Mount - BWs366 - 30-3300 Meth
  1. #251
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    Quote Originally Posted by VLT View Post
    I've read this thread front to back. Almost following your build exactly.
    Any advice to give?
    My lower timing chain is extremely tight. Was yours like that?
    Beautiful car, and happy boosting!
    yes its tight because of the spacer. put exhaust sprocket in center of all holes to compensate for the tensioner which has no effect on sprocket position with spacer builds
    99 Turbo M3 - BWs366 - RSI - Fuse Fabrication - JE Cutring -
  2. #252
    FL
    are slow.
    The FX Stage 4 clutch you chose is rated for 340 ft/lbs of torque. How is it doing with your power levels?
    -Dr. Seuss
  3. #253
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    Quote Originally Posted by Hova View Post
    Man to to be honest I’ve felt it slip in the beginning of 3rd one time on a 14.5 psi pull. Also felt it slip randomly in traffic once in a while when I’m heavily on and off engagement.. But OVERALL, I can’t believe it’s taking the abuse... atleast for now... but something tells me this clutch is completely maxed out now...
    Looking back I’m still happy I did this build on a cheap clutch like this and a stock block... sure helps you figure out what you really want and were you need to spend your money.
  4. #254
    FL
    are slow.
    Quote Originally Posted by JPE36M3 View Post
    There are some cheap alternatives include the following:
    Quote Originally Posted by PowerKraut View Post
    M30 / S38 Flywheel + Sachs 765 performance pressure plate + 4-puck sinter clutch disc. Thats what i run. No slip at over 600 Hp from an HX52
    You just have to bolt an M30 starter engine on your S50/M50 block or fit the m30 starter gearing (is that what its called?) onto your S50 flywheel.
    -Dr. Seuss
  5. #255
    Nov 2013
    VA
    E36
    Fx stage 4 is rated higher than 340 ft/lbs if you follow the break in process. Usually maxes out around 500ft/lb. I'm at 400+ ft/lbs and it's holding up fine...
    Sent from my Moto Z (2) using Tapatalk
  6. #256
    FL
    are slow.
    Quote Originally Posted by bmw328m52 View Post
    Sure, I can understand that they might have some margin in their claims of 340 ft/lbs, but 400 ft/lbs is only a 15% margin. I'm not saying that the stage 4 wouldn't hold 400ft/lbs, but there is no way that clutch is going to hold up with 500ft/lbs or anywhere near that. He is running a BW366. I had that same turbo on my E30-S52. When he turns up the boost I seriously doubt it will hold for very long. The BW366 has A LOT of flow. Go look at what the Supra guys have been doing with that turbo, 700-800whp on a regular basis.
    -Dr. Seuss
  7. #257
    Nov 2013
    VA
    E36
    https://r.tapatalk.com/shareLink?url...9&share_type=t
  8. #258
    FL
    are slow.
    Interesting. So it might hold up for a bit with his setup, assuming he stays around or under 500whp.
    -Dr. Seuss
  9. #259
    Nov 2013
    VA
    E36
    Whp is irrelevant. All about torque. Once you get close to 500wtq it will start to slip. Happened to someone local to me. Can't go wrong for $400...
  10. #260
    Mar 2013
    Upstate NY
    M3
    My car makes 620whp and 570wtrq.... I have a Fx stage 3 or 4 or what ever their "strongest" is. Mine doenst slip soooo idk maybe I got lucky?
  11. #261
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    Quote Originally Posted by Mklock View Post
    Damn! Those are big numbers on this clutch !!
  12. #262
    Mar 2012
    Renton, Wa
    98 m3
    Its all how the clutch is used, broken in, and how you shift.
    For it to hold power you basically have to dump it, you cannot slip it in under any load.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  13. #263
    Jul 2014
    Finland
    BMW E36 328i Turbo
    I have billet m50 Flywheel, sachs sre 765+stock organic disk. 500whp 600trq, no slip with that combo.. Proven To be cheap and usefull
    Quote Originally Posted by vollosso View Post
    Amen To this, few slips and basicly would be done.
  14. #264
    Jan 2019
    Wilmington DE
    94 Turbo Miata, E36 soon
    Any updates? I just finished reading this thread and have really enjoyed it. Thank you for sharing the story.
  15. #265
    Mar 2013
    Upstate NY
    M3
    Yeah, I've never EVER slipped my clutch. I broke it in for 500 miles as well, changing gears, decel accel under light load too. I've had it apart and back again. Minimal wear... perfect contact patch. I've felt no need to slip it either, dump in first about 2600, it bogs just a hair... but then it's go time. Any time my foot hits that clutch pedal I'm off the gas, then change the gear.. yes it's not like driving your civic around where you can power shift 2nd and the clutch grab but heck... what do you want for 300$?
  16. #266
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    18psi on this thing and she still holding!!!
    Gapped all all sorts of cars lately
    re ran my nemesis 2014 track edition GTR which on the current setting is around 700wheel very close race all the way to 140 and he reeled me in when i had the car set to 15psi. This was also him letting me brake boost the car and get a tiny initial hit. Don’t know if the s52 will continue to hold up at 18 psi for now I’m staying with 15 psi....
    2nd gear is pissing me off. If I slam into 2nd under full boost sometimes the shifter goes through the defent and gets stuck in 2nd gear position with no gear. Resulting in me smacking the limiter ........... not only is this embarrassing but I’m sure my motor isn’t happy about that either
  17. #267
    Mar 2013
    Upstate NY
    M3
    Hahah yessss gap all the things. I'm doing the same thing you are, I had it on dyno queen mode for 3 months last summer and came to realize that it's just mental. 620whp on an E36 is flat nasty but 525whp will be fine. 20psi is fun n all but does it sacrafice longevity?? Probably... lol.
  18. #268
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    The ZF320 is probably at its limits above 500 lbs rwtq. I am on my 3rd. The Getrag 420G is better and needs a different clutch and linkage and driveshaft. The GS6-53 is stronger than the 420G but requires an adapter ring (Volloso sells one) and linkage and flywheel/clutch and driveshaft. I am about to install one. The T56 Magnum is stronger than the GS6-53, but is an even more expensive conversion.
  19. #269
    Boston, MA
    E36 M3 Turbo
    I've had the 22rpd GS6 kit installed for a long time - amazing transmission matched with an RTD shifter.
    Good to hear this thing still running great and kicking ass. It's hard to drop the boost down after you get a taste of it lol
    97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
  20. #270
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    thank you to everyone here for this build thread.
  21. #271
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    IMG_0807 by joe princen, on Flickr
    in those boxes... CES extreme ported head. dual supertech valve springs. 1+mm oversized. steel retainers. sunbelt stage 2 cams. pauter rods.
  22. #272
    Nov 2016
    Long Island, NY
    A few
    Congrats on the Performance BMW feature. Does your existing head have a problem or are you just doing elective upgrades?
  23. #273
    LI NY
    Turbo 99' M3
    Just read the thread - nicely done putting this thing together. Fern Green is beautiful and so is the fabrication work on the exhaust!
  1. 99 fern green vert auto m3 part out
    By Hitmachine101 in forum Interior Lighting & Body Parts
    Last Post: 06-06-2013, 08:29 PM
  2. FS/FT '99 Fern Green M3
    By skylerwaite in forum 3 series & Z Series
    Last Post: 07-14-2010, 01:55 AM
  3. FS: 99 Fern Green E36 M3 Coupe
    By Lewcis in forum 3 series & Z Series
    Last Post: 06-01-2010, 09:51 PM
  4. 99 E36 M3 - Fern Green SE PA
    By speedracer228 in forum 3 series & Z Series
    Last Post: 10-31-2009, 01:36 PM
  5. 99 M3 Fern Green/Magma, 50,780 miles, all original
    By hein in forum 3 series & Z Series
    Last Post: 10-29-2007, 12:04 PM
