Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 52
Thread: S85 V10 M Roadster
  1. #26
    Jun 2016
    Odessa, TX
    2000 BMW Z3 2.8 Roadster
    https://vorshlag-store.com/collectio...shaft-assembly
    Would this be of use? I don't know if you've seen it yet.
  2. #27
    Nov 2008
    Kelowna
    '99 M Roadster '08 135i
    Thanks, I've looked at using that shaft but I'm waiting to see what the my fabricator thinks.
  3. #28
    Nov 2008
    Kelowna
    I picked up these front and rear 2 piece ECS rotors to go the Porsche 996 calipers.
    Attachment 618965Attachment 618966Attachment 618967Attachment 618968
  4. #29
    Nov 2008
    Kelowna
    Also decided while the front end is apart I would replace the hubs as a PM thing.
    Attachment 618969Attachment 618970
  5. #30
    Aug 2014
    kentucky
    '98 Z3 M Roadster
    Can you make a post about your 996 calipers when you get it all together., and what you think about the feel of it. I've been thinking about doing this.
    Built S52 w/Dinan ISR-3 kit, NickG Stage 2+ Tune, Dinan Vortech V2 Supercharger, Dinan Air to Air Intercooler, Dinan CAI, Porsche 803 HFM, Buldogge 6" crank pulley, Griptec 2.90" blower pulley, Eurosport UD pulleys, Dinan 3.38 Diff, Dinan front/rear Swaybars, Dinan springs, Koni Yellow Sport Struts, Ground Control end links, South Bend Clutch Stage 3 Organic, AASCO Light Weight Flywheel 18.5#, Zionsville Radiator & Oil Cooler, Riot Racing BBTB, Schrick Intake Manifold, 42# Injectors, Schrick cams 264/256, Forged Wiseco pistons 9.0 comp., Forged Eagle rods, Supertech dual valve springs & valves, VAC crank & bearings, Supersprint mufflers, Euro Z3 midpipe, Raceland euro headers, Walbro 255, Bevauto ignition coils, Vortech Mondo bypass, Bailey Diverter DV30, Ireland Rear Subframe Bushings, Mason Engineering Strut Brace, Mason Engineering Clutch Petal, Apex 18" EC-7 Wheels, Full Custom Sound System, two trunk lids (with & without OE spoiler), Hardtop, Trunk full of AK's...
  6. #31
    Nov 2008
    Kelowna
    Sure but winter will have to end first! We've have about 10" of the white stuff over the last couple days.
  7. #32
    Nov 2008
    Kelowna
    So here are a few shots of the initial fitting of this beast! you can see how it really fills the engine bay, but surprisingly its not to bad for access. With the exhaust removed this engine is about 27" wide, evening getting to the exhaust bolts isn't bad due to how low they are on the engine. The ABS unit had to be relocated as the brake lines were touching the valve cover, so to get the engine all the way back I had to unbolt it and push is over. luckily there is plenty of room just under the brake booster.
  8. #33
    Nov 2008
    Kelowna
    Since I wanted to keep the original feel of the car the SMG trans was not kept and a 6 speed manual trans was acquired, this also meant a new flywheel and twin disc clutch were needed.
  9. #34
    Surrey, BC
    Canada
    BC represent. this is amazing.
  10. #35
    Nov 2008
    Kelowna
    You know it!!!
    Are you on BC bimmers?
  11. #36
    Surrey, BC
    Canada
    Quote Originally Posted by Z3 M Roadster View Post
    You know it!!!
    yeah, under the same name but I don't log on there much.
  12. #37
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Great build! This will be a wild ride. I have an E90M3 and think the motor would be fun in a car that weighs 25% less.
  13. #38
    Nov 2008
    Kelowna
    Thanks, I did consider using the S65, maybe I'll use one for the next project The manual trans I purchased for this came from a wrecked E90M3 with only 18,600 miles on it. The seller also included the flywheel/clutch and the cooler lines in the deal, unfortunately I couldn't use any of those pieces.
  14. #39
    Jun 2005
    New England
    V10 is 25% better!
  15. #40
    Nov 2008
    Kelowna
    An update on the progress. The headers are coming along well but slow... they are more challenging than my guy figured! I'll post some photos soon. The RallyRoad caliper brackets and brake lines arrived last week, thanks Eric!
  16. #41
    Nov 2008
    Kelowna
    Header update
    Ok the RH header is almost done, here are some shots of the snakes! sorry about the cell phone pics
  17. #42
    Nov 2008
    Kelowna
    Well here's a shot of the headers out of the car, they just need the v-bands welded on and off to get ceramic coated. These took 60+ hrs and were a pia to build. Sorry about the crappy pic I'll get better ones when I get the car back.
  18. #43
    Nov 2008
    Kelowna
    Here are some better photos of the headers.
  19. #44
    Nov 2008
    Kelowna
    Due to the limited room the steering shaft is routed through the header. Because of the heat I felt the aluminum shaft would not fair well I opted for the Vorshlag steering shaft.
  20. #45
    West V
    1995 M3
    :motherofGod:
  21. #46
    Nov 2008
    Kelowna
    An update
    I picked up an updated oil pan with 2 drains (left), the early pans (Right) only had 1 drain plug where as the later ones have a drain added to the front.
  22. #47
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    Awesome build! This thing is going to rip!
    Make sure to change the rod bearings while the motor is out!
  23. #48
    Dec 2008
    Long Island
    528iT
    Wowsers. Most epic swap ever. Shoe-horning all those runners around there, barely enough room to re-fit the heat shields!
  24. #49
    Nov 2008
    Kelowna
    Quote Originally Posted by e30polak View Post
    Thanks!
    Yes its a must on these engines, so this is what was done when it was out:
    BE rod bearings + ARP rod bolts
    New main bearings (#6 had failed)
    New vanos hp line
    Replaced every seal and gasket except for the head gaskets
    Removed and cleaned the throttle bodies
    Disassembled and cleaned main oil pump
    Disassembled vanos oil pump and filter screen/vanos pump and crank gear were replaced with updated ones while the car was under warranty
    Removed and inspected vanos filter screens
    Replaced filter screen at the bedplate
    Flushed both air boxes
    Quote Originally Posted by itsbrokeagain View Post
    It was challenging that's for sure!
  25. #50
    Jan 2014
    SF, CA
    S/C LS2 e46, LS e367&8
    This is amazing, my secret hope is that someone with a coupe buys our M6 V10 and enjoys the everloving crap out of it.
  1. S85 V10 M Roadster
    By Z3 M Roadster in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-30-2024, 07:42 AM
  2. S85 V10 + Z3M = Win
    By T-Rex in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-15-2010, 10:43 PM
  3. S85 V10 E30 M3 vs. V8 E92 M3 (Vid)
    By jszy25 in forum BMW Rides & Events
    Last Post: 01-02-2010, 01:58 PM
  4. RUMOUR: Z4 M Coupe with S85 V10 (E60 M5) engine and SMG III gearbox.
    By gamelanman in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 03-11-2007, 10:42 PM
  5. Help Needed: S85 V10 Firing Order
    By Bimmerman535i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-01-2006, 09:51 PM
