Results 1 to 7 of 7
Thread: Coolant level drops fast
    Mar 2013
    Alpharetta
    1998 z3
    I know this has been covered numerous times but I'm baffled. Sons 96 e36vert has to have the coolant reservoir completely filled every couple weeks.
    No Symptoms, none on the ground, new reservoir, no coolant smell, no white exhaust, no coolant in oil, no leak from fairly new water pump. Had it pressure tested awhile ago.
    I could live with topping it off on occasion but this stuff has to be going somewhere.
    Ideas please?
    Sent from my iPad using Tapatalk
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    IF your trouble is a cracked head, you would have all of the symptoms that you list -- no smell, no puddles, no coolant in the oil, and so on.
    If you were to remove the head and turn it belly-up, the #3 and #4 cylinders have a thin wall between one of the exhaust valves and the adjacent water galley. Tiny amounts of coolant pass from the water jacket (passage) into the exhaust stream where it is vaporized. I'm not suggesting you tear the engine down, but if you were to do such a thing then you want to inspect very closely the wall between the exhaust valve seats and the adjacent water passage. I believe this picture is the #3 cylinder, but the 3 and 4 ought to be mirrors of each other so the trouble could be either or both, 3 and/or 4.
    Baton Rouge, LA
    '98 328i convertible
    Is the reservoir completely empty?
    Filling the reservoir completely is not the correct thing to do. Once the engine heats up, the coolant will expand and push coolant out of the system as needed. When it cools back down, the reservoir will have a lower level in it. But it should not be empty.
    - Ken -
    Jul 2010
    Murrieta, CA
    Also, this is not really a question that is unique to the convertibles. It's a common problem for the Inline Six engines of all chassis configurations.
    United States
    02 525,01 X5,99 323IC
    I have had 2 of these engines have cracked coolant passages just like the above pictures. As the corrosion/cracks grow you will also start to pressurize the coolant system and start to blow hoses. So, be prepared for that! Keep an eye on it closely.
    Jul 2010
    Murrieta, CA
    Quote Originally Posted by capebmw View Post
    What happens is that as the coolant loss becomes greater, the engine temp rises which produces more pressure. System Pressure is a function of temperature. Less coolant = more temperature = more pressure.
    SF Bay Area
    98 M3 vert, 05 X5
    I "love it" when someone starts a thread, asks for help, then never returns to read the comments members take the time to leave for them...!
  1. Replies: 4
    Last Post: 02-14-2019, 07:56 PM
  2. eng oil level dropping fast
    By jcrypto in forum 2006 - 2010 M5 & M6 (E60, E61, E63, E64)
    Last Post: 06-11-2015, 05:39 PM
  3. Coolant level slowly dropping...
    By irv0735 in forum 1991 - 1999 (E36)
    Last Post: 10-27-2009, 02:14 PM
  4. Coolant level dropping with this heat?
    By PseudoRealityX in forum 1992 - 1999 M3 (E36)
    Last Post: 08-10-2007, 05:50 PM
  5. Coolant Level and Fast Driving
    By Impervious in forum 1999 - 2006 (E46)
    Last Post: 06-12-2007, 04:34 PM
