Results 1 to 25 of 57
Thread: Car Shakes When Braking at Highway Speeds
    Dec 2013
    Houston, TX
    "96 850
    Hi guys,
    I have an issue with my 1996 850 and me and my mechanic are unable to figure out what's wrong. I've replaced pretty much everything in my suspension recently and this issue started a few months after that process.
    Whenever I brake at about 60 mph, the car shakes violently. It's fine when accelerating and will only do it when braking at certain speeds. What could be causing this?
    I don't know if this info will help but it started after hurricane Harvey. My car was at the mechanics (where else would it be lol) at the time and he says it did not flood. I have no reason not to believe him... It looked fine. However, even though water didn't get inside, maybe part of the suspension was soaked for a while? I also started getting these check engine lights for misfires after the hurricane but they have gone away. My mechanic believes that it could've been due to gas that got water in it and that a lot of his clients were having the same issue.
    Any help is appreciated, he says he has looked over all his work and had the tires rotated and balanced... He thinks it maybe the steering box? I just spent over 10k on this stupid car redoing everything and I just want it work
    Any help is much appreciated!
    Edit: Also, it only seems to start doing it after the car has warmed up a little bit. If it's been sitting and I take it out, it'll be fine the first few times I try it and then seems to progressively get worse until it's shaking quite ferociously.
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Check the run out of the brake rotors.
    Check the brake calipers for binding. Salt water and metal don't get along.
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Jun 2010
    Hyperworld
    '97 840CI
    Quote Originally Posted by Guts1200 View Post
    ... the car shakes violently... it's shaking quite ferociously.
    For those who have not experience this, the violence is far, far beyond your imagination.
    For the root cause, think beyond the box.
    Due to the magnitude of violence, I have a particular suspicion.
    Dec 2007
    Dallas, TX
    Quote Originally Posted by Hyper View Post
    This forum works best when people aren't left to guess - why didn't you post your "particular suspicion", instead of having people guess...
    Sunny Cali,
    6.5 second 69 Camaro
    Absolutely!
    My issue at those speeds years ago were Upper control arms, Change them both, Buy them complete. I chose Lemforder.
    May 2009
    Bangkok, Thailand
    5/93 E32 730i M30
    Have a read of this ... it covers almost all the likely culprits ... Timm is pretty much a guru on these things ... ( as you may guess from his website)
    http://www.meeknet.co.uk/e31/E31_Shimmy.htm
    Good luck
    Jan 2016
    Ca
    2001 525it
    If you have non factory brake parts that's why, after you replace the brakes with factory parts then thrust bushings could be worn out from the shaking they we're trying to control
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    As TxGR8White says - that's a sticky caliper!
    My BMW Repair YouTube Channel
    Memphis TN
    95 840,14 535i
    My 840 shaked very bad when braking at high speeds, i was convinced it was control arms. I first replaced all my rotors and that turned out to be the problem. No more shaking at any speed.
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    control arms are the #1 suspects
    bad Brake master cylinder causes caliper lockups too... strange, but true
    '91 850i 6sp (mint) (sold)
    Dec 2007
    Dallas, TX
    Quote Originally Posted by cartoonz View Post
    Control arms will cause shaking regardless if speeding up or braking. The OP's problem is under braking conditions. Seeing as how the car is in Houston, and the mechanic swears it didn't sit in flood water, I suspect that it did - at least up to the brake calipers. It doesn't take long for those sitting in water, that you will see problems.
    Oct 2008
    Irvine, CA
    1993 850ci 6spd
    Had a similar problem. Crazy shake upon braking at speed. Turned out to be rotors and poorly made hub rings on 5 series wheels. Changed to correct hub sized wheels with new rotors and fixed for now.
    May 2013
    Salinas CA.
    1993 BMW 850CI
    Brembo calipersshould
    Hi guys,
    My suspicions are that your calipers are corroded internally, as often happens with the Brembo units, and so they are sticking. This can lead to pads that don’t retract, and so they overheat, and leave smears on the rotors. Another possibility is that the flex lines to the calipers are damaged internally, and as such keeping the pressure inside the calipers. This rarely happens on both sides at the same time, and leads to the car pulling to one side or the other. Master cylinder problems can also cause the pads to remain in contact with the discs, and then overheat, pad smear, and shake. I would start with the calipers, and if they are free moving, move on to the master cylinder replacement. You will have to bite the bullet on this one, as you have a late model car. The early ones up to 94 can use the 750il ones. I hope this helps. Your mechanic should be able to track this down, or perhaps you need to find a new one. If the rotors are badly smeared / overheated, you will need new ones, as turning won’t help. Of course, an inspection of the traction arm bushings, and ball joints are in order. Turner sells monoball units to replace the rubber units, as does Moosehead engineering. Good luck
    Dec 2013
    Houston, TX
    "96 850
    Thank you *so* much for all the replies guys! You all are amazing!
    I'm going to have him check out the calipers... that sounds like it could be it, especially since it started after the flood. When I test drove it a couple days ago, they were quite loud when braking. Like they were making sounds when closing and opening.
    However, if it is the calipers, why would it only do it at certain speeds? Braking under 60 mph seems to be fine but as soon as I go over, it'll do the shake... albeit not always and sometimes worse than others.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The BMW suspension system has a resonant frequency - 50 MPH - 60 MPH for the front and over 80 MPH for the rear:
    "If an imbalance is detected, note the speed range in which it arises. The following rule applies for BMW vehicles:Vehicle speed = 80 - 100 km/h Front axle affectedVehicle speed = 140 - 160 km/h Rear axle affected"
    http://www.meeknet.co.uk/e31/Timms_b...20Problems.pdf
    Sunny Cali,
    Because it's a control arm bushing and not a caliper.
    Dec 2013
    Houston, TX
    "96 850
    Hey guys, sorry for taking so long to post, it's been hectic around here.
    I've attached a pdf of the suspension work I had done. Everything was working great until the flood...
    I asked my mechanic to look at the calipers... need to follow up with him.
    Attached Files Attached Files
    San Ramon, CA
    850Ci, M5, Model-S P85D
    "Everything was working great until the flood..."
    Oh...No!!!
    Very possible the rotors rusted under the pads during the flood, which is not good. If you look closely you may still see a pad imprint on the rotors, maybe not.
    The easy way to check for a seized caliper is to drive the car until the brakes shake then drive it for several miles without using the brakes hard, then coast to a stop and feel for unevenly heated rotors. Laser thermometer is a good tool if you have one, if not be careful not to burn your fingers.
    If all the rotors are fairly cool and the heat is even at all rotors, you could try to re-bed the pads on the rotors but most likely you will need to replace the rotors. Insurance may pay for the rotors replacement as flood damage.
    That is, whenever the rotors get wet under the pads and the rotors are not dried off quickly the rotors will develop a deep rust due the the pads trapping the moisture against the rotors on both sides of the rotor (this can also occur when you wash the wheels and don't dry the rotors off by driving the car).
    At a minimum, the rusting under the pads will strip the bedding off the rotors and that will cause the rotors to have an uneven friction spot at the point where the rotors once had a rust spot.
    Hence the vibration during hard braking. Measuring the rotors will not show any abnormal run-out or parallelism problem as this is an uneven friction issue.
    You can try to re-bed the pads by driving and heating the rotors and pads by stopping several times hard, until the rotors get very hot (slight fade), then continue to drive to let them cool down some and heat them up again to to a slight fade to transfer some of the brake pad material onto the rotors, then keep driving until the rotors cool down and see if the vibration is gone.
    However, I don't think you'll be happy until you have new pads and rotors installed.
    Oct 2016
    Montgomery, AL
    '92 850i 6-speed (SOLD)
    I looked through your service receipt Guts. Wow . . . $10k! You practically rebuilt the entire car. For that kind of money, I'd hope they would be taking better care of you. I'd bring it back to the mechanic and say, "This is on you." If they are good mechanics, they should be able to figure this one out instead of you having to ask for a diagnosis on the forums.
    When something is beyond my technical capabilities, I take my cars to a small independent shop here in Montgomery. If anything is wrong after the work is complete, I bring it in (with no appointment needed) and they take as long as required to get it right without charging me a thing.
    Sean
    Arlington, Virginia
    E31, E38, E39
    I have had my steering column tightened twice now. Not related?
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Dec 2010
    Baker, FL
    1995 BMW 840Ci
    New rotors are an annual event when I flush the brake lines. The Bosch have a lifetime warranty so it's just a time factor. I'm sure better rotors would last longer but for what cost?
    Mar 2011
    Liberal Loontown, CA
    Cool Volvo, Ugly BMW
    Annual? Are you driving 50k miles a year or something?
    Dec 2010
    Baker, FL
    1995 BMW 840Ci
    Cheap rotors.
    Dec 2013
    Houston, TX
    "96 850
    Hey guys, quick update:
    My mechanic replaced the brake rotors in the front and he says it's reduced the vibration but not eliminated it. He is convinced it cannot be the calipers and says the brakes in the back cannot cause vibrations in the front. He wants to check/change the hubcentric rings (I think that's what he called it?) next... what do you guys think?
    If changing the front rotors helped, maybe doing the backs would fix it or is he right about that not being it?
  1. Steering wheel shakes when braking at high speeds? HELP E38 Gurus!
    By alpinewhite740i in forum 1995 - 2001 (E38)
    Last Post: 04-26-2015, 09:16 PM
  2. Shake when braking at highway speed
    By Houseboater in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 01-21-2015, 01:13 PM
  3. Car shaking while driving at highway speeds
    By mdimillo in forum 1988 - 1996 (E34)
    Last Post: 01-06-2014, 12:28 AM
  4. Shaking When braking At highway speeds??
    By NYZ93 in forum 1996 - 2003 (E39)
    Last Post: 07-31-2010, 01:57 AM
  5. Car Shakes When Braking at High Speeds
    By x13alle12x in forum 1996 - 2003 (E39)
    Last Post: 03-23-2010, 05:01 PM
