Results 1 to 25 of 28
Thread: Z3M Roadster on Staggered E39 M5 Wheels (Style 65's)
    Nov 2017
    Cincinnati
    1999 BMW Z3 M Roadster
    My Stock Z3M Roady Not My Stock M5
    So, just like most BMW fan boys, I love the E39 M5. I've been meaning to put some Style 65 wheels on my car to pay homage for a LONG time but couldn't ever find an example. I did my own due diligence and bit the bullet. These are genuine BMW OEM wheels that have been sandblasted and powdercoated. I didn't think I would dig the black, but it's growing on me. I couldn't help but drive it today when I got them on. If you are looking for specs/calcs see below. If you have any questions feel free to ask. It came out okay. I posted some pictures below.
    OEM Wheel/Tire Specs
    Z3M Roadstars... M5 BMW Style 65's...
    Front Wheel 17”x7.5”, 41mm offset 8"x18" front, 20mm offset
    Rear Wheel 17”x9”, 8mm offset 9.5"x18" rear, 22mm offset
    Lug Pattern 5x120mm 5x120mm
    Centerbore 72.6 mm Centerbore 74.1 mm Centerbore
    Front Tire 225/45-17 245/40/18
    Rear Tire 245/40-17 275/35/18
    Z3M Fitment
    Fronts: Inner 15mm Away from strut, Outer 27mm Closer to Fender
    Rears: Inner 20mm Closer to Strut, Outer 8mm Retracted
    Modifications to Fit Style 65’s
    Fronts: 72.6-74.1mm Hub Rings, Heat Liner and Run 1-1.5 ° negative camber
    Rears: 72.6-74.1mm Hub Rings, +20mm Spacers = Stock distance from Strut, 12mm Closer to Fender
    Front Tire Differences
    225/45-17 245/40-18 Difference
    Diameter inches (mm) 24.97 (634.3) 25.72 (653.2) 0.74 (18.9) 3%
    Width inches (mm) 8.86 (225) 9.65 (245) 0.79 (20) 8.9%
    Circum. inches (mm) 78.45 (1992.71) 80.79 (2052.09) 2.34 (59.38) 3%
    Sidewall Height inches (mm) 3.99 (101.25) 3.86 (98) -0.13 (-3.25) -3.2%
    Revolutions per mile (km) 807.61 (501.83) 784.25 (487.31) -23.37 (-14.52) -2.9%
    Rear Tire Differences
    245/40-17 275/35-18 Difference
    Diameter inches (mm) 24.72 (627.8) 25.58 (649.7) 0.86 (21.9) 3.5%
    Width inches (mm) 9.65 (245) 10.83 (275) 1.18 (30) 12.2%
    Circum. inches (mm) 77.65 (1972.29) 80.36 (2041.09) 2.71 (68.8) 3.5%
    Sidewall Height inches (mm) 3.86 (98) 3.79 (96.25) -0.07 (-1.75) -1.8%
    Revolutions per mile (km) 815.98 (507.02) 788.47 (489.93) -27.5 (-17.09) -3.4%
    Speedometer Difference w/ 245/40-17 vs 275/35/18
    Speedo Reading Actual Speed
    20 mph (32.19 km/h) 20.7 mph (33.31 km/h)
    25 mph (40.23 km/h) 25.87 mph (41.64 km/h)
    30 mph (48.28 km/h) 31.05 mph (49.96 km/h)
    35 mph (56.33 km/h) 36.22 mph (58.29 km/h)
    40 mph (64.37 km/h) 41.4 mph (66.62 km/h)
    45 mph (72.42 km/h) 46.57 mph (74.95 km/h)
    50 mph (80.47 km/h) 51.74 mph (83.27 km/h)
    55 mph (88.51 km/h) 56.92 mph (91.6 km/h)
    60 mph (96.56 km/h) 62.09 mph (99.93 km/h)
    65 mph (104.61 km/h) 67.27 mph (108.26 km/h)
    Speedometer Difference w/ 245/40-17 vs 265/35/18
    20 mph (32.19 km/h) 20.47 mph (32.95 km/h)
    25 mph (40.23 km/h) 25.59 mph (41.19 km/h)
    30 mph (48.28 km/h) 30.71 mph (49.43 km/h)
    35 mph (56.33 km/h) 35.83 mph (57.66 km/h)
    40 mph (64.37 km/h) 40.95 mph (65.9 km/h)
    45 mph (72.42 km/h) 46.07 mph (74.14 km/h)
    50 mph (80.47 km/h) 51.19 mph (82.38 km/h)
    55 mph (88.51 km/h) 56.31 mph (90.61 km/h)
    60 mph (96.56 km/h) 61.42 mph (98.85 km/h)
    65 mph (104.61 km/h) 66.54 mph (107.09 km/h)
    Z3///M Roadster | GC Sleeves | TCKline 450lb (F) & 700lb (R) | Koni S/A | Porsche 996 4-Pots | CSL 345mm (F) | e38 328mm (R)
    All that and not even a side pic to see how they look?
    Nov 2017
    Cincinnati
    Quote Originally Posted by BimmerBreaker View Post
    Here are some additional pictures... (photo limit above)
    20171229_083116_HDR.jpg 20171229_083150_HDR.jpg 20171228_234451_HDR.jpg 20171229_075614_HDR.jpg
    Sep 2017
    Northeast
    2001 M Roadster
    Quote Originally Posted by Meeners View Post
    Is this OE suspension?
    San Jose, CA
    '11 335is vert, '01 Z3M
    Tried this on my car a few years ago while I was having my roadstars refinished. Had aftermarket wheels on my M5, so I just bolted the stock M5 wheels on my M Roadster. I liked the look, but when I removed them a couple of weeks later, the front brake pad rattle clips had worn grooves on the inside back of spokes on the M5 wheels. If you have worn pads you might not have this. You could try spacers but I think the fronts may stick out of the fenders.
    Lawrenceville, GA
    4 BMWs.
    Doesn't look right to me.
    Nov 2017
    Cincinnati
    Quote Originally Posted by DimrBimmer View Post
    Correct.
    Quote Originally Posted by sjdennis View Post
    My pads are decently new, I checked and took some pictures but they didn't come out well. After reaching in it appears I have around a finger thickness of space between the back of the wheel and what you are talking about. Good looking out. When I replace pads I will check. So far I haven't had to do any modifications to the car up front.
    Quote Originally Posted by amancuso View Post
    If it's wrong, I don't want to be right. It might be because it's at stock height and it has stock m5 tires as well. They are a little meaty.
    Lawrenceville, GA
    4 BMWs.
    Correct.
    It’s not that. It’s that the wheels are poking out of the wheel wells. Always a bad look IMHO. if you like it though, have at it.
    Nov 2017
    Cincinnati
    Ah, I see what you mean. I'm hoping when I play with suspension/camber/caster they'll come in a bit, but to each their own. At stock height with stock alignment the wheels protrude about 3mm in the front beyond the hood and about 2mm from the rear fender. Here's a slightly better pic.
    Lawrenceville, GA
    4 BMWs.
    Cool. Thanks for sharing. It’d be even worse in the rear for a non M!
    Wadsworth, Ohio
    BMW
    Put a lower profile tire on them and I think I could like the look!
    -James
    Nov 2017
    Cincinnati
    Here's the goal next year.
    Lawrenceville, GA
    4 BMWs.
    Mar 2003
    somers,ny
    well.......not my taste.....too tractor ish, big, meaty, hoopty, cumbersome
    Nov 2017
    Cincinnati
    Here's some more recent pictures after rolling around and letting the suspension settle in with the hardtop.
    Oct 2017
    Edmonds, WA
    1998 BMW M Roadster
    I personally like a bit of poke, but things look pretty damn cozy up front there Chief. Some lower profile skins would be waay cheaper than a hood if you get interference at speed near full compression.
    Nov 2017
    Cincinnati
    I'm purchasing new tires for the front this winter and am currently trying to decide b/n 225/40/18 & 235/40/18. Right now the outside of the tire rubs the liner at full lock with the 245/40/18 on inclines at the front on hard cornering... With the 275/35/18 in the rear it will affect geometry going with smaller than what I have. The 225/40 would decrease with sidewall about 8mm - effectively raking out the car but shifting more weight to the front. The other option would be gaining a little more width with the 235 and only decrease sidewall about 4mm (albeit it would be a little harder to find tires in this size). This way the tire wouldn't be as stretched.
    Having a slight rake would be okay for front grip during corners, however it would affect the high speed stability like caster. I'm the least excited about going back to the smaller width in the front as I feel like these cars have a little under-steer if you don't apply pedal feedback in an emergency. I'm hoping the slight shift in weight would help with that. I know I'm overthinking things, but I really enjoy this stuff.
    My stubborn option would be to swap the top hats and get a little bit more aggressive camber in the front.
    Feel free to give your opinions.
    Nov 2017
    Cincinnati
    Been driving around on the setup for about a year now... around 6k miles and no issues. I still haven't bought the smaller front tires like intended. The tires rubbed a little of the fender liner as expected but haven't had any major issues with fitment. I drive semi-aggressively every so often but haven't seen any track time. So far so good. Plans are to lower the car about an inch or so, pump gas, and drive. My highest priority is to save up and have the rear trunk/subframe welds strengthened before I do anything crazy with the car. Figured I'd update.
    Mar 2003
    somers,ny
    your last post, 2nd to last pic:
    car looks like an RC car sitting there.
    Feb 2015
    Durham, NC
    '99 MCoupe | E90M3
    Looks good! I think with that smaller profile tire and a little more negative camber up front, they might look a little more at home.
    1999 M Coupe Evergreen | 2008 E90 M3
    Click the here for E36 M3 manual swap project!
    Nov 2018
    Florida
    E36 325is Coupe
    IMG_1417 (002).jpgThese wheels always look good
    Sep 2017
    Northeast
    2001 M Roadster
    Quote Originally Posted by jrkoupe View Post
    Looks great. I have similar Apex rims in same color, but have not installed them yet.
    +1 on it looking like an RC car. Just need to photoshop longer antenna.
    Nov 2017
    Cincinnati
    A guy at the car wash told me that when I was getting in. Told me I'm too big for it because I had to get in butt first and swing in.
    Quote Originally Posted by Krohn27 View Post
    I concur. Front tire is massive. I'm having trouble finding options for a decent e36/7-8 adjustable coilover system but I'm planning to Christmas gift the old girl after bonus time. I see the trend that the new E36 options all have adjustable height in the rear shocks and mounting tabs on the front shocks for the sway bar so i'm checking that avenue and opting for some extended top hats.
    Quote Originally Posted by Mercedville View Post
    Yes! It took me a while to find a real OEM set but it was worth it. That looks good on your 36vert!
    Nov 2018
    Florida
    E36 325is Coupe
    id rather have those roadsters tho
    Nov 2017
    Cincinnati
    Finally got around to making a decision as far as front tire. I was compromising between a 235/40/18 and a 225/40/18 and finally settled on the 225 Bridgestone G-Force to eliminate any rubbing issues for when the car is lowered. They are fairly wide for a 225 but they are a little shorter than the 245/40 I had on there previously. The tire should tuck now under load... if it doesn't I can still swap the top hats. The setup is fairly meaty and should work well balancing pressures with the stiffer suspension.
    After
    Before
    Now that I finally made a decision on tire choice - suspension is in the works to get rid of the horrendous wheel gap and replace the clapped out stock springs/struts/shocks. I decided to go with the Koni single adjustable shocks front and rear. In the front I'm going with Ground Control coilovers in a 440lb rate and I received some rear TCKline 500lb standard springs which I will probably be selling. I have purchased a new set of TCKline 700lb shorty springs with height adjusters to balance the car and drop it approximately 1" from where it is now. I also purchased a set of helper springs to keep the front springs in place during any corner unloading. Looking forward to next season and testing the 440f/700r combo.
    Rear Springs Ordered:
    http://www.tcklineracing.com/webdocs.../Details80.cfm
    Rear Adjusters Ordered:
    http://www.tcklineracing.com/webdocs...Details385.cfm
    Waiting on Rear Spring/Adjusters and Front Helper Springs
  1. Replies: 11
    Last Post: 11-05-2013, 03:38 PM
  2. E39 Square Set of E39 M5 Wheels-- Style 65 Wheels
    By aksc in forum Wheels and Tires
    Last Post: 07-28-2013, 11:30 PM
  3. E39 I want to buy one E39 M5 Wheel (Style 65) 18" x 9.5" (rear wheel).
    By KINGM6 in forum 5 series & 6 series
    Last Post: 03-21-2012, 08:06 AM
  4. E39 Wtb: E39 m5 wheels (style 65)
    By KINGM6 in forum Wheels and Tires
    Last Post: 02-22-2012, 03:02 PM
  5. E39 FS: OEM E39 M5 Wheels (Style 65)
    By Schitzo in forum Wheels and Tires
    Last Post: 12-23-2010, 07:51 PM
