Results 1 to 17 of 17
Thread: Need guidance for a Z3 suspension upgrade.
    bridport vermont
    01 Z3 3.0 roadster
    I thing about refreshing my 2001 Z3 3.0 Roadster suspension. 65,000 original miles (M sport option package ie wheels, trim....is not a M car)
    I for a resonably compliant road suspension that will absorb or Vt roads frost heaves...for brisk riding in the Mountains..I do not want a "race" suspension.
    What do I need to do? Shocks/struts, bushings(which ones), springs( do they sag a lot over time?)
    What about the Pelican Part Stage 2 kit? anyone with experience?
    Any comments , ideas welcome
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    No experience. Springs don't sag but can break. Do you suspect that?
    At your miles the original struts and shocks are worn out.
    The Stage 2 kit's struts and shocks are Bilstein Touring, says slightly stiffer ride. Looks like a good value and what you would want.
    https://www.pelicanparts.com/catalog...SUSSHK_pg1.htm
    You could just replace the struts and shocks for less, using the Bilsteins, or KYB for even less.
    Edit: You say you want a "resonably compliant road suspension that will absorb or Vt roads frost heaves". Bilstein Touring though softer than the unbearable Sports, are likely to be harder than your present shocks. My choice on your rough roads would be KYB at the low end, or Koni at the high end per Post #3. They are not in Pelican's kits but maybe you could ask them to substitute and adjust the price..
    BMW MOA 696, BMW CCA 1405
    Feb 2014
    Galt,CA
    2002 M Coupe
    For the best street ride buy a set of adjustable Koni's and set them one turn from full soft; the improvement will surprise you.
    Marty
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    First mod should be to replace the subframe bushings with poly. From what you say, I think most will opine: subframe bushings, Koni shocks, Conti or Michelin tires, new rubber bushings as needed. Here's one, of many, discussion on it: https://www.bimmerforums.com/forum/s...Z-3-M-Roadster
    Tallahassee
    1998 Z3 M Roadster.
    Have a word with this company.
    https://shop.bimmerbum.com/t/z3-30i-roadster-2001-2002
    Ed has all you need and great advice
    Kent, Ohio
    1998 M Roadster
    Second talking to Ed--you can't go wrong.
    Nov 2009
    Roanoke,Va
    2000 MCoupe
    yes, Bimmerbum would be the one to speak about this question.
    bridport vermont
    01 Z3 3.0 roadster
    Thanks for the great advice. I will take a look at the subframe mount and existing bushings. That is a new issue for me. Hope I do not need that.$$$$
    On your advice I will definitely go with the Koni shocks.
    FYIW I put on Conti tires a couple of years ago and handling, noise and road harshness greatly improved. The rear insides are wearing down noticeable at about 15k miles.
    Feb 2014
    Galt,CA
    2002 M Coupe
    I put Conti's on my stock height M Coupe (with Koni's), and while the wear on the rear tires is actually pretty even across the full width, I am on my second set of rears while the fronts are still going. It seems like the rears last 15-16K, while the fronts have 31K on them with usable tread left.
    Marty
    Oct 2012
    Louisville, KY
    Quote Originally Posted by vtbob View Post
    .. I put on Conti tires a couple of years ago... The rear insides are wearing down noticeable at about 15k miles.
    Which is supposedly normal, from negative rear camber. But I put on new tires 15k miles ago, too, and don't notice it happening yet.
    Dec 2013
    Chicagoland area
    EXOTICS
    Tire friendly (camber & toe) settings can help to diminish wear issues.
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    You can buy offset subframe bushings, to take out some of that camber that is wearing out the inside of your rear tires. https://www.akgmotorsport.com/produc...-poly-75d-e30/
    Oct 2012
    Louisville, KY
    Quote Originally Posted by MIKYZZ4 View Post
    BMW made the Z3 with fixed negative rear camber, and I don't think there are any settings to adjust. Changes to rear camber or toe must be done with hardware.
    Dec 2013
    Chicagoland area
    EXOTICS
    Begun the libations early, sorry for the erroneous information.
    I must have had my thoughts on a z4 instead of z3.
    You are correct, rear camber & toe are fixed and normally non-adjustable on a z3,
    whereas on a z4, rear camber and toe adjustments are possible.
    Dec 2013
    Chicagoland area
    EXOTICS
    Now that I come to think about it, my z3 never had tire wear issues,
    however the z4 is another matter!
    bridport vermont
    01 Z3 3.0 roadster
    I'm not concerned about rear inside tire wear at 15k miles. I'll get this summer, 4-5k miles on these and get a new set in the fall..or sooner if needed.
    Feb 2017
    Texas
    Z3
    Hi Bob, I too own a 01, 3.0 Roadster. What did you end up doing ? Care to share your experience and some advice maybe ?
  1. Need Hood for 01 Z3 body style
    By AlbertaAviator in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-07-2010, 12:23 PM
  2. 2000 BMW 325 - Need Guidance for Offer
    By culapo in forum 1999 - 2006 (E46)
    Last Post: 07-14-2009, 07:40 PM
  3. Need advice for chipping and other upgrades.
    By mgv2325 in forum 2001 - 2006 M3 (E46)
    Last Post: 11-06-2007, 07:22 PM
  4. Need rims for a Z3 Roadster 2.2l
    By FinRoadster in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-29-2006, 02:28 PM
