Results 1 to 13 of 13
Thread: Braking vibration
    Jun 2016
    Los Angeles, CA
    M235 | M3 | 325Ci
    Braking vibration
    I have now gotten a few track days under my belt, in my E36 M3, and I have noticed that my brakes pulse/vibrate badly once they get really hot under hard braking. At the beginning of a session, no problem, but near the end when the brakes get hot, when I brake hard into a corner I get bad brake pulsing. When I first noticed it, I just assumed I had warped rotors that needed replacing. But then I realized, that I do not have this issue AT ALL when driving on the street. And even at the beginning of a track lap session, the brakes are fine, it is only after about 15 minutes on the track that I get the brake pulsing.
    Any thoughts? Do I just need to replace the rotors, or is this normal? Or somethint else is going on here? Thanks!
    Oct 2003
    Seattle
    99 M3
    You don’t mention what pads you are using, but it sounds as though the pads/rotors have overheated.
    Aug 2012
    Central, MD
    1995 M3
    Not normal. It is odd that it takes 15 minutes. But, my BET is that it's a combination of pad type and uneven pad deposits. A few fast laps gets you a good deposit on the rotors, then some combination of slow laps and minimal braking, or pulling into pits, holding brakes on while sitting still, etc, creates 'snarf' on the rotors, which will absolutely create the problem you've described.
    Warped (or out of spec) rotors are VERY rare, and would cause vibration at all times.
    What pads are you using?
    Marietta, GA
    95 M3, 87 535is
    Change to a different pad compound or brake harder to push past the uneven deposits on the rotors.
    Jul 2012
    Orlando, FL, USA
    1993 BMW 325i
    Inspect for a crack as well
    Oct 2017
    NoVa
    E36 M3 GTS2
    Yes, what brand and model of pad would help diagnose the problem.
    It's possible if your using a street pad, it could be depositing material on the rotor when you over heat them. Only noticeable under heavy braking when hot.
    Jun 2016
    Los Angeles, CA
    M235 | M3 | 325Ci
    Pads are EBC Yellowstuff. I have not noted any cracks on the rotors when I self tech.
    Maryland
    2006 Estoril Blue/Cin M3
    Are you sure it isn't ABS?
    Oct 2017
    NoVa
    E36 M3 GTS2
    Quote Originally Posted by skyotee View Post
    That's a street/track pad. Perhaps you're just over working them
    Jul 2011
    West Seattle/ Pullman, WA
    98 M3 Cosmos
    Do you feel the pulsing/vibration through the steering wheel and pedal?
    It sounds like pad deposits to me.
    When I first started tracking my car I struggled with brake shudder that would begin halfway through sessions.
    I had a set of street pads and a set of track pads (PFC 06) and would swap pads before heading to the track.
    After dealing with the shudder for a few events I bought a dedicated set of rotors that I would only use with my track pads.
    The shudder hasn't returned once I stopped using street and track pads on the same set of rotors.
    ArlingtonVA
    E46S54B32
    about 5 years ago at VIR I got a brake vibration that felt exactly like a warped rotor/pad deposit but it was neither..… turned out to be a bent hub.
    Montreal, Quebec, Canada
    E46 330 ZHP, E36 328i
    I would try PFC.
    They have an enduro compound (Usually even numbered) that will be usable on the street and does not require bedding once you get to the track. Once you try it you will not go back. There is a reason they are expensive... They work.
    California BAY AREA
    e30 M3, 335d
    I was having this exact issue with my E36 M3 as well. I recommend upgrading to a more track friendly pad. Your pads might be reaching their heat limit near the 12-15 minute mark during your sessions.
    - Max
  1. Brakes vibrate when hot, ok when cool
    By hukalaki in forum 1992 - 1999 M3 (E36)
    Last Post: 08-05-2003, 04:04 PM
  2. High speed brake vibration....
    By Ryan Stewart in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-10-2003, 11:18 PM
  3. brake vibration
    By BJO in forum 1992 - 1999 M3 (E36)
    Last Post: 08-08-2001, 12:02 PM
  4. Front brakes vibrate and squeak like a mother...
    By Jim//M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-09-2001, 10:34 AM
  5. braking vibrations
    By PECivil in forum 1991 - 1999 (E36)
    Last Post: 03-24-2001, 11:37 AM
