Results 1 to 22 of 22
Thread: WTB 540i/6, need help with choosing
    Aug 2015
    Fairfax VA
    1983 320i, 2008 M5
    Hey all,
    I currently drive an E21, and want something more modern/powerful that can cruise the highways with ease. I've done a decent amount of research and have driven a 540i/6, so I know this is the E34 I want. I'll feel as though I'm missing out with I go with less powerful or E39 and up. I want one that can be daily driven and last at least 6-7 more years before needing a full overhaul. I've located a few that are in my price range (operable at $7500) and want some opinions on what to eliminate and what to further pursue.
    Option 1: Silver w/ white interior, 173k miles, $7300
    Pros - Owner is trusted BMW enthusiast/friend and local, has all the desirable upgrades (headers, new coilovers, 3.15 LSD, PCV and supplemental hoses replaced, M62 top end), and good documentation
    Cons - Higher mileage, interior is worn, rust spots on rear bumper and trunklid, was not treated well by 1st owner (friend is the 2nd)
    Option 2: Black on black, 113k miles, $7500
    Pros - Low mileage, E31 front brake setup, short shifter, custom exhaust, winter and summer tires/wheels, well maintained with decent documentation, PCV done, new top end gaskets and water pump
    Cons - Not local, but coincidentally flying out to his location for vacation so will try to see the car soon, priced highest
    Option 3: Oxford Green w/ tan interior, 160k miles, $5500
    Pros - Price, knowledgeable seller (has owned 540i/6's before), great documentation (all records in past 10 years), essentially stock other than poly bushings
    Cons - Don't love the look, higher mileage and some rust along the doors, does not know if PCV has been done
    Option 4: Grey w/ black interior, 119k, $5500
    Pros - Low mileage, dinan everything (chip, exhuast tune and tips), alusil block (I know not a problem anymore, but I heard it's better for resale), new clutch
    Cons - Poorly documented, Will need some work... has SLS that does not work now, occasional cold start rough idle (MAF/vacuum leak?), occasional lambda 1 code thrown randomly (o2 sensor?), cats are gutted (95's in VA still need to pass emissions) and small rust on the bottom of all 4 doors
    Sorry for bombarding with all the info! Just found 4 cars I'm interested in, but want to pick the one that'll be the most reliable (hoping for 100k more miles!) and won't need a huge overhaul soon.
    Let me know what you guys think - thanks for the help!
    Mar 2017
    STL
    2017 M3 6sp
    If I was you I would look for low mileage stock CA car with no rust at all. It’s funny to read “little surface rust on doors”. It’s doors rusted through and most likely rocker panels too.
    none of the above
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Except for No.2, they all seem overpriced, and that's assuming the only Con to No.2 is that it's far. Anything over 5k is "nice and sorted, or really special" territory for an E34, where rust and worn interiors do not belong.
    No.1 has some questionable items: M62 top end, presumably valvetrain? M60 heads are sometimes put on M62 blocks for hotter cams, stronger timing chain, and higher compression, but not the other way around. And headers? Really?
    PCV is a $200 job if you pay someone to do it, not a big deal in the bigger picture. You'll pay more than that for any meaningful rust repair.
    None of these I'd consider "higher mileage", certainly not worth worrying about.
    Nov 2002
    Portland, Oregon
    M30 E30, 540i6 E34
    Def stay away from 4. Black on black is the best, I get compliments on mine all the time. If you can get him down closer to 7K I'd say go for it, it will hold it's value IMO. You can always find maintenance items or bushings that need to be done to help drive the price down.
    If option 1 has the "m60b44" as Moroza properly described I'd take a good hard look at it, if you want more of a hotrod. The 3.15lsd is $$$ and a significant mod. That said if you just want a fun solid cruiser option 2 sounds well equipped, I "overpaid" for my e30 back in the day and it was a great decision.
    Nov 2011
    Riverside, CA
    01 M5, 93 M5, 94 525iT
    If it has rust and you're planning on keeping it that would be a no go in my book. Rust repair on doors and probably rockers could easily be $4k. I had my M5 sport seats redone a couple years ago for $1350 so there's a baseline cost for that. If you've researched E34s then you know you can expect to replace all the bushings, hoses and do a cooling system refresh if there is no evidence they've been done. Search California, Nevada and Arizona for rust free examples which in my book would be worth waiting for. Here's a current BAT auction you might keep an eye on.
    https://bringatrailer.com/listing/1995-bmw-540i-5/
    Tommy L.
    oOO \ (IIII) (IIII) / OOo)
    -o- (##########) -o-
    2001 BMW M5 LMB
    LHD Euro
    Bilstein PSS, Black Kidneys, Dinan Rear Anti-sway Bar, Matte Black Style 65, UUC SSK w/DSSR, Alpine iLX-007, Alpine MRV-F 340 Amp, Boston Acoustics Pro components, Alpine MRP-M450 Amp, Infinity Kappa 102.7W Sub x2
    Current Garage:
    1993 BMW M5
    1994 BMW 525i Touring 5spd
    2004 Ford SVT Lightning
    Oct 2017
    Harriman, TN
    1995 BMW 540i/6
    I just paid $7,000 for a 155,000 mile, black on parchment 540i/6 with a fairly well documented history.
    "The right to self defense is fundamental to a free state. If, by dictate of the state, it is unlawful to defend your own person, you are not a citizen nor even a subject; you are property"
    Mar 2004
    Silverton, Oregon
    E31-E36, E70, E46
    Quote Originally Posted by Kingpin025 View Post
    Yeah over 15K plus buyer's commission..Wow! I'm not so sure any of the cars listed above are high priced..at all
    moroza's Avatar
    BFE
    E34T
    15 grand, no mention of suspension work, and they didn't even bother to tighten up the peeling weatherstripping on the RR door?
    Oct 2017
    Harriman, TN
    1995 BMW 540i/6
    Quote Originally Posted by MMMEAT View Post
    I'm not so sure any of the cars listed above are high priced at all
    I'm sure I over paid for mine, but in the end I think it was worth it (at least to me) as it was exactly what I was looking for. A 540i/6 with nice paint, a nice interior, no rust, and no EDC, SLS, or ASC.
    Zionsville, IN
    93 740i, 84 533i
    To be honest, the top two are in higher regard, but the performance upgrades (headers?) always make me think the car has be driven very hard. Other than the coil overs and "M62 top end" for #1, the things you list are fairly cheap upgrades. PVC is cheap, LSD can be found for $300-$400, etc
    Truthfully, I would look for a bone stock, well treated, rust free example in the color you want. Black on Black is the best, although I am biased. Use Searchtempest and be patient
    Black on Black 740i - 10/92 build date, 225,000 miles.
    Delphin on Cherry 533i - 4/84 build date, 136,000 miles
    Black on Black 328i - 3/96 build date, 185,000 miles - Sold
    2008 Porsche Cayenne GTS
    Jun 2012
    New Mexico
    2003 328i
    I've got one out here in NM. M60B44, 280rwhp, needs paint and the drivers seat is worn out. No rust. Black on beige. 218k on the chassis. 3k takes it.
    May 2016
    Springfield , MO
    3-02 530s,1-97.540-1.740
    I have an E39 Black on Black sport with sport seats heated with 64k. I just got it back form being repainted Cosmo Metallic with 4 coats and 4 coats of BASF clear $400 a gallon. It's an automatic so, that may be an issue for you but it's a lot less $ that the clutch will cost when replaced at$2,500. You can call 417-299-8813. Mack and I'll send pics
    Jun 2012
    New Mexico
    2003 328i
    Quote Originally Posted by Guidonhue View Post
    PM replied. Had to log back in after I finished typing, if you didn't get it I can send it again.
    Aug 2015
    Fairfax VA
    1983 320i, 2008 M5
    Got it! Thanks
    moroza's Avatar
    BFE
    E34T
    Quote Originally Posted by Mackman View Post
    A clutch is nowhere near $2500. That's wholesale price for a new slushbox, before installation. And it's still a slushbox.
    Sep 2009
    Milwaukee WI
    540i/6, 740il,M Roadster
    This is the E34 you want, or everyone wants.
    RobZR
    https://bringatrailer.com/listing/1995-bmw-540i-4/
    Mar 2006
    Great Lakes
    BMW
    Quote Originally Posted by RobZR View Post
    RobZR
    Nice. Except for your intake manifold.
    This 540 6spd sold for 6300. I don't know who's car it is but seems well cared for.
    https://bringatrailer.com/listing/1995-bmw-540i-3/
    And an M5 sold on the same day for $13,500
    https://bringatrailer.com/listing/1993-bmw-m5-9/
    Jul 2006
    Lake Lanier
    E34 540i6 M Sport
    Have any information on option 4? If it's a 540i6 with SLS, chances are it's an M Sport.
    95 540i6 M Sport - 95 525it S52/OBD2 - 433k E36 328i5 - X5D that hit a pothole - IG: @justinmurray95
    Sep 2009
    Milwaukee WI
    But, but, but, fresh Calypso, M-pars,blk sport seats, and LSD is all I needed to see.
    If I didn't have one in the garage just like it, I'd all over that auction.
    Hellrot, and Calypso have to be the best E34 colors. But I'm a little biased.
    RobZR
    Jun 2005
    Texas
    E21, E24, E34, E46
    Unless I've forgotten or missed something, a US model 540i/6 cannot have SLS unless it's an M-sport. So confirm if it is an M-sport, and buy that one.
    Sep 2016
    Niagara
    1995 525i, 1994 540i6
    buy mine. . 165 kms mint 6000 CDN
    Feb 2009
    Arizona
    1998 e36
    nothing worse when seller says it has "upgraded" intake and all it is crappy cone filter that drags hot air from the radiator reducing the power and increasing the chance for detonation
  1. Need help with choosing a short shifter **GIFT**
    By SentraDude in forum 1991 - 1999 (E36)
    Last Post: 12-16-2009, 05:23 PM
  2. Need help with choosing a Cam and Long Con Rods?
    By M202002 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-12-2008, 08:03 AM
  3. Need help with choosing a car
    By mrfd3s in forum 1999 - 2006 (E46)
    Last Post: 11-04-2003, 09:05 PM
  4. need help with choosing suspension
    By $Rich$ in forum 1991 - 1999 (E36)
    Last Post: 08-13-2003, 06:51 PM
  5. Need help with choosing detail supplies?
    By joeyc in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 12-17-2002, 09:43 AM
