Page 6 of 9 FirstFirst 123456789 LastLast
Results 126 to 150 of 224
Thread: 540i P1346 and P1347 cyl 3 misfire after timing chain guides + vanos
  1. #126
    Jul 2013
    Worcester, MA
    03 540i Msport Touring
    except that goes in direct contradiction to CW's timing knowledge, he repeated many times that he has never seen or heard of a valve being bent by hand, so this would be experience number 1 of his many engine timings so far.
    although speaking of cw i hope he's ok. he's pledged to get things right but i haven't heard from him since friday the 5th
    Looking for an e39 Touring black carpet set, including the rear cargo cubbies and side sections!
    ALSO looking for 540i 6speed manual transmission sets (2001+ pedals with switches, driveshaft, gearbox), for the 6speed swap! Probably not for a while....
    GN92489
    540i msport touring; jet black on grey
    Progress Thread (general)
    Progress thread (touring specific)
  2. #127
    Jan 2016
    Madison, WI
    2001 BMW 525i Touring
    Ausfahrt! Teee heee heee!!
    I will see myself out now.
  3. #128
    Jul 2013
    Worcester, MA
    joe's of worcester called back to let me know of some minor pitting on four of the intake valves, saying it'll rob some horsepower and a couple psi of compression. He offered to replace them while he was there, but i'm so checked out of this by now, and running low on cash (all those valves would be another $120 in parts), that i declined.
    CW finally got back to me so he'll help get the head back on and re timed once i get the head back.
    suffice to say the second the head is back on i'm going to do some compression testing and blow some air onto the valves to see exactly how much psi is gone
    GN92489
  4. #129
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Where was the pitting? If it's on the valve seat he could do a quick lap job on them. OK GG and Snotty, I'm sure you guys are going to pick up on that.
  5. #130
    Jul 2013
    Worcester, MA
    sounded like the valve itself hence why he was suggesting replacing the valves but man i am not in any kind of mood to spend any more money or time on this than necessary, i'll live with a few less horses
    GN92489
  6. #131
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Interesting. Jim what did you find on those old heads that are in my basement - any signs of pitting/wear? Prob oughta ask 'Ho what he's found with all the motors he seems to have pulled...
    Glad CW is back online and lined up to help.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  7. #132
    West of Boston, MA
    2001 BMW 540iT/6
    This thread makes me glad I just bent my timing trigger installing my valve cover like ham fisted gorilla (apparently). Here is hoping you're back on the road soon. Wrong time of year up here for all this... :/
  8. #133
    Jul 2013
    Worcester, MA
    Quote Originally Posted by scottieducati View Post
    PRETTY MUCH :|
    if things hadn't gotten bent i would have been back on the road the day after christmas.
    almost a month later than that...
    GN92489
  9. #134
    JimLev's Avatar
    Sundance Mesa, NM
    The valves themself looked OK. You have the heads minus some of the valves, how do the seats in the head look?
  10. #135
    Mar 2010
    Too buried in basement to grab quick/easy... When time allows if I remember..
    2003 M3CicM6 TiAg
    Former:
  11. #136
    Jul 2013
    Worcester, MA
    hey guys i think my valves are bent
    also here's the light gap he was talking about. although he said it was only four intake valves, i only really saw it on one of them, i am somewhat worried about how much compression will be lost because of this
    GN92489
  12. #137
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    That's not ok. There should be no light showing. Pull those valves too.
  13. #138
    JimLev's Avatar
    Sundance Mesa, NM
    Wow, that ain't good. They need to be replaced or you engine will run like crap and backfire thru the intake.
  14. #139
    Jul 2013
    Worcester, MA
    oh good lord i'm going to smash my head through a wall at this rate, UGH
    what could have possibly caused THAT though?
    why did it run fine while i was doing the seafoam (minus the misfire)?
    although now i cannot remember if this problem intake valve was on cylinder 3 or not...
    GN92489
  15. #140
    JimLev's Avatar
    Sundance Mesa, NM
    I guess you could try tapping on the valve when it's open to try and bend it back. DON'T let the valve hit the valve seat in the head.
    At this point you've got nothing to lose.
    You can tell if you secede and the valve is closed tight by turning the head over (combustion chamber up) and filling it with alcohol. If it runs into the intake port you failed....new valve time.
  16. #141
    Jul 2013
    Worcester, MA
    clarify this statement, don't let the valve seat? isn't that the intention? or do you mean don't strike the valve such that it hits the valve seat as it flexes from the strike?
    also from where do i get or borrow a valve spring compressor, cw doesn't have one, and at this point i'd much rather just do the thing myself than have the indie do more of it
    literally just dropped another $77 on four intake valves and stem seals, i just want to drive my car again ;__;
    GN92489
  17. #142
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by joekitch View Post
    This, see your quote above.
    I used an old school valve spring compressor that wouldn't reach down into the pockets, had to make an extension on it with cutouts on the bottom sides to get the keepers out using a magnet.
  18. #143
    JimLev's Avatar
    Sundance Mesa, NM
    I can't take this "As The World Turns" soap opera any longer, when will the produce cancel this series, LOL.
    Joe, do you still need intake valves? How many, I have some good BMW ones.
  19. #144
    Jul 2013
    Worcester, MA
    never seen as the world turns, this feels more like an Always sunny in Philadelphia episode
    speaking of which, current mood;
    I rage-bought (is that a thing?) four intake valves and a valve stem seal kit last night from FCP which will get here like monday or something. $77
    GN92489
  20. #145
    Mar 2010
    Which hole are the bad intake valves on?
    My guess... #4?
    2003 M3CicM6 TiAg
    Former:
  21. #146
    Jul 2013
    Worcester, MA
    they're sort of spread around, that picture i showed earlier was from cylinder 3 i believe.
    tonight i'm going to more fully capture exactly which valves are showing light and how much
    GN92489
  22. #147
    Feb 2014
    Caboolture, Q, Australia
    E39 535i
    I hate to suggest it... But is the other bank worth investigating too?
  23. #148
    Jul 2013
    Worcester, MA
    Quote Originally Posted by StRaNgEdAyS View Post
    i'll be doing another compression test after bank 1 is on, since i have a baseline from before this mess happened (180psi on all cylinders except 3, give or take a few psi)
    GN92489
  24. #149
    Mar 2010
    got the engine timed, exhaust manifold bolted back on, intake manifold placed back on with the help of a forum member
    started to put bank two valve cover back on
    forgot to put the oil rails back on before doing so
    noticed the little valve grommets seemed to not be encountering much resistance which was weird
    heard a little cracking noise
    now i have a hairline crack in my freshly powder coated valve cover
    Attachment 621311
    Attachment 621312
    and the grommet nuts are stuck on the studs, which backed out with the nuts as i removed them
    Attachment 621317
    Attachment 621319
    the studs are 07129904544 and the nuts are 11121747162 according to real oem, thankfully both are cheap
    is it possible to repair that crack with some sealant?
    i'm hearing something called pro-seal, aka type B-2, can seal magnesium vc gaps
    https://www.aircraftspruce.com/pages...prosealant.php
    i'm really. really getting sick of this stupid car
    Joe you're missing parts.
    The studs go in the cam caps.
    Then the oil distribution rail drops onto them.
    Then top-nuts go on top of that.
    Only THEN do you put the valve cover on w/ grommets etc.
    When you do the top cap-nuts for the VC are designed to bottom out on the stack and not put tension on the cover.
    The "under-nuts" are critical (TWSS). If you omit the nuts (let alone the rail...) underneath, then indeed the VC nuts will go down too far and jam on the studs etc. etc. exactly what you saw happen.
    See below.
    It is not uncommon for the studs to back out when you remove the rail-nuts for sure, they usually thread right back in again though.
    BTW there should be no reason you can't remove those studs from the nuts - they don't look stripped... do you not know how to remove a stud with 2 plain nuts backed against each other?
    2003 M3CicM6 TiAg
    Former:
  25. #150
    JimLev's Avatar
    Sundance Mesa, NM
    Like I mentioned earlier...As The World Turns, the soap opera continues. Sorry Joe, had to say it.
    To fix that crack I'd use a drummel tool to make a small V groove on the cracks. Then get some MARINE JB Weld, not the regular JB stuff. The Marine stuff is good to 650F IIRC. AutoZone should have it.
    This is what I use when I patch up the imperfections on valve covers before I bake them after powder coating.
  1. P0021 After Timing Chain Guides + Vanos Rebuild
    By dannyzabolotny in forum 1996 - 2003 (E39)
    Last Post: 02-28-2018, 10:13 PM
  2. bmw 540i startup after timing chain guides and vanos seal
    By berkeleydojah in forum 1996 - 2003 (E39)
    Last Post: 02-26-2016, 06:23 PM
  3. M62 Engine Noise After Timing Chain Guides
    By Tibs01 in forum 1995 - 2001 (E38)
    Last Post: 04-20-2015, 05:39 PM
  4. VANOS stopped working after timing chain guide replacement
    By TheLadiesMan in forum 1995 - 2001 (E38)
    Last Post: 06-08-2014, 11:49 AM
  5. E39 M62TU code after Timing Chain Guide rebuild
    By BlackBMWs in forum 1996 - 2003 (E39)
    Last Post: 01-04-2012, 12:29 PM
