Hey all,
I just picked up a set of heated electric vader seats. i'm curious if anyone has done this swap into an e46 before (i've found chatter of it, but no write up about it).
after some quick googling; it seems then connectors are different and the passenger side occupancy sensor wire will need to be spliced into the seat connector, is this true?
Would I be able to just cut the harness connecter of my E46 seats, match the wires up and transfer the harness connector onto the vaders? Im not worried about any memory functions, just that all movement directions and the heat is functional.
I'm concerned the seats might trip the airbag light (i've read its run off the female belt receptacle), would i be able to just "spoof" the circuit or should i transfer the belt receptacle from the e46 seats on to the vaders?
Thanks for the input!
