Results 1 to 3 of 3
Thread: Raising the rev limiter on a ECU that has a EWS delete?
    Mar 2017
    Oslo, Norway
    E36 320i, E36 318TI
    Hello people! I own a 98' 318ti which has a M42B18. The car originally had a M44B19, but the previous owner swapped in a M42 because the M44 got rod knock. Since it has an "backdated" engine the car has a ecu which has a EWS delete.
    Now here comes my question: I want to raise the revlimiter to 7k by purchasing a performance chip. Will this chip mess with the EWS delete that my ecu currently has?
    Regards Marius
    Vancouver, BC Ca
    1993 325is
    As long as the new ECU also has EWS delete, you'll be fine. If the EWS delete is working correctly now, it'll work correctly with the new ECU - as long as the EWS delete is done to the new ECU.
    Oct 2003
    Seattle
    99 M3
    US cars have ‘flash’ ECU code, no ‘chips’ after 1995.
    New flash memory code will have to include EWS delete.
    Are you running OBDI ECU with a ‘chip’?
  1. Replies: 1
    Last Post: 02-11-2014, 09:34 PM
  2. Replies: 15
    Last Post: 11-07-2013, 03:43 PM
  3. Stock rev limit on the M52B25?
    By Le Nitro in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-03-2009, 09:49 PM
  4. whats the rev limit on my 328is??
    By jefiddler in forum 1991 - 1999 (E36)
    Last Post: 10-05-2004, 10:11 PM
  5. So whats the rev limit on a 328?
    By Stylin in forum 1991 - 1999 (E36)
    Last Post: 03-15-2001, 12:21 AM
