Stupid Question:
1999 M3 4 Channel ABS Pump
I relocated the ABS Pump in my 1999 M3 for the LS swap I'm slowly doing. I got the last line bent last night and realized I think I f@$%ed up. Can anyone tell me or post a picture of which line goes to which port from the Master Cylinder to the Pump? I had them marked when I took everything apart but with shots of brake fluid and brakleen hitting the marker ink, I think I got them backwards. Last night when I realized this, I looked and the master cylinder has an "H" embossed on one port and a "V" on the other one. I have the "H" going to the port closet to "HR" and "HL" and "V" to "VR" and "VL" respectively. Looking at any picture I can find online, it looks like I have them backwards.
Any help is appreciated.
Thanks.
The embossed marking is German language
H = Hinten = rear
V = Vorne = front
HR = Hinten Rechts = rear right
HL = Hinten Links = rear left
VR = Vorne Rechts = front right
VL = Vorne Links = front left
