Katit2 or Mykk - could really use your help on this, I've ordered the ADS cable but haven't received it yet and still need to find the right software.
Would you mind reading what the DME is reporting as running engine temp when your instrument cluster is showing 1/4 and 1/2 mark ?
This would help me tremendously as I am plotting e30 temp gauge (done) and the single pole 12 62 1 710 512 sending unit that e30 cars use to drive the cluster temp gauge. As you can imagine a little bit of calibration is in order as the e30 temp gauge and 512 sender wasn't really meant to be used with a hotter running M6x engines.
Just for reference, 1/2 mark on the e30 gauge cluster reads when the sender is at 46ohms. I used hot water and got 512 sender to 195F and thats 61 ohms. Tomorrow I'll use a digital infrared thermometer and do some more testing to validate my data.
So, what I really need is a good data point, running temperature that the DME is reporting when your e32/e34 cluster is showing at the 1/4 and 1/2 marks.
Hopefully this isn't too much to ask CRAP, I just realized Katit2 your screenshots are off 525 and not 540, so hoping Mykk got his hardware Or maybe someone else have this setup running and can report back running temps?
Cheers!
e30 84 340i m6x powered.
e34 89 535i 5speed - current DD
e24 89 635csi - maybe a DD?
e34 93 525i (m50tu) - gone
e39 540i 6spd m-sport - gone
e53 x5 4.4l - gone
e30 89 325i (m20) - gone
