Results 1 to 25 of 32
Thread: 295/35ZR18 tires rubbing
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    So I just installed a set of 295/35ZR18 rear tires on 8 series specific 10.5" wheels and unfortunately tires rub when hitting a bigger bumps on the freeway.
    They are not rubbing alot so I am thinking maybe roll the fenders slightly or just bite the bullet and go for 285/35ZR18?
    Wanted widest tires possible to gain more traction, close to 600 hp really lights up the 275/35 at virtually any speed below 60mph, and I do have an LSD.
    Dec 2012
    Carriere MS
    91 e31, 67 Camaro
    Quote Originally Posted by dragon850 View Post
    Rolled mine with a 1.5" wooden dowel, heated the paint in the area around it 1st. Little at a time.
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    I have used a baseball bat to roll fenders but maybe this cheap fender rolling tool would work: https://m.ebay.com/itm/Roll-Fender-R...kAAOSwjqVZCvOK
    Mar 2016
    Tyler, TX
    1992 E31 850i
    Even if you bump down one width, consider an alternative tire compound. On my twin turbo M70, I run 315/30/17 drag radials. DOT marked for inspections / street use. I can certainly still spin them if I desire, that car being half the weight of an E31 -- but doing so is more a display of poor driver control than inadequate traction! Of course, that car also never leaves the garage on other than on nice sunny days. I wouldn't want to drive those tires cold or wet, so it's not good advice for a daily driver, etc.
    Cheers, John
    May 2010
    Brentwood, NY
    BMW 850
    I wear 285s. Was toying with the idea of going bigger, but now I know. No 295s for me.
    I may research the tires with the best dry traction I can find.
    Sent from my SM-N950U using Tapatalk
    San Jose CA
    1991 850i S70 6 speed
    Depends on your suspension setup (how stiff they are) and which tire brand. I had same brand of tires that Dragon850 has on my 840ci with Blisters and Eibachs and no rubbing.
    But Yeah, don't risk it unless you have SC 850 and need extra traction.
    Quote Originally Posted by thelongeride View Post
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Tire widths are not consistent between manufacturers. Example: a 285 BF Goodrich will not rub on my stock 93, but a 285 KUHMO will rub all day long. Might want to stick with 285's, since you are only talking about 10mm increase in width. The HAMANN car that I saw in Germany a few years back, actually hade a 305 on it.
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Went with Michelin Pilot Sport A/S 3+, 285/35ZR18 Rear and same 245/40ZR18 Front.
    Toronto, Canada
    BMW 850CSi
    Why all-seasons? Wouldn’t a summer-only tire give better grip/control?
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by Dr. T View Post
    According to my research those all season tires outgrip 90% off summer only tires on dry.
    Jun 2015
    West Chester, PA
    BMWs:74 3.0 CS, 97 840Ci
    I also have the Michelin Pilot Sport A/S 3+ on 4 corners of 3 cars - 840, SL55, and A8. Love them in warmer weather, stick very well. I DON'T use them in snow. Heard from several people they are pathetic as snow tires. But they do grip very well when warm (drove the 840Ci up the TN side of Tail of the Dragon with these - very pleased with traction).
    Gary
    Gary Knox
    '97 BMW 840 Ci
    '03 MB SL55 AMG
    '07 Mini Cooper S hatchback
    '09 Aston Martin DB9 Volante
    '13 Audi A8
    '90 MB 560 SEC and '94 Porsche 928 GTS recently departed but long enjoyed
    50 or so others over the past 70 years of driving
    Wadsworth, Ohio
    BMW
    With the power levels you're running, good luck getting traction with anything less than sticky compounds in hot dry weather.
    and +1 to using a fender roller (LINK) and finisher (LINK) over a baseball bat, they make it a little easier not to wrinkle the fender.
    -James
    Las Vegas, NV
    1994 850CSi, 2007 M5
    I run 295/35 18s on my CSi, no rubbing at all. Looks fantastic and I love them!
    1994 850CSi, 2007 M5, 1990 VW Westy Syncro, 2010 e61 Touring Manual
    Iceland
    BMW 850
    Quote Originally Posted by Major Cheese View Post
    Pics?
    Las Vegas, NV
    Quote Originally Posted by Fatandre View Post
    Pics?
    Las Vegas, NV
    These are Racing Dynamics e31 specific wheels.
    Toronto, Canada
    BMW 850CSi
    What front size do you run? A little surprising how high the body is over the tire. With 285/35/18, mine is only roughly 1/4” above the tire....maybe it’s just the angle. Looks great.
    Sep 2010
    Finland
    bmw 850i M-tech
    What is the offset? With 295 you should be above et20.
    Nov 2013
    Whitney, TX
    97 850CI
    And they are amazing.
    Desecrator of all things Sacred
    Las Vegas, NV
    245/40/18
    Las Vegas, NV
    This article list the tire size for the Racing Dynamics K55. Sorry for the small print.
    Toronto, Canada
    BMW 850CSi
    What’s the offset on the RD wheels? Would the 295’s work with M-Parallels?
    Las Vegas, NV
    I don’t know the answer to either of your questions. Maybe someone else here can chime in?
    Greater Seattle Area
    '93 850Ci,'01 X5
    Important critical tip: Make sure you heat the paint before extensive fender rolling. Otherwise you'll crack the paint like I did.
    Here's some picts. 2011-09-17_18-01-25_199.jpg They're 315/35ZR-18 Michelin Pilot Sports.
    I'll look in my notes to see if I can find the offset, hell, it's been 7 years since I've done that.
    Iceland
    BMW 850
    Wow. This is super hot
  1. Replies: 8
    Last Post: 02-21-2005, 09:27 AM
  2. Will a 255/40/17 SO3 tire rub?
    By eurospec#19 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 10-01-2002, 08:30 PM
  3. Tire rubbing, what to do?
    By ele in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 05-25-2002, 02:33 AM
  4. Tires rubbing!
    By CJ in forum 1991 - 1999 (E36)
    Last Post: 04-08-2002, 02:46 AM
  5. Will 235/40/18 tires rub on stock height?
    By Ali in forum 1992 - 1999 M3 (E36)
    Last Post: 10-03-2001, 06:48 PM
