Thanks, I was wondering if anyone have done a replacement of these parts because no one replied after 68 views. Maybe I will take pics of the DIY. Thanks for the reply.
Originally Posted by
NevadaMike
I'm in the process of rebuilding my complete cooling system (water pump, radiator, belts tensioners, hoses, etc) so they might seem easy to get to with all that stuff removed, but to remove the bottom sensor the hydraulic pump must be loosened and moved, which has to be done from underneath the car. Also the harmonic balancer/toothed pulse wheel must be positioned so the slot in the wheel is over a bolt holding the wire from the bottom sensor so the wire can be removed.
A pretty good write-up of the procedure is here:
https://www.bimmerforums.com/forum/s...osition+sensor
Hurt
Current project working on the E31 rebuild.
1992 BMW 850i, 1995 E31 840ci, 2008 E90 M3, 2008 750Li
