Page 9 of 13 FirstFirst 12345678910111213 LastLast
Results 201 to 225 of 308
Thread: S85 V10 M Roadster
  1. #201
    Nov 2008
    Kelowna
    '99 M Roadster '08 135i
  2. #202
    Sep 2014
    The Netherlands
    E46 BMW 330/ Een BMW Z4
    Quote Originally Posted by Z3 M Roadster View Post
    The pictures are not available
    Sent from my MI MAX 3 using Tapatalk
  3. #203
    Aug 2017
    They show for me, even in your quote
  4. #204
    Sep 2014
    The Netherlands
    Quote Originally Posted by me77 View Post
    See attached
  5. #205
    Nov 2005
    Finland
    Z3 Coupe individual
    Use computer and browser. Not a what ever that MI MAX 3 and Tapatalk are.
    What pads did you end up using? What are those 3M stickys used?
    ps. I am going to remove anti squeal shims from rear as one of my rear brakes occasionally squeals but fronts dont and I did not install those into fronts.
    I am having brembo pads at front but oem porsche pads in rear, that difference might be also causing it.
    Z3 & E36 RamAir systems, send private message for more information.
  6. #206
    Nov 2008
    Kelowna
    I'm using Hawk ceramic, same type had on the car for the last 7 or 8 years. They were low dust as one would expect and quiet. The 3M are anti vibration pads, when I got the calipers both fronts and rears had them so I just pick up new ones.
    I've heard many Porsche owners complaining about brake noise, maybe it the pads? Other than some squealing how do you like the Brembo's and do you feel the braking has improved/reduced?
  7. #207
    Nov 2008
    Kelowna
    Does anyone have an S54 fuel pump assembly with a dead pump? fuel line connections and fuel level must be in good working order.
  8. #208
    Oct 2007
    VA
    00 Mshoe
    Jeremy might, I believe I just saw him post on FB about replacing his FP not too long ago.
  9. #209
    Nov 2008
    Kelowna
    Thanks Robb, I'll get in touch with him.
  10. #210
    Nov 2008
    Kelowna
    While working on the fuel system I've discoved that the fuel pumps from the M6 are a direct fit in the original S52 pump assembly and the electrical connector is the same as well. Unfortunately the M6 assembly does fit the Z fuel tank.
    20190311_164356.jpg20190311_164439.jpg20190311_164500.jpg20190311_164534.jpg20190311_164600.jpg
  11. #211
    Nov 2008
    Kelowna
    The larger front sway bar arrived today, going from a Dinan 22mm to an H&R 28mm. Both front and rear bars will be going out for powder coating shortly. The front bar and powerflex bushings are no longer needed...
  12. #212
    Nov 2008
    Kelowna
    After 20 years it was time to clean the fuel tank inside and out. I was surprised to see so little debris in the tank, after that long I expected more. I have most of the fuel system now, I just need the dual pump bracket and the tank can be installed.
  13. #213
    Nov 2008
    Kelowna
    The new fuel lines, filter etc. The blue lines had been sealed and sitting on the shelf in Germany for a long time, one says 1998 and the other says 2000.
  14. #214
    Oct 2007
    VA
    00 Mshoe
    One day I hope to be able to overhaul a car to this extent. Excellent work as always, Lars
  15. #215
    Fort Worth, TX
    E36M3/E46M3/E39M5/E63M6
    Awesome work.
    E36/8 2000 M Coupe Cosmos Black/Black
    Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein, AKG Subframe/Diff, UUC TME Red/Caps, Swapped Front Hats, Ice>Link.
  16. #216
    Nov 2008
    Kelowna
    Quote Originally Posted by robb1887 View Post
    Thanks Robb! I always wanted to do something like this too!!
    Quote Originally Posted by TexaZ3 View Post
    Awesome work.
    Thanks!
  17. #217
    Nov 2008
    Kelowna
    It was such a nice sunny day this past Sunday to work on the car. This is where the magic/voodoo happens aka wiring! I removed the canbus from the engine harness and did some repining. The SMG wiring needed to come out in favor of a 6 speed manual trans and I'm using a manual from an E90 which comes with a trans cooler that has to be added. After hours of work it sure doesn't look like you accomplished much... also the E90 trans harness has o2 sensors and these are not needed as the engine already has all the wiring for the o2's. The first photo showing o2 connectors, second with them removed and a little cleaner looking.
  18. #218
    Nov 2008
    Kelowna
  19. #219
    Kent, Ohio
    1998 M Roadster
    Which pin out tool is that, and how do you like it?
  20. #220
    Nov 2008
    Kelowna
    It's the Schwaben set. For the most part it does a good job but there are a couple styles of pins the tool isn't strong enough to release the locking tabs. There are simple workarounds for those.
  21. #221
    Im s54 swapping my e36 m3 right now and boy am I glad they make off the shelf wiring harness adapters! 😝
  22. #222
    Oct 2013
    Rock Hill, SC
    2000 BMW M Roadster
    So are ECUs adaptable enough that you can just disable all of the extra components that were on the M5 but won't be in the roadster?
    I know people do projects like this, but I've always been confused about how you could get a modern ECU to live happily in a 20 year old car.
  23. #223
    The DME controls the engine. Other modules control the car and chassis stuff. The difficulty in these swaps lies in:
    A) getting the chassis modules to talk to the DME
    B) deleting EWS (antitheft) and other extraneous systems from the M5 DME (like it wanting to talk to the SMG)
    The engine computer does not control the whole car
  24. #224
    Nov 2008
    Kelowna
    Quote Originally Posted by BimmerBreaker View Post
    Im s54 swapping my e36 m3 right now and boy am I glad they make off the shelf wiring harness adapters! 
    Graham, your so lucky! I sort of whish there was an S85 option for our cars. I guess if the was more may attempt this swap...
    Quote Originally Posted by pine1000 View Post
    What Graham said below.
    The DME for this swap will get;
    1. Canbus delete
    2. EWS delete
    3. RPM limiter delete
    4. O2 Readiness Override
    5. Cold Start Delete
    6. RPM Limiter Raised
    7. VANOS Adjustment Improvement
    And some coding +++
  25. #225
    How much bus can a canbus bus if a canbus can bus bus?
    these are the questions nobody is asking
    PRICE CUT on ALL FABRICS
  1. e39 M5 6speed gearbox working with an s85 V10?
    By lalaland in forum 2004-2010 (E60,E61)
    Last Post: 08-24-2010, 06:57 AM
  2. S85 V10 + Z3M = Win
    By T-Rex in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-15-2010, 10:43 PM
  3. S85 V10 E30 M3 vs. V8 E92 M3 (Vid)
    By jszy25 in forum BMW Rides & Events
    Last Post: 01-02-2010, 01:58 PM
  4. RUMOUR: Z4 M Coupe with S85 V10 (E60 M5) engine and SMG III gearbox.
    By gamelanman in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 03-11-2007, 10:42 PM
  5. Help Needed: S85 V10 Firing Order
    By Bimmerman535i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-01-2006, 09:51 PM
