Page 7 of 13 FirstFirst 12345678910111213 LastLast
Results 151 to 175 of 308
Thread: S85 V10 M Roadster
  1. #151
    San Diego, CA
    1999 BMW M Coupe
    Who is going to do the ECU tune for you?
    1999 M Coupe
  2. #152
    Nov 2008
    Kelowna
    '99 M Roadster '08 135i
    It will depend if I go with an alpha n or not.
  3. #153
    Nov 2008
    Kelowna
    I've made some progress withe the electrical but also had to remove a few more connectors and wiring from the M6 harness. Needed the vacuum pump for the brakes, what a pain in the ass that was! wiring going from the engine bay to the interior pass thru a rubber section that filled with butyl I understand why they did it but still... it wasn't long an that crap was all over me. I also got the trans mission harness installed.
    20180923_140337.jpg20180923_140309.jpg20180923_140320.jpg20180923_155508.jpg20181008_131131.jpg
  4. #154
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    Eh, close enough. Turn the key!
    Nathan in Denver
  5. #155
    SW Florida
    99-01 M Cpe & Rdts, X5M
    At what point did you realize that fabricating the headers and engine mounts was the easy part?
    Far cry from the early days of engine swaps, when all you needed was a hot wire to the coil, a screwdriver to short out the starter solenoid, and you were off down the road!
  6. #156
    SAN JOSE
    84 M635
    Quote Originally Posted by Z3 M Roadster View Post
    Just as a note from my tuner that is the head tech for Emtron USA... You don't want to run Alpha N for the street, its very unrefined for a well tuned street car.
  7. #157
    Mesa, Arizona
    2000 Z3 M-Roadster
    Quote Originally Posted by Randy Forbes View Post
    I remember those days quite well. My parents has a 68 Ford Comet wagon with the starter solenoid mounted on the firewall. One hot wire to the coil and a screwdriver was all I needed to start the engine
    Tony
    "You can't sign away negligence."
  8. #158
    Nov 2008
    Kelowna
    Quote Originally Posted by s8ilver View Post
    I tried but it didn't start...lol
    Actually Randy I gave the wiring a lot of thought before starting on the swap, like you said the headers and mounts are the easy part!
    No kidding, I remember helping my grandfather and my dad restore model T's and the flathead fords along with the Chryslers with 331/354 Hemi's. Honestly I'd be lost working on one now!
    Quote Originally Posted by Gatso7 View Post
    Thanks, that's seams to be consensus with most tuners I've talked to.
  9. #159
    Far Hills,NJ
    '00 Z3 2.3 Roady, '08 M5
    A far as running AlphaN goes, I had an Evolve AlphaN Tune on my E60 M5 with zero issues. I had the tune for about 3 years before I had a slight hiccup, but it involved the throttle application for the SMG. A simple email to them and they sent me an updated tune and all was well.
    indaily drove the car and the AlphaN Tune was night and day compared to stock. I had it paired with stock catless Headers and the Evolve Intakes. And then I had a set of long tube headers installed. Throttle response was probably the biggest difference. Hope this helps the previous discussion about AlphaN.
  10. #160
    Oct 2007
    VA
    00 Mshoe
    Bump for updates, been over a month!
  11. #161
    St. Petersburg, FL
    2020 M2C
    My Apha N tune runs great on my S54 street daily driver. I would not call it unrefined at all. Rather, I call it awesome.
    Bill
    2002 M Coupe. Steel Gray/Black.
  12. #162
    Nov 2008
    Kelowna
    Quote Originally Posted by dimm6 View Post
    Most of the guys I've talked to like the Alpha N and have no issues. Thanks for your input it does help, I have a plan...
    Quote Originally Posted by robb1887 View Post
    Hey Robb it has been a while! sadly I haven't had any timefor the car, work is stupid busy and thanks to daylight savings its dark when Iget home. Also working with wires/connectors when its cold is very difficult.So here's an update, the new tires arrived last week I've been torn between theMichelin PS2's and the Proxes R888R's. And the winner is...
    Quote Originally Posted by FINZ View Post
    I picked up a second DME, one will have a standard tune and the 2nd will be Alpha N. This way I can chose which is the best for this application.
  13. #163
    Sep 2017
    Northeast
    2001 M Roadster
    ... I've been torn between theMichelin PS2's and the Proxes R888R's. And the winner is...
    I must have missed it, but what wheel size are these Proxes are going on? What is you front and back tire and rim size? I am trying to get some rubbers for my new Apex rims that are wider then OE, but I don’t think I could stick 315 in the back. Thus I went with 10.5 rim in the back. I think proper size for that is 285-295.
  14. #164
    SW Florida
    Smart move on the DME, I always try to get a 2nd DME to put supercharger tunes in.
    Those tires, when both are mounted on the car, do they leave enough gap between them for the differential?!?!
  15. #165
    Oct 2007
    VA
    00 Mshoe
    This hits too close to home... Trying to fit a 06 Tundra V8 into my 97 4Runner.
    The sun gets down before I get home too
  16. #166
    Nov 2008
    Kelowna
    Quote Originally Posted by DimrBimmer View Post
    You didn't miss it I forgot to mention it, they are on 11" Apex EC-7 on the fronts its 9" with 255 35's. The wheels in my signature 255 35/18 on 9.5's and 295 30/18 on a 10.5
    Well I'm hoping the diff will tuck inside the barrels looking something like this
    Its good to see you're still working on the Toyota project!
  17. #167
    Aug 2016
    Fort Worth Texas
    1998 BMW Z3 Roadster
    I want to make my 1.9 4 pot into a 5.0 10 pot now... This is going to be one heck of a ride good sir. Following to see the final product!
  18. #168
    Nov 2008
    Kelowna
    Well I had some time after work yesterday to strip down the half shafts, figured while they were off the car it would be a good time to inspect and replace the boots since they are the original 19 year old ones!
    20181201_125414.jpg20181201_114026.jpg20181201_125411.jpg20181202_140758.jpg20181202_140731.jpg
  19. #169
    SW Florida
    Unquestionably the dirtiest job on our cars!
    I keep a couple of inner/outer boot kits on hand, in case I come across a torn one__but I hope they dry-rot on the shelf
  20. #170
    Jul 2005
    Temecula Ca.
    99 M Coupe LS Swap
    Do not take a short cut and use a mallet to hammer the shaft back into the splined TA race. I took my new rebuilt shaft over to BMW and had a "Tech" install for me since I do not have the BMW tool to correctly pull the shaft into place. He took the short cut unknown to me the first time and damaged the CV just enough that it pulled the differential output flange out of position when at speed. It would not pull out the flange unless I was at high speed. I thought I just got a bad rebuild till I went in the second time and observed how he was intending to "install the shaft. Use the correct BMW tool or you my not like the results.
    Dan "PbFut" Rose
  21. #171
    Nov 2008
    Kelowna
    You got that right Randy!! WellI hope these ones last another 19 years...
    Somehow I don't think you'll get that lucky
    Quote Originally Posted by PbFut View Post
    You bring up a good point! I cant believe someone wouldhammer them back in and at BMW?? he's not a professional that's for sure butthat's just my opinion. How did you remove them? I bolted up a tool to the huband pressed mine out and they were very tight (attached photo). That got me thinking well howdoes BMW install them and like you said there is a tool for doing just that, itpulls the shaft back in place without damage. After doing some research I foundthat can buy a non-OEM tool from Bavauto for $70 but they are currently out ofstock. I'm not in a rush so its not a big deal, others sell a similar tool butthe price is between $300 and $400.
  22. #172
    Oct 2013
    Rock Hill, SC
    2000 BMW M Roadster
    Here's an article about installing the rear axles on BMWs and Porsches: http://www.rtsauto.com/re-installing...w-porsche-etc/
    I think the only "proper way" is to use the tool. However, I tapped around the perimeter of the CV housing on mine to get it just far enough in so that a new axle nut put on backwards could grab some thread. Then I used some big vice grips to turn the nut. I was able to draw the axle into the hub the rest of the way using this technique.
  23. #173
    SW Florida
    This is the mandrel used to pull them in...
    ... and in use
    While we're on the subject, this is a 4:1 torque multiplier; I only have to pull 75Nm to achieve 300Nm at the nut/axle joint.
  24. #174
    Nov 2008
    Kelowna
    Quote Originally Posted by pine1000 View Post
    Thanks for the link I checked it out on my lunch break.
    ... and in use
    I like the OE tools Randy I've only seen the BMW drawings for them, the look robust! would you mind sharing the part numbers?
  25. #175
    Aug 2015
    Denver, CO
    I need one of those!
    I could've definitely used one a few years ago. I was reinstalling the massive front axles on my old S8 and the manual called for 250 ft-lb + half turn IIRC. I got the 250 part done, but the half turn was more about an 1/8. My 30" breaker bar felt like it was about to snap, so I put some paint marks on the hub and bolt and called it good. Checked a month later, nothing had budged. After two years, I quit worrying.
    Did a pitman arm on an F250 not too long ago...nut torque required was something stupid like 350ft-lb. We got creative with a breaker bar and long piece of spare roll cage tube.
    Nathan in Denver
  1. e39 M5 6speed gearbox working with an s85 V10?
    By lalaland in forum 2004-2010 (E60,E61)
    Last Post: 08-24-2010, 06:57 AM
  2. S85 V10 + Z3M = Win
    By T-Rex in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-15-2010, 10:43 PM
  3. S85 V10 E30 M3 vs. V8 E92 M3 (Vid)
    By jszy25 in forum BMW Rides & Events
    Last Post: 01-02-2010, 01:58 PM
  4. RUMOUR: Z4 M Coupe with S85 V10 (E60 M5) engine and SMG III gearbox.
    By gamelanman in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 03-11-2007, 10:42 PM
  5. Help Needed: S85 V10 Firing Order
    By Bimmerman535i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-01-2006, 09:51 PM
