Page 2 of 13 FirstFirst 123456789101112 ... LastLast
Results 26 to 50 of 308
Thread: S85 V10 M Roadster
  1. #26
    Jun 2016
    Odessa, TX
    2000 BMW Z3 2.8 Roadster
    https://vorshlag-store.com/collectio...shaft-assembly
    Would this be of use? I don't know if you've seen it yet.
  2. #27
    Nov 2008
    Kelowna
    '99 M Roadster '08 135i
    Thanks, I've looked at using that shaft but I'm waiting to see what the my fabricator thinks.
  3. #28
    Nov 2008
    Kelowna
    I picked up these front and rear 2 piece ECS rotors to go the Porsche 996 calipers.
  4. #29
    Nov 2008
    Kelowna
    Also decided while the front end is apart I would replace the hubs as a PM thing.
  5. #30
    Aug 2014
    kentucky
    '98 Z3 M Roadster
    Can you make a post about your 996 calipers when you get it all together., and what you think about the feel of it. I've been thinking about doing this.
    Built S52 w/Dinan ISR-3 kit, NickG Stage 2+ Tune, Dinan Vortech V2 Supercharger, Dinan Air to Air Intercooler, Dinan CAI, Porsche 803 HFM, Buldogge 6" crank pulley, Griptec 2.90" blower pulley, Eurosport UD pulleys, Dinan 3.38 Diff, Dinan front/rear Swaybars, Dinan springs, Koni Yellow Sport Struts, Ground Control end links, South Bend Clutch Stage 3 Organic, AASCO Light Weight Flywheel 18.5#, Zionsville Radiator & Oil Cooler, Riot Racing BBTB, Schrick Intake Manifold, 42# Injectors, Schrick cams 264/256, Forged Wiseco pistons 9.0 comp., Forged Eagle rods, Supertech dual valve springs & valves, VAC crank & bearings, Supersprint mufflers, Euro Z3 midpipe, Raceland euro headers, Walbro 255, Bevauto ignition coils, Vortech Mondo bypass, Bailey Diverter DV30, Ireland Rear Subframe Bushings, Mason Engineering Strut Brace, Mason Engineering Clutch Petal, Apex 18" EC-7 Wheels, Full Custom Sound System, two trunk lids (with & without OE spoiler), Hardtop, Trunk full of AK's...
  6. #31
    Nov 2008
    Kelowna
    Sure but winter will have to end first! We've have about 10" of the white stuff over the last couple days.
  7. #32
    Nov 2008
    Kelowna
    So here are a few shots of the initial fitting of this beast! you can see how it really fills the engine bay, but surprisingly its not to bad for access. With the exhaust removed this engine is about 27" wide, evening getting to the exhaust bolts isn't bad due to how low they are on the engine. The ABS unit had to be relocated as the brake lines were touching the valve cover, so to get the engine all the way back I had to unbolt it and push is over. luckily there is plenty of room just under the brake booster.
  8. #33
    Nov 2008
    Kelowna
    Since I wanted to keep the original feel of the car the SMG trans was not kept and a 6 speed manual trans was acquired, this also meant a new flywheel and twin disc clutch were needed.
  9. #34
    Feb 2013
    Canada
    2004 Z4R 06&12 Cooper S
    This build is what dreams are made of.
    Well done sir. Small car, big engine is the age old meaning of hotrodding. Albeit with a modern flare.
    Looking forward to the epic driving vids
    04R 3l 6 sp VF SC, custom ducting, alphaN, 2.62 pulley, multiport WMI,Severn Tuning(Pokeybritches), Tial BPV,Ceramic header, magnaflow section 1, SS race muffler/y-pipe, megan mounts,42 design catch can, CDV delete ,custom strut bar,3.91 LSD, H&R bars, Hotchkis links.Eibach Pro Kit,Koni Yellows.Megan camber arms. Carbon interior,SSK,UUC lines.CF aero. Poly bushings.
  10. #35
    Jul 2004
    Houston, TX
    36 Cylinders
    How are you dealing with immobilizer, cas, cluster? Or you are moving all of that to the Z3?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  11. #36
    Jul 2004
    Houston, TX
    36 Cylinders
    Are you going to take it up to 212mph like that one other Z3M rally car with S85?
    -Abel
  12. #37
    Nov 2008
    Kelowna
    Thank you.
    I'm looking forward to making the videos
    I might move it to the Z but there are other options and I'll post more about that in a while.
    The plan is to try for 200+ and see how that goes... who knows may even go FI.
  13. #38
    Wadsworth, Ohio
    BMW
    You officially have my attention, subscribe for more awesome updates.
  14. #39
    Washington, D.C.
    S54 e36/8; Tesla MY LR5
    Finally, proof estoril is the fastest color.
  15. #40
    Quote Originally Posted by fmcfad01 View Post
    Interesting. I looked at it as proof that estoril was so slow that you had to swap in a V10 just to keep up with the other colors
    PRICE CUT on ALL FABRICS
  16. #41
    Mesa, Arizona
    2000 Z3 M-Roadster
    Quote Originally Posted by BimmerBreaker View Post
    Ha!
    Tony
    "You can't sign away negligence."
  17. #42
    Nov 2008
    Kelowna
    Graham I think you have it backwards, fmcfad01 has it correct
  18. #43
    Mar 2010
    west
    ModelS;CayenneD;M5;MCx2
    Damn... this is gonna tear that chassis apart... I'd suggest plenty of gussets :-)
    Best of luck!!!
    Patrick
  19. #44
    Washington, D.C.
    Lol, I was pretty sure I had it right.
  20. #45
    Nov 2008
    Kelowna
    Best of luck!!!
    Patrick
    Thanks Patrick. I sure hope it doesn't tear itself apart...LOL
    There was never doubt!!!
  21. #46
    Oct 2007
    VA
    00 Mshoe
    You finally posted this! (although I'm late to the party, I don't surf much anymore!)
    Very excited to see how this comes together!
  22. #47
    Jan 2014
    Bend, OR
    2004 Porsche CTT
    This will be exciting to see and hear the finished car ... I hope you do an in cabin video on the open road. That would be inspirational.
  23. #48
    Nov 2008
    Kelowna
    I know, it took a long time! I was also unsure how I wanted to start the thread.
    I'm pretty excited as well! The plan is to head out to the prairies and take some videos on those straight roads that go forever...
  24. #49
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by Z3 M Roadster View Post
    I had made plans to convert an E46 wagon to diesel with a euro engine, and for the longest time wanted to make a thread: "Help! I mistakenly put diesel in my tank, and started the car."
    "Help! I got a 212mph ticket in my Z3, after overrevving my engine to 9000.."
    -Abel
  25. #50
    Nov 2008
    Kelowna
    That's a fantastic way to start a thread, you should have saved it!
    That's priceless! followed by "please send donations to my bail fund"
  1. e39 M5 6speed gearbox working with an s85 V10?
    By lalaland in forum 2004-2010 (E60,E61)
    Last Post: 08-24-2010, 06:57 AM
  2. S85 V10 + Z3M = Win
    By T-Rex in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-15-2010, 10:43 PM
  3. S85 V10 E30 M3 vs. V8 E92 M3 (Vid)
    By jszy25 in forum BMW Rides & Events
    Last Post: 01-02-2010, 01:58 PM
  4. RUMOUR: Z4 M Coupe with S85 V10 (E60 M5) engine and SMG III gearbox.
    By gamelanman in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 03-11-2007, 10:42 PM
  5. Help Needed: S85 V10 Firing Order
    By Bimmerman535i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-01-2006, 09:51 PM
