Page 10 of 13 FirstFirst 12345678910111213 LastLast
Results 226 to 250 of 308
Thread: S85 V10 M Roadster
  1. #226
    Nov 2008
    Kelowna
    '99 M Roadster '08 135i
    roflmao!!!
  2. #227
    Oct 2007
    VA
    00 Mshoe
    Quote Originally Posted by BimmerBreaker View Post
    How much bus can a canbus bus if a canbus can bus bus?
    these are the questions nobody is asking
    A canbus can't bus bus becuase the canbus was bussed to the can....
  3. #228
    Nov 2008
    Kelowna
    The new brake lines arrived this week, apperently you have to bend them yourself! good thing i saved the originals.
  4. #229
    Fort Worth, TX
    E36M3/E46M3/E39M5/E63M6
    Umm - what? Why?
    E36/8 2000 M Coupe Cosmos Black/Black
    Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein, AKG Subframe/Diff, UUC TME Red/Caps, Swapped Front Hats, Ice>Link.
  5. #230
    Pretty standard. Would be hard to ship if pre-bent
    What tool do you use for bending them? Need to do the same myself soon
    PRICE CUT on ALL FABRICS
  6. #231
    Nov 2008
    Kelowna
    Quote Originally Posted by TexaZ3 View Post
    Umm - what? Why?
    Well during the summer moths they sealcoat the highways (asphalt mixed with water is sprayed on the road and a layer of sand is applied on top, filling the cracks. Its a winter thing) The original owner drove over this hot mess an by doing that coated the entire underside of the car. When I removed the mess with solvent soaked rags, the sand remove part of the protective coating on the brake lines very much like sand paper.
    Your right, after I looked at the photos again the light bulb above my head came on...
    I've got a few benders, I'll dig them out and let you know what works best.
  7. #232
    Nov 2008
    Kelowna
    The new TC kline DA's arrived.
  8. #233
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Quote Originally Posted by Z3 M Roadster View Post
    My favorite! I wonder how many of their sets I've installed over the years...?
  9. #234
    boston,ma
    Hi Randy - I tried to message you through bimmerforums to get information on the z3 subframe issue. Is there a best way to contact you? I am an owner of a 2001 z3. Thanks!
  10. #235
    Nov 2008
    Kelowna
    Quote Originally Posted by Randy Forbes View Post
    I'll bet more than anyone else
    I figured it was time to upgrade from the SA's which were absolutely great! but for this build I needed that extra adjustment to dial the car in. I almost joined the JRZ group by but opted to stay with TC. I'm curious is anyone running the JRZ's and what their thoughts are?
  11. #236
    Nov 2008
    Kelowna
    This past weekend a lot was accomplished, mounted the expansion tank and installed vent pipes. Unfortunately since I have the tank mounted on the opposite side of the strut tower from the M6 I'll have to pick up more of the plastic line to make the connections.
    The M6 puller fan is installed along with the wiring that goes to it. The wiring is crazy big and is connected to a 100 amp fuse!! you can see the standard wiring compared to the fan wires. Most of the DME wiring is labeled and ready to run where it needs to go, luckily the M6 harness has more than what's need and several feet will be trimmed.
    20190504_143444.jpg20190505_141345.jpg20190504_143547.jpg20190506_171223.jpg20190506_182830.jpg
  12. #237
    Oct 2007
    VA
    00 Mshoe
    Is that a standard Z3 radiator? How's the shroud fit from the M6? In been looking at doing a custom shroud... But if it fits direct and just needs some wiring why reinvent the wheel.
  13. #238
    Nov 2008
    Kelowna
    No its the M6 rad with custom mounts, that would be nice if it fit the z3 rad. I do have the original rad from the roady, I'll see how it fits.
  14. #239
    Nov 2008
    Kelowna
    Well it’s been a productive weekend, the box for the DME isinstalled along with some of the wiring. I removed the glovebox and all themodules to access the opening in the firewall, got the wiring routed into thecar and ran the wires to where the need to go. Now all the wiring can be wrappedand routed.
    I also finished off the rad with a cover which gives it amuch cleaner look.
    20190511_113234.jpg20190511_181159.jpg20190512_130824.jpg20190512_131251.jpg20190512_145033.jpg
  15. #240
    Nov 2008
    Kelowna
    Quote Originally Posted by robb1887 View Post
    Robb, the M6 fan shroud does not fit the original rad for our car.
  16. #241
    Oct 2007
    VA
    00 Mshoe
    Unfortunate, but figured.
    I don't know if you've looked into it or need it, but there is a few OEM pieces that the euro coolant expansion tank mounts to in the area you are putting that connection box. If you've already mounted it you might not need it anymore, but it may give you more options for secure mounting. I think I had the PN's in my Euro cooling conversion thread from a few years back.
  17. #242
    Oct 2007
    VA
    00 Mshoe
    Thread: https://www.bimmerforums.com/forum/s...-helpful-hints
    Has some extra photos, and PNs but here's the short list
    "Body bracket 1- 41112491298
    Body bracket 3- 51712490388 "
    Body bracket 2 you dont need as its specific to the expansion tank conversion.
    Bracket 1 DOES required to be welded to the tower
  18. #243
    Nov 2008
    Kelowna
    I actually looked at using the euro that you installed and the remote expansion that the other z's use but since I had all these pieces from the donor, it just made more sense to use what I had. For mounting brackets I went to a local auto wrecker and found a bunch of them (about 20) for like $5... with a some test fitting and a little reshaping voila I had factory looking mounting brackets. I must admit that I got the idea after looking at you and others had done using the correct OEM brackets for your installs, it just looks clean.
  19. #244
    Oct 2016
    Ambler, PA
    2000 BMW Z3 Coupe
    Can’t wait to see this build finished. I had the pleasure of driving this M6 earlier this week, can only imagine how that engine would feel in my clownshoe
  20. #245
    Indianapolis
    F30 328d X-Drive
    Any updates?
    1995 Mazda RX-7 Feed Widebody LS3 6-speed (Toy, project)
    2010 Cadillac Escalade Luxury (Daily, Pulls my 18' car hauler)
    2014 BMW 328d XDrive (Wife's Daily)
    Have owned 4 other BWM's I no longer have.
  21. #246
    Nov 2008
    Kelowna
    Holy Crap its been a while!
    Yes there is a few updates, finished shaping and installing the vent lines to the expansion tank.
    Installed the engine and steering oil coolers. Had to make new lines for the engine oil cooler and modify the M6 power steering lines.
    Mounted the oil filter housing.
    I've bee working on fitting the vacuum pimp and lines.
    Much of the wiring is done. What else am I missing... oh yeah the engine cranks over! no fuel or spark, fuses have been pulled.
  22. #247
    Indianapolis
    F30 328d X-Drive
    Very cool! sounds like you are getting pretty close! I was just at an event that my buddy with his Z3 M coupe was at, and I was telling him about your swap.
  23. #248
    Jul 2005
    Temecula Ca.
    99 M Coupe LS Swap
    How'd you get the shoehorn out once the engine was in?
    Very nice looking work!
    Dan "PbFut" Rose
  24. #249
    Nov 2008
    Kelowna
    Quote Originally Posted by Venom13132 View Post
    Kind of close... After its running everything has to come out so I can repair where the OE brackets were removed and new brackets welded, scratches etc. so it can be painted to match the body.
    Quote Originally Posted by PbFut View Post
    It wasn't too bad, Thor just happened to be passing by
  25. #250
    Oct 2014
    Mesa AZ
    2000 740iL
    This is awesome. Thanks for paving the way on s85 stuff. Guess now I have to start keeping an eye out for a drivetrain
  1. e39 M5 6speed gearbox working with an s85 V10?
    By lalaland in forum 2004-2010 (E60,E61)
    Last Post: 08-24-2010, 06:57 AM
  2. S85 V10 + Z3M = Win
    By T-Rex in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-15-2010, 10:43 PM
  3. S85 V10 E30 M3 vs. V8 E92 M3 (Vid)
    By jszy25 in forum BMW Rides & Events
    Last Post: 01-02-2010, 01:58 PM
  4. RUMOUR: Z4 M Coupe with S85 V10 (E60 M5) engine and SMG III gearbox.
    By gamelanman in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 03-11-2007, 10:42 PM
  5. Help Needed: S85 V10 Firing Order
    By Bimmerman535i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-01-2006, 09:51 PM
