Results 1 to 5 of 5
Thread: 1999 Z3, 2.8 (Yes! 2.8) ABS Module replacement do not fit!
    Dec 2017
    Cincinnati, OH
    1999, Z3
    Long story; Wife went to BMW dealer in 1999 and ordered a loaded Z3 with standard engine 2.3. Years later, I took it to dealership and they said why does a 2.3 have a 2.8 under the hood? The engine sticker agrees. Now we need to replace the ABS module and pump. Cannot find the correct arrangement. The ECU harness is smaller than the replacements. and the module has two extra holes the mechanic (BMW) doesn't even recognize. This thing is a real FUBAR. Any suggestions? I really just want to find a junk yard unit and swap but, this is a night mare. ECU rebuilding is a more expensive.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to Z3 forum
    SF Bay Area, CA
    BMWs: 1; MINIs: 1
    Are you sure it's not a '98 2.8 and not a '99 2.8? They have different engines ('98: M52, '99: M52tu) and different ECUs, which might explain your confusion.
    Show us a photo of your engine, we'll figure it out. Also your VIN might help.
    I like the unicorns.
    '99 Z3 Coupe - Jet Black/Black (1-of-114)
    '99 M Coupe - Estoril Blue/Black (1-of-82)
    '03 540iT - Sterling Gray/Black (1-of-24)
    '16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    Have you checked to see if module master in Idaho can repair your abs module. They a notorious for cracking solder traces. MUCH cheaper than replacement.
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    Put the last 7 of your VIN into http://realoem.com and you will get the real information about your car based on your VIN. You can even get the BMW part number for the ABS Module which should fit your car.
  1. ABS Module replacement (540it)
    By BlackBMWs in forum E39 Common Problems and DIY Fixes
    Last Post: 10-13-2022, 02:29 PM
  2. abs module replacement & bleeding
    By tgburnett in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-27-2012, 12:21 AM
  3. ABS Module replacement help
    By purplecty in forum 1995 - 2001 (E38)
    Last Post: 07-29-2011, 05:07 PM
  4. Remove ABS module to do a diagnostic?
    By Mordan in forum Diagnostic Software
    Last Post: 01-08-2011, 01:21 PM
  5. E36 ABS Module replacement.
    By vinax in forum 1991 - 1999 (E36)
    Last Post: 10-24-2006, 08:47 PM
