Long story; Wife went to BMW dealer in 1999 and ordered a loaded Z3 with standard engine 2.3. Years later, I took it to dealership and they said why does a 2.3 have a 2.8 under the hood? The engine sticker agrees. Now we need to replace the ABS module and pump. Cannot find the correct arrangement. The ECU harness is smaller than the replacements. and the module has two extra holes the mechanic (BMW) doesn't even recognize. This thing is a real FUBAR. Any suggestions? I really just want to find a junk yard unit and swap but, this is a night mare. ECU rebuilding is a more expensive.
moved to Z3 forum
Are you sure it's not a '98 2.8 and not a '99 2.8? They have different engines ('98: M52, '99: M52tu) and different ECUs, which might explain your confusion.
Show us a photo of your engine, we'll figure it out. Also your VIN might help.
I like the unicorns.
'99 Z3 Coupe - Jet Black/Black (1-of-114)
'99 M Coupe - Estoril Blue/Black (1-of-82)
'03 540iT - Sterling Gray/Black (1-of-24)
'16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
Have you checked to see if module master in Idaho can repair your abs module. They a notorious for cracking solder traces. MUCH cheaper than replacement.
Put the last 7 of your VIN into http://realoem.com and you will get the real information about your car based on your VIN. You can even get the BMW part number for the ABS Module which should fit your car.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
