Decided to start a thread on my build as I’m sure many have. It will be a lengthy build and I’ll try to keep the post updated when progress is made. Feel free to ask any questions and or add some input!
1997 E36 M3 Sedan
LM7 Iron Block 5.3
K1 Technology Forged Crank
K1 Technology H-Beam Rods
Wiseco Forged Pistons
TMS 243 Heads Ported and Polish
ARP Engine Stud Kit
Vorschlag Motor Mounts
Custom Turbo Exhaust
Silky Engine Management Harness
80mm ball bearing turbo
Twin waste gates
TH400 with Monster transmission SS Kit
High rise tagged manifold
102mm throttle body
F-Body pulley kit
Twin Walbro 450s
Chase Bays booster/ABS delete
Tick Performance Stage 3 Turbo Cam
Plus some other little odds and end parts!
Sounds like a solid build. any thoughts on a 4L80 over the TH400?
I'm curious about your answer to this one too.
I went from a 200r4 to a Th400 in a single turbo SBC g-body but swapped gears from 3.70 to 3.08 at the same time. The car felt like it accelerated much better but I don't have any data to back that up and there's more factors that changed besides just gear ratios; torque converter, for instance.
I can see advantages to both transmissions. Has anyone managed to squeeze either trans in an e36 yet?
Sent from my iPhone using Tapatalk Pro
