Results 1 to 5 of 5
    Sep 2017
    Boise, Idaho
    2001 BMW X5 E53 3.0i.
    SIDE SEAL LEAK (front differential) AFTER REMOVING CV AXLE (front/right)?
    Thank you all ahead of time for your help!
    THE PROBLEM: (pictures attached)
    Removed the front, passenger side cv axle (to replace) which came out wet and some fluid came out of the hole. (waiting to replace the driver side until after I get an answer here)
    THE QUESTION: Is it normal for fluid to be leaking like that after removing the shaft (and the shaft wet)? If not what do I need to do to fix it? What are the implications on damage? Do I need to be concerned about the diff/transmission?
    THE WHAT:
    2001 BMW X5
    Chassis: E53
    Transmission: a5f390r
    Again, thank you!
    Oct 2017
    Albuquerque
    '05 X5 4.4i & '08 X3 3.0
    Cool It's normal
    That is normal when you remove the axle. The fluid level in the diff is above the lowest point of the axle seal so some runs out. Make sure to refill the diff to make up for any lost fluid when the axle is replaced.
    AceEngineer
    Sep 2017
    Boise, Idaho
    Thank you, AceEngineer.
    That takes off some anxiety. In other vehicles, when I did this, if it was leaking it was a big problem.
    As a follow up:
    1. Should I just replace the fluid instead of topping off?
    2. Have you had problems popping the circlip? I have tried (bent a few pry bars of different types) getting the driver's side to pop off. That axle will not come out for the life of me and have spent a couple of days trying different ways.
    Thank you for your time.
    Popping the axles out can be difficult. BMW makes a special tool for it. But since you don't have it, prybars are about the only other way. It's a real pain sometimes.
    Sep 2017
    Boise, Idaho
    Thank you, White94RX!
    at least I know it's not abnormal and that I am not going crazy. Well actually I am, these "simple" repairs have gone on too long. Tomorrow I will try something new that I think will work.
    Thanks again for all of your help everyone!
  1. Differential seal leaking!!
    By rf900rkw in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-27-2015, 07:34 AM
  2. WTB/Rent Front Differential Bushing Removal Tool
    By apexilude in forum E34 Classifieds (closing soon)
    Last Post: 07-16-2013, 09:42 AM
  3. Solutions to seal bolt-in rollbar holes after removal
    By Krank in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-25-2009, 05:39 PM
  4. leaking differential after storage...
    By crotter in forum 1992 - 1999 M3 (E36)
    Last Post: 11-06-2006, 12:21 AM
  5. Front Seals Leak
    By KBMW222 in forum 1983 - 1991 (E30)
    Last Post: 02-09-2004, 09:52 PM
