Results 1 to 2 of 2
Thread: Which Clutch Kit fits 1997 e36 318i
    Sep 2017
    Brentwood, ca
    1997 BMW 318i
    I am looking to replace my clutch, it is starting to slip, when shifting gears it tends to rev up high, then drop and then catch gear. Not happening all the time, but last night it was pretty noticeable in all the gears. So looking online and seeing basic kit parts at pelican for about $220 or so. This is just a basic kit. Any recommendations by others on what to get?
    Not sure what all I will need probably untill torn apart to really look I am thinking.
    Sent from my Nexus 5X using Tapatalk
    Oct 2003
    Seattle
    99 M3
    Pressure plate, clutch disk, throw out bearing, pivot pin, release arm spring, pilot bearing.
    Hopefully, your flywheel is reusable, but you may need to replace it also.
    Use the last seven characters of your VIN to look at the clutch parts diagram in realoem.com to get an idea of what you are looking at.
  1. Sachs K70206-01 Clutch Kit, fits E39, E36, and others - No Longer Available
    By E39InHockeytown in forum Drivetrain & Transmission Parts
    Last Post: 11-10-2016, 02:12 PM
  2. E36 NYC 1997 E36 318i with S52 swap m3 everything and lots of goodies
    By nuport in forum 3 series & Z Series
    Last Post: 02-27-2012, 04:12 PM
  3. E36 FS: E30 Turbo Kit fitted on e36 motor. "803", 42lbs.
    By Majjic1 in forum Race Cars & Track Parts
    Last Post: 10-31-2010, 04:25 PM
  4. Which clutch kit do you guys recommend for a first stick car?
    By always legit in forum 1992 - 1999 M3 (E36)
    Last Post: 09-10-2004, 02:29 PM
  5. Would M3 Door moldings fit my E36 318is?
    By BMW318iS in forum 1991 - 1999 (E36)
    Last Post: 03-01-2003, 04:10 PM
