Page 2 of 5 FirstFirst 12345 LastLast
Results 26 to 50 of 120
Thread: Beginners Cheap Turbo Setup Help
  1. #26
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by Substance D View Post
    That was a very sensible thing to say. I respectfully disagreed with you earlier, before you started talking smack about my setup and my tune. The kid was already going to do rods, you were talking him out of it, I was just adding my perspective to the mix by posting that pic. Thats as far I was going to go. We can agree to disagree. However, I think we can all agree, it starts at 350, and then you want 400, 450, 550, 700....
    Thanks for reminding me why I love BF/FI
    I never talked smack about your setup. I have no idea what it is. All I was saying is 350-400 HP is not enough to bend rods. Your car at the time of failure had issues like all cars that fail. Anything can happen at any time to anyone. But it wasn't the power that bent or twisted the rods.
    I advised him from the rods that he was going to buy for 1 simple reason and I will use his words "very tight budget".
    So, I would hate to see him yank the motor, prolong the build, and put the money into rods that will be fine in HIS case scenario. It costs much more than the $500 to change rods. That's $500+ that could go towards data logging, maybe a better turbo or whatever. It would be like spending $5000 on 32 way adjustable crazy coilovers for a street car that isn't racing in anyway. That money can be wisely spent elsewhere that will help keep things together long term. Personally, I feel data logging with failsafes and or properly tuned standalone system is best INS.
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  2. #27
    Jun 2012
    Socal
    turbo e36
    Its all good in the hood dude. Miscommunication.
    Lets resume topic.
    Vanos good for street car.
  3. #28
    Manchester, N.H.
    96 332IS 6466 turbo
    Even better idea.. Buy one already to go. Like this.
    1996 332IS
    Built 3.2
  4. #29
    Nov 2016
    Central Indiana
    1998 BMW 328is
    I asked this earlier this earlier, but I think it was kinda buried in my response, but here are the questions. Should I be getting the head milled and resurfaced along with new valve seals before the cut ring head gasket and boost? and also can I be boosting on a stock ecu or should I just get a megasquirt? Thanks!
  5. #30
    Jun 2012
    Socal
    turbo e36
    Quote Originally Posted by finsky View Post
    SHUT UP FINSKY THIS ISNT ABOUT YOU! And anothering thing....
    Just kidding.
    You should get the head prepped for boost. Some one told me you dont need to machine the head at all for cut-ring gasket. I dont know if I believe them.
  6. #31
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I always have the head checked and decked. Now that these motors are all 20 years old, its a good opportunity for a shop to change stem seals, check for worn guides, nicked or bent valves, seat condition, etc. To me, its not worth doing a headjob twice and buying an expensive gasket again.
    I would get a stock ECU tune. A good tune is very flexible. I have had the same tune since 2009, and run it on 2 motors, 4 different turbos, 3 different manifolds, stock S52 cams and schrick cams, stock head and ported +1mm valve head. Runs greats with wastegate disconnected for no boost, runs great at low rpm and light throttle before I get in boost, runs great at 10 psi, runs great at 15 psi, runs great at 20 psi. I would not mess around with a standalone unless that is a project you want to get into and you want to tune your car yourself. People have made 1000 rwhp on a stock ECU with tune. Aftermarket ECU can do things a stock ECU cannot, but you don't need those things to have a reliable well sorted out car.
  7. #32
    Nov 2016
    Central Indiana
    1998 BMW 328is
    Okay thanks for the help, not getting a standalone is going to save some good money. Time to find some local Indianapolis area shops that are known for good work
  8. #33
    Apr 2006
    Minnesota eh?
    86 325es
    Just wanted to add that you can't put an s52 crank in anything else without the right pistons. The piston pin height has to match the stroke.
    I see no reason not to use a stock ecu tune for what your doing.
    if it were mine I would clean the head up at home and put it back in assuming you have a healthy motor
    fear not, this path has been walked a couple hundred times
  9. #34
    Nov 2016
    Central Indiana
    1998 BMW 328is
    Yep, just gotta find the right car first. I'll probably be updating my first post on this thread with some of the questions I had and the answers I got to help others who happen to run across this thread with the same questions.
  10. #35
    Jan 2017
    RI
    1994 325is
    You mention looking for a car and either a m50 or m52 in the first post. One thing I would add is to look for a 328. That way you have a zf trans out of the starting gate and have one less thing to worry about, break, and buy.
    Sent from my SM-G930V using Tapatalk
  11. #36
    Nov 2016
    Central Indiana
    1998 BMW 328is
    Quote Originally Posted by drstuess View Post
    Yeah I was hoping to find a 328is, no luck yet.
  12. #37
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    Bottom line, have another car/reliable daily driver while this your project car becomes a project car.
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
  13. #38
    Virginia
    97' m52 turbo
    Quote Originally Posted by BMWManiac View Post
    This is true ^
    My car spends more time in the shop than it does anywhere else.
  14. #39
    Sep 2002
    USA
    BMWs
    let me chime in because it's been a while since we had a 5mall5nail5 argument.
    Substance D, no offense, but if I had 5 cents for each count of how many times I had been consulted on builds that involved self-built, self-tuned MS setups, I'd be rich.
    Not trying to cast judgement, but I've had cars roll into my driveway on MS2/Extra that "just need a tune" and I find out there are open circuits to coolant sensors, etc.
    You had a failure at 500 RWHP (which is somewhat useless, torque figures make more sense here) which is NOT the norm. I ran an M50 non vanos for probably 80k miles on MS both supercharged and turbocharged in the 350 - 450 rwhp realm for YEARS on a college budget. Your car experienced a failure - could be from the ECU, the tune, or the care of the engine previously. That said, your result is not the norm.
  15. #40
    Sep 2010
    Salisbury md
    1998 318i
    Substance D- What was the rpm limit on the engine that windowed the block?
  16. #41
    Jun 2012
    Socal
    turbo e36
    Quote Originally Posted by 5mall5nail5 View Post
    I appreciate your opinion. We can speculate all we want, but honestly, I know my setup inside and out. Will I put another motor together with stock M52 rods, nope.
    I don't want to muddy up this kids thread anymore than I already have.
    Quote Originally Posted by charles318 View Post
    pm'd
    back on topic.
  17. #42
    Apr 2006
    Minnesota eh?
    86 325es
    I have seen 3 different stock m50/m52's in the junkyard with holes in the side of the block, so I guess the safe hp limit is less than 150 whp. It happens to any type of motor.
  18. #43
    Jun 2012
    Socal
    turbo e36
    Lol. Must have been the tune. My rod bolts were intact, I just had to weld nuts to em to get the big end off. Crank looks okay, hope I can salvage it.
  19. #44
    Apr 2006
    Minnesota eh?
    86 325es
    What I'm saying is it wasn't necessarily your or anythings fault. It a mechanical thing and they break. That doesn't mean they all break. Roll of the dice.
  20. #45
    Manchester, N.H.
    96 332IS 6466 turbo
    Sometimes you just get screwed
    1996 332IS
    Built 3.2
  21. #46
    Oct 2015
    San Rafael, California
    1996 bmw 328is turbo
    LOL same thing happened to me. Dropped intake manifold nut into intake by accident. Thankfully head was able to be saved and still running 18 psi with that piston.
    96 328is turbo. Built 3.2, 6266, RSI Manifold
  22. #47
    Manchester, N.H.
    96 332IS 6466 turbo
    I bought a spare m50 manifold online. For a direct port setup. Cleaned it all up and was driving it for a few thousand miles. It must have been really wedged in there. At 22-23# it broke it lose.
    1996 332IS
    Built 3.2
  23. #48
    Nov 2016
    Central Indiana
    1998 BMW 328is
    For this build that I'm planning, since I'm not taking the engine out I don't need to worry about gaping the piston rings to a certain level? Just stock gaps?
  24. #49
    Virginia
    97' m52 turbo
    First, the answer is no
    There are 2 ways you can prepare the motor.
    a. Cutring gasket, spacer, and arp studs
    Will lower compression to 9:0:1 which is why you don't need to gap the rings. With a good tune and that compression the engines are good for up to 550whp. Its been proven, dont listen to the random dude who posted pics of pos rods and his build. Something was wrong or went wrong with his build that caused his shittiness
    b. You can build the motor and gap the rings in the process.
    But its been proven so many times that you can make good power out of the e36 engines and previous I6 engines without major modification. As long as you use quality components and an excellent tune you'll be okay.
    That doesn't mean go chasing waterfalls of power, the motor is stock. But I can say first hand on a base-tune and about 7-12 psi the cars are an absolute blast. If I can keep it in this power range I'm sure the engine would last as long as I wanted it too. Everything else, rear end, trans, etc... Is what you need to worry about. Unfortunately Mr. Rods didn't make it to that point :-(
    oh and if you have e85... strap a turbo on it, have it tuned, and drive it. Skip all the nonsense
  25. #50
    Apr 2006
    Minnesota eh?
    86 325es
    Compression has nothing to do with having to gap rings but yes stock ring gaps seams to be fine up to a certain hp level.
  1. HELP, tuning my turbo setup
    By 97m34 in forum Forced Induction
    Last Post: 06-08-2010, 07:33 PM
  2. need help with a turbo setup... please!
    By brumsky in forum Forced Induction
    Last Post: 05-14-2008, 08:22 PM
  3. 318 M42 turbo setup help
    By DASC RACER in forum Forced Induction
    Last Post: 04-26-2006, 05:23 PM
  4. 325i getting a turbo setup soon need help.
    By BRUNO in forum Forced Induction
    Last Post: 04-29-2005, 10:56 AM
  5. Cheap Turbo setup
    By ///Manuel in forum Forced Induction
    Last Post: 10-21-2002, 03:00 PM
