Results 1 to 6 of 6
Thread: OBD1 To OBDII Management
    Apr 2008
    Douglasville
    3 BMW's a Benz & a Truck
    Good Evening All,
    Making progress on my 3.2 build to go back into the E36. Now that I have more or less decided on the hardware that I will be running I have started to look into the software/management and have decided that I want to run OBDII instead of OBD1. My E36 came from the factory as an automatic OBD1 vehicle. I already have the harness and all the sensors from the donor OBDII car, most of them will be replaced anyway. I remember reading a thread on what connectors need to be modified in order to run the vehicle OBDII instead of OBDI and was wondering if anyone knew the thread I was referencing, I tried searching but was unsuccessful. Any advice or help is appreciated, thanks.
    -Fully Rebuilt M52-Ported & Polished Head-3 Angle Valve Job-S52 Cams-540 MAF-24lb Injectors-BBTB-Longtube Headers-TRM Tune-ZF 5 Speed Swap-M50 Manifold-AFE Stage II 3.5" CAI-Remus Exhaust-Rokkor Coilovers-Polyurethane Bushings-ZHP Shift Knob-Sport Seats-M-Technic Body-EBC Cross Drilled & Slotted Rotors-EBC Red Stuff Pads-Euro Foglights-DJ Auto-Clear Lights-M Tech Side Moldings-VDO Gauge Pod-BBS RC-M Tech 1 Steering Wheel-BSW D210-Motion Motorsport Under Panel
    Cars: 2005 BMW 545i-2004 BMW X5 4.4i-2004 BMW 645ci-1999 BMW 528i-1995 BMW 325is-1994 BMW 840i-1989 Mercedes-Benz 560SL-2001 Dodge Ram 2500 Turbo Diesel
    Mar 2011
    Kingston ,Jamaica
    1997 328i turbo
    Yes in for that info too planning on doing the same on my 1995 m3 obd1. I know about wire loom sensors and it can be ews deleted but not sure which connectors need to be modified
    Oct 2003
    Seattle
    99 M3
    You need an OBDII engine harness, and the fuel supply lines and fuel rail are different.
    Are you planning to incorporate Traction Control Throttle Body as the ECU will be ‘looking’ for it.
    I think it is easier to convert the S52 to OBDI.
    Mar 2016
    Australia
    e30 318i, 135i
    Quote Originally Posted by bluptgm3 View Post
    Not all obd2 engines had it.
    You need:
    - Trigger wheel/harmonic balancer (optional if running rear/block mounted crank sensor - this varies by region i.e. EURO OBD2 cars have timing cover mounted CPS)
    - Crank Position Sensor
    - Cam Angle Sensor
    - IAT
    - ECU
    - Engine Harness
    - Knock sensors
    - O2 sensors. OBD2 uses 0-5v sensors, very different to others.
    - MAF
    It can all be done fairly cheaply and is a massive benefit as far as finding faults and flash tuning.
    Oct 2003
    Seattle
    99 M3
    I don‘t believe the M50/S50 US engines have the aft crank trigger or the machined provision in the block.
    Apr 2008
    Douglasville
    I have an OBD2 Harness already, I have an entire OBD2 car for parts. Not planning on incorporating traction control.
    Quote Originally Posted by ba114 View Post
    You need:
    - Cam Angle Sensor
    - IAT
    - ECU
    - Engine Harness
    - Knock sensors
    - MAF
    I've got all the OBD2 sensors already, I bought a complete E36 M3 for the engine and parts. I'm looking for what needs to be modified on the x20 and x69 harness on the chassis side of the vehicle so that the engine harness will plug in to the correct pins. It is my understanding that the connectors on the OBD1 vehicles were pinned differently than on the OBD2 vehicles and that if I were to connect an OBD2 engine harness into an OBD1 pinned x20 and x69 harness that I would do some electrical damage. That is precisely why I want to run OBD2 instead of OBD1. Better diagnostics, tuning, etc.
    They do no have that provision in the block. The crank sensor from the Euro spec engines mounts up front and is a hall type sensor so it works the same way that the sensor works in the rear of the block. It is a workaround for running the OBD1 engines on OBD2 management.
  1. Smog Check...Couldnt connect to OBDII!?!?
    By radelow in forum 1992 - 1999 M3 (E36)
    Last Post: 03-05-2006, 05:57 PM
  2. OBD1 to OBD2 swap 2.5l-2.8l??
    By AKCraig85 in forum 1991 - 1999 (E36)
    Last Post: 08-10-2005, 03:40 PM
  3. Replies: 13
    Last Post: 08-27-2004, 02:27 PM
  4. Failed Smog due to OBDII...help!!!
    By ///M3-=FiN=- in forum California sponsored by Avus Autosport
    Last Post: 08-18-2004, 05:02 PM
  5. OBD1 to OBD2,traction control?
    By Keith97m in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-14-2003, 12:13 AM
