Results 1 to 10 of 10
Thread: Problem after removing and reinstalling console
    May 2016
    Eureka Springs, AR
    2000 BMW Z3 Roadster 2.5
    I recently pulled my console out to fix some wiring that had been chewed on my a mouse at some point and time. Although the damage wasn't near as bad as I thought it might have been. Just a couple of wires under the console that had a little insulation chewed off. I got the wires taped up and also replace the bulbs and sockets in the HVAC controls while I was at it (had one burned out).
    Lights in HVAC work great now. Got everything put back together...all the connectors plugged back in etc.
    BUT...now, my odometer doesn't light up...fuel gauge doesn't move...actually don't really know what all does and does not work on the dash. Car starts and runs fine. I'm thinking that I must have pulled something loose under the dash or something by accident. Or is it possible that I just didn't get something connected back up? I wouldn't think that there would be something under or in front of the console that could cause this. Have I blown a fuse? Any help is greatly appreciated. It was such a job removing and then re-installing the console to now have this happen .
    2000 Atlanta Blue Z3 2.5L 5 speed manual with factory hartop.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by ArkansasTed View Post
    Does that mean it does not rise to show current level of fuel, or does not drop from consumption when driving?
    Could you have shorted one of the fuzes here?
    https://blog.bavauto.com/3447/bmw-e3...nation-lights/
    BMW MOA 696, BMW CCA 1405
    May 2016
    Eureka Springs, AR
    Quote Originally Posted by Vintage42 View Post
    Could you have shorted on of the fuzes here?
    It does not rise from the E mark when the key is turned on. I will check the fuses when I get back to my garage tomorrow...but i was frustrated by the time I got everything put back together...just to have the dash not working correctly, so I just shut everything down and came home.
    Quote Originally Posted by Dane36328i View Post
    This so off topic but i need help with my e36 sedan just bought a set of 6piston calipers and some 325x25 ... i have some apex arc 8 et42 would they clear ?
    You will get more answers by starting a separate thread on the subject.
    I forgot to also mention...that my analog clock is not working either...which it has always kept perfect time since I have owned the car.
    Is it possible to plug the connector into the clock backwards? I would think that the connector would be keyed somehow...where it will only plug in one way. I had to plug it in by feel.
    Terry F.'s Avatar
    Terry F. is offline ONLY BMW Content is + Moderator
    Broward County, FL
    M-Roadster
    The fuel gauge is supposed to move?
    Stuff. I got stuff.
    May 2016
    Eureka Springs, AR
    Quote Originally Posted by Terry F. View Post
    I thought it was supposed to move when you turn the key on. It is showing empty and it is not empty.
    I never let any of my vehicles get even close to empty. Everything worked fine before I removed and reinstalled the console.
    Oct 2012
    Louisville, KY
    May 2016
    Eureka Springs, AR
    My problem with the warning dash lights / odometer was an easy fix. I check all the fuses described in the link in post #2. All of those fuses were good...checked with a digital multimeter. But then I thought....the clock (which is analog) was not working either. So I checked the fuse diagram to see which fuse was for the clock. Sure enough...the fuse was blown. I replace the fuse and immediately the chime in the car started dinging. I sat down in the car and turned the key on and.....everything lit up like it was supposed to. And the fuel gauge (needle) jumped up to the full mark, and the clock also powered up.
    So if anyone else ever has this problem....check the clock fuse. I can't imagine why the clock fuse would power the warning lights in the dash too....but obviously it does.
    Oct 2012
    Louisville, KY
    Several things are often shared on several fuses. You have to check the Bentley Manual to see.
    In another thread, a fuel gauge quit and it shared a fuse with the wiper / washer, which had shorted.
    May 2016
    Eureka Springs, AR
    Thanks Vintage for your replies....I appreciate your help.
    Jul 2004
    Houston, TX
    36 Cylinders
    http://www.wedophones.com/BMWManualsLead.htm
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  1. E36 BMW M3 antenna problem after removing factory amp
    By Brent95M3 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 12-21-2006, 09:33 AM
  2. Intake manifold remove and reinstall
    By martialartsblac in forum 1991 - 1999 (E36)
    Last Post: 11-15-2006, 11:51 AM
  3. hmmm, weird idle problem after oil and coolant change?
    By Alizè in forum 1991 - 1999 (E36)
    Last Post: 08-20-2006, 12:59 AM
  4. Intake problem after removing manifold
    By louisianajobe in forum 1991 - 1999 (E36)
    Last Post: 12-04-2005, 11:25 AM
  5. Major tranny problems after JC and HFM install.
    By Kudo540 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-19-2003, 01:40 PM
