RM European Auto Parts
Results 1 to 5 of 5
Thread: Washer fluid dispensed under hood and not through the blades
    Dec 2017
    Delaware
    2004 BMW 530i
    Has anyone else had this issue? Could it be a bad washer fluid motor?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    Well, is it the tank emptying right after you fill it? Or does a big puddle of blue water appear under the car when you hit the washer fluid? Have you tested to see if the pump is getting power? Have you tested the pump with 12 Volts to see if it will come on?
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Dec 2017
    Delaware
    2004 BMW 530i
    No, I have not done any tests and I didn't think to have someone try to dispense fluid while the is parked...only using while driving. The tank is emptying somewhat through a tube under the hood close to blades...if that makes sense.
    dworthy's Avatar
    Nov 2010
    Yes it does in a way, that means the fluid piping is disconnected or the sprayer is clogged and needs to be replaced. The only way to know for sure is to pull the hood mat off and have a look. If you see a black tubing unhooked from the sprayers, then you have your answer. Otherwise you will need a buddy to hit the sprayers to see if the fluid comes out of the tubing.
    It will look like this: http://www.realoem.com/bmw/enUS/show...diagId=61_1674
    Darin
    Current:
    Past:
    M-Flight Member
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    http://www.realoem.com/bmw/enUS/part...BMW-530i&mg=61
    Scroll down to the bottom. Then remove the hood liner enough to see what's leaking. Match that part to the diagram, and order that part number.
    Note that all this 15 year old plastic will tend to break when you touch it; you may need additional parts, when you go to fix the leak.
    Chris Powell
    BMWCCA 274412
  1. bmw x5 subtle white smoke under hood and burning smell. Pls help!
    By mgcorrei in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-23-2013, 03:48 PM
  2. bmw x5 subtle white smoke under hood and burning smell. Pls help!
    By mgcorrei in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 07-22-2013, 09:43 PM
  3. Oil loss, blowing sound under hood and 50% power
    By softtopsman in forum 1996 - 2003 (E39)
    Last Post: 10-24-2012, 10:39 PM
  4. Best way to remove foam from under hood and trunk?
    By CMG in forum 1978 - 1987 (E23)
    Last Post: 04-24-2012, 05:37 AM
  5. Jlevi SW | Vorsteiner Holiday Promotion- $150 Off Hoods and Trunks through December!
    By Edison@Jlevi SW in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 12-02-2008, 01:20 PM
