RM European Auto Parts
Results 1 to 11 of 11
Thread: ABS-BRAKE-SEnsor lights all on
    Dec 2017
    Long Beach ca
    2002 325i
    New to forum-2002 325i-manual says ABS control unit....ran a code check and only thing coming up is a rich mixture. So why are all three lights on? Drove to 55 mph and hit brakes hard...no locking, tracks straight and brakes well.
    Thanks in advance! Love this car!
    Jul 2004
    Houston, TX
    36 Cylinders
    You have to use a code reader that can read into the ABS module. What you read was just engine. A basic OBD reader is not enough.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    dworthy's Avatar
    dworthy is online now Wagon meister :) BMW Tech Expert
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    That little pocket reader will only talk to the engine DME. You need to get to a shop or pony up some money to get a true diagnostic tool that will read all the ECU's in the car.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Dec 2017
    Long Beach ca
    2002 325i
    Ok...do you have recommendations I can buy? I would rather read myself than have someone else do it. I just want to see it for myself. but in any event....car seems to be performing well in spite of the indicator lights. Anything I should be worried about? Does the factor pre-set these to come on after a certain amount of miles as a safety precaution?
    dworthy's Avatar
    Nov 2010
    I have heard great things about this unit: https://www.ecstuning.com/b-schwaben...020sch01a~scf/
    However if you have an older laptop, you can also get INPA to do the work too. Normally a USB with a 16-pin connector that is compatible with INPA and you have to learn the program.
    Darin
    Current:
    Past:
    M-Flight Member
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    and, to answer your other question - No, it is actually a violation to set a MIL for anything other than a malfunction.
    this is not an uncommon issues on e46 BMWs. we'll need to know the codes stored, as the possibilities as to why these lights are lit number in the thousands.
    this can be as simple as a dirty throttle body and ICV to something far more complex.
    at some point, you'll also need to address the mixture code.
    a few thoughts:
    1) join your local BMW CCA chapter and get to know the folks in the club. odds are they have tools or knowledge to help. or, at the least, will know the best shops in your area.
    2) if you intend to work on this vehicle yourself pick up a bentley service manual.
    3) yes, get a good scan tool - if you are computer savvy setting up your own isn't too hard, but, the Foxwell unit from ECS/Turner is hard to beat for the price and ease of use.
    here's a few links to things we'll need to know to help you out:
    https://www.bimmerforums.com/forum/s...ose-your-issue
    https://www.bimmerforums.com/forum/s...cal-Help-Forum
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    I'll just add my voice to the excellent guys you've already got, offering their assistance. Buy that ECS/Foxwell device, or ask Abel (328Power04) to help you get started with INPA, and we'll all be very happy to help you decipher your codes.
    As others have stated, you cannot decipher ABS codes with an OBD code reader. The OBD system was created for emissions problems, and it was done by bureaucrats, not mechanics. It has its usefulness, but this usefulness is extremely limited.
    Chris Powell
    BMWCCA 274412
    NW suburban Chicago
    hiss by my window
    Sounds like the Bosch 5.7 trifecta. Was that system carried over to the E46 chassis?
    Jul 2004
    Houston, TX
    36 Cylinders
    He wouldn't have a working speedometer, I would think.
    I would think a yaw sensor is in the OP's future.
    But a scan is the most important first step.
    If you're slightly computer savvy and have a Windows laptop, you're more than halfway there.
    -Abel
    Jun 2002
    E39M5, E500 4WD
    Ouch. Yaw sensors are not cheap.
    https://www.ecstuning.com/b-genuine-...r/34526864094/
    But, of course, it could be something much cheaper to fix......when we know the codes.....
    Chris Powell
    BMWCCA 274412
    Jul 2004
    Houston, TX
    36 Cylinders
    You can buy 10 used ones for that price. But I can't recall if a yaw sensor fault would block abs function as well.
    Wheel speed sensors are also common, or module issues.
    -Abel
  1. TPMS, ABS, and DSC lights all on
    By mikeyb74 in forum 1 Series & 2 Series (E81, E82, E87, E88, F20, F22, F23, F40, G42)
    Last Post: 11-21-2011, 05:17 PM
  2. changed brake sensors light still on
    By kiwi325i in forum 1991 - 1999 (E36)
    Last Post: 03-29-2010, 12:14 PM
  3. ABS ASC Brake Airbag lights all on...!!!!
    By MrRight in forum 1995 - 2001 (E38)
    Last Post: 03-01-2010, 05:04 AM
  4. Help , ABS/Speed sensor light came on
    By calypso325i in forum 1999 - 2006 (E46)
    Last Post: 04-22-2009, 09:58 AM
  5. Help: Braking Fluid, Park Brake, ABS, and Battery Lights ALL ON!!!
    By philow in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-08-2008, 10:34 PM
