Guys,
The lights on the following buttons do not work. SEDC, DSC and transmission shifter. No lights at all on the buttons when they are pushed, the DSC light on the dash is permanently on and the light on the shifter does not come on as you shift from P to D. It lights up on the dash but not on the shifter. Any ideas?
Thanks.
shak. g
well, s-edc light on the button not working would mean the system is inactive. it could be an issue with the shocks or the module.
the dsc button does not have a light on it, pressing it will turn on and off the traction control (the warning triangle on the cluster). if the warning triangle is lit all the time by itself (no abs or brake lights), means it is an issue with one of the wheel speed sensors or the steering angle sensor. Mine had the light on when i got it and turned out it was only on cause of prior speed sensor errors in the system. Cleared errors, bam, gone.
i dont know why your shifter light does not illuminate, i'll let the others chime in.
Thanks you sir.
shak. g
