Results 1 to 25 of 53
Thread: VANOS Question for M54 experts
    Oct 2007
    Middle TN
    Too many/Not enough
    Vehicle is a 2005 X3, M54, 183,000 miles, owned and serviced by me since 58,000 miles, new Bosch O2 sensors, rebuilt VANOS unit, new Bosch coils and plugs and no codes. Vehicle has sluggish low rpm acceleration that has gradually gotten worse over the last 10,000 miles, mpg is poor. Rebuilding the VANOS made no difference. Starts good, idles smooth. I know the engine has lots of miles, but there's something not right. I have a Schwaben professional scan tool, and some of the readings I am unable to interpret. Here's a VANOS readout that concerns me and I would think displays a problem with the exhaust adaptation, but I don't know how to translate the reading to a problem that I can resolve:
    http://s1232.photobucket.com/user/91...kfrkp.jpg.html
    I don't see how the exhaust adaptation could possible be right, but I can't find any information on what the correct readings should be. Any VANOS experts that can advise?
    Many thanks in advance.
    Edit: One symptom I would like to add is that the engine has what I consider to be excessive induction sound during acceleration, almost like it's running with an unmuffled air filter, but the filter housing is tight and the main air intake into the housing is tight and sealed to the front of the radiator support.
    Current Garage:
    91 e34 M5 - spoiled & demanding 27 y/o -glanzshwarz
    91 850i/6 -another spoiled & demanding 27 y/o- schwarz-gone but never forgotten
    06 325i - undeserving, spoiled & demanding 27 y/o daughter's DD-hellrot
    03 MINI Cooper S JCW -spoiled & demanding, yet deserving wife's DD - Chili/Panther
    05 X3 3.0i -family workhorse - diamond schwarz
    12 X5 3.5d - torque monster - space gray metallic
    86 GMC Cabellero - Old Faithful 32 y/o DD BMW Support Vehicle
    08 Cub Cadet 19HP 46" hydrostatic- yard vehicle
    88 Schwinn Sierra - 1WD Off Road Vehicle
    e31 & OHC BMW CCA #385540
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Only suggestion I have is to replace the intake and exhaust cam sensors. They can and do become less accurate without throwing codes. Night and day difference in low-midrange power.
    Oct 2007
    Middle TN
    Too many/Not enough
    Quote Originally Posted by dhurley34 View Post
    Thanks dhurley. Actually, I have an exhaust sensor on the way...I'll report back when it's installed.
    Current Garage:
    Jun 2012
    New Mexico
    1995 540i/6
    Have you pulled the DISA valve out of the intake? They can fail without causing a massive air leak. No check engine light the car just wont run very well.
    Dec 2007
    Spain
    2003 330ci
    What I find strange is that you noticed no difference after rebuilding the vanos. Changing out those old dried up o-rings which let the pistons flap about inside the unit should absolutely make a difference, giving a smoother idle and a bit more torque at low rpm. Did the job go smoothly? Did you run into any issues? Did you use teflon o-rings?
    Jun 2012
    New Mexico
    1995 540i/6
    I have not yet seen a bad VANOS seal. I did rebuild the double VANOS in my old M52TU. Close to 200k miles. Was trying to solve a problem that turned out to be a bad coil. Those o-rings came out looking quite good.
    My wife drives a 2004 X3 3.0 with 176k miles, no problems. I also have an 03 325i with 195k miles, original VANOS, runs great.
    Aug 2014
    Lawrence Kansas
    Vanos seals go bad by virtue of losing their ability to hold their shape after under specific pressures after becoming brittle by constant heat cycles. The factory Buna-N o-ring material has a limited shelf life in petroleum/hot conditions and eventually they're unable to keep even pressure on the outer teflon seals. This is why the replacement kits have viton o-rings which are by far superior. You usually won't feel an immediate difference in power unless the seals were terrible. It takes about 500-1000 miles for the new seals to break in.
    Dec 2007
    Spain
    2003 330ci
    Wow OK. I did mine and they were dry and brittle and the pistons had a lot of room to flop around. After replacing them I noticed an immediate difference, on an engine with less miles than OP. I figured most engines would be affected the same way at this mileage which is why I was suprised that OP's rebuild had no affect.
    Oct 2007
    Middle TN
    Too many/Not enough
    Quote Originally Posted by nonturbodan View Post
    A new DISA valve is ordered. Considering the miles and age of the vehicle, I figure it's reasonable to replace it as preventive maintenance.
    Current Garage:
    Oct 2007
    Middle TN
    Too many/Not enough
    Quote Originally Posted by Hellmet View Post
    If there was any difference, it was negligible. I was quite disappointed because of all the positive comments I found online regarding improved performance after they were replaced. The replacement was performed with ease and no issues. Teflon rings were used.
    Current Garage:
    Chicago, IL
    2001 330i and 2005 330i
    The weird noise might be the oil separator giving up.
    I had sluggish acceleration and nothing seemed to improve it (although new VANOS seals made it a bit better). I tried changing out all the usual suspects as you are doing with little effect. Then I started getting t-stat problems every 6 months. This tipped me off that there must be an underlying problem. OEM t-stats don't fail that fast. Finally hooked up INPA and discovered errors in the DME. After re-flashing the DME, the car is like new again. Plenty of low-end power. Fast take-off, the works. OP, if you have a spare laptop, I would rig up INPA and see. Big bang for the bucks.
    Johnny Murray
    California
    325e 535i M5 325iT 330i
    Quote Originally Posted by johnjmurray View Post
    I know this may be taking the thread slightly off-topic, but I'm particularly interested to know what you found when diagnosing the DME with INPA, and how you reflashed it.
    Oct 2007
    Middle TN
    Too many/Not enough
    Quote Originally Posted by Jackson42 View Post
    I, too would like to know how you reflashed the DME. I thought that was available only through the dealer.
    Current Garage:
    Oct 2007
    Middle TN
    Too many/Not enough
    The entire CCV system was replaced around 15,000 miles ago with BMW cold weather parts. This was done as preventative maintenance while I had the intake removed to replace the starter. Re-sealed the intake and replaced some coolant pipes and hoses while I had it off.
    Replaced the DISA valve yesterday and there was no change in performance. I reset the adaptations later on and the engine seems to be improving as it re-learns after the adaptations.
    Current Garage:
    California
    Quote Originally Posted by 91e34M5 View Post
    OK, I'm good at taking things off-topic - this is the second time in this thread. (Massive apologies. I'm easily distracted/amused.) I'm also an owner of a '91 E34 M5. Out of curiosity, what are the last seven of your VIN? There's a guy in Denver on the forum whose car rolled off the assembly line immediately before mine (sequential serial numbers). Just would like to know where you are in the sequence.
    Jun 2012
    New Mexico
    1995 540i/6
    Yeah I've read all about it. The thing is that the buna o-rings are just a filler. They can harden but they still support the teflon ring. Unless they were to dissolve somehow they will continue to support the teflon rings. The gap between the VANOS piston and the VANOS body is also very small. VANOS operates on a continuous supply of high pressure oil which compensates for any leakage automatically.
    I am firmly of the belief that the VANOS will set a fault if its not able to hit its targets. They do fail on occasion but its not subtle. You get driveability problems and a check engine light.
    Aug 2014
    Lawrence Kansas
    A sluggish vanos almost never trips a CEL even with driveability issues unless its accompanied by a cam sensor or solenoid failure. The margin for error in timing is too great for the DME to pinpoint it.
    Jun 2012
    New Mexico
    1995 540i/6
    Yeah, I've read that too. The DME monitors lobe centers down to a tenth of a degree at all times. If it can't hit its mark it will set a fault for a mechanical VANOS failure.
    Aug 2014
    Lawrence Kansas
    Yeah, the bad part is that both cam sensors have a tendency to become dull post-100k miles so the DME thinks everything is A-OK and within measurement but its really not. I've replaced the cam sensors on 3 vehicles that didn't have sensor codes and it made an unreal difference in midrange power and smoothness of shifts.
    Oct 2007
    Middle TN
    Too many/Not enough
    Tried to install a new exhaust cam sensor yesterday. Used a quality 5mm hex and I rounded the hex insert. I've replaced multiple cam sensors on M5x engines and N52's and never had this to happen. I was really, really tight..I guess rounding it off is better than breaking it off. What makes it so bad is that on an X3, the exhaust cam sensor is very easily accessed without removing anything.
    Current Garage:
    Oct 2007
    Middle TN
    Too many/Not enough
    Mine is relatively early:BK05241 have owned it for 10 years and put over 50,000 travel miles on it as well as considerable track time.
    Current Garage:
    Oct 2007
    Middle TN
    Too many/Not enough
    I'm beginning to think that there is a problem with the vanos seals I installed, specifically the exhaust.
    Current Garage:
    Jun 2012
    New Mexico
    1995 540i/6
    That is another thing I don't like about servicing them. There is a possibility of damaging the teflon rings during assembly. Would suck to screw one up fixing something that isn't broken.
    Aug 2014
    Lawrence Kansas
    Take a pair of vice grips and grip the outside of the bolt and try to remove it that way. That bolt has thread locker on it and can be a pain in the ass to remove sometimes.
    Jun 2012
    New Mexico
    1995 540i/6
    Sometimes with an allen type fastener you can get a second chance at it even after it seems stripped. If you tap the allen bit in with a hammer and get it fully seated in the bolt head you might have enough bite to break it loose. Those fasteners are very difficult to completely strip, more often the bit is just out of alignment and not fully seated into the head of the bolt. Just make sure the second time that you are lined up and applying torque perfectly perpendicular to the axis of rotation.
  1. VANOS question for the experts
    By thekubiaks in forum General BMW sponsored by Intercity Lines
    Last Post: 11-10-2004, 04:41 AM
  2. Question for windshield experts:
    By EvanL in forum 1992 - 1999 M3 (E36)
    Last Post: 08-25-2003, 03:29 PM
  3. Question for Engine Experts
    By ChaseBmw in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-23-2002, 05:11 PM
  4. question for brake experts
    By M3*TR in forum 1992 - 1999 M3 (E36)
    Last Post: 10-21-2002, 05:57 PM
  5. Question for suspension experts...
    By ¶Pho€nix in forum 1992 - 1999 M3 (E36)
    Last Post: 05-29-2002, 05:28 PM
