Hello,
New here and I have already read everything there is on this. I did all the testing possible.
When you turn the key to ignition the blower should come on and it doesnt. Start the car and put on high defrost and nothing. Drive for a bit then turns on. Once it's on it works fine every speed auto or manual. If the car is turned off and then restarted, the same thing starts over again.
Ive changed the FSU. tested it to make sure its not the control board. Ive removed the blower and it was working at the time of testing. I put everything back together. Turned the key on and off a couple of times and evrything seemed fine. Next day its back to its regular routine.....
Do I just change the blower motor? Maybe a weak spot on the brushes?
thank you
