Results 1 to 5 of 5
Thread: O2 Sensor Question
    Apr 2014
    DFW TX USA
    1983 320I, 1986 325E
    O2 Sensor Question
    So one of my friends recently purchased a 1999 323i. The seller told us that the car was not recognizing the post cat O2 sensor. As in the computer can't see or detect it. The seller did replace the sensor, but it didn't make a difference. Has this happened to anyone else?
    Mar 2016
    Portland, OR
    2002 325Ci Cabriolet
    Quote Originally Posted by Thecatmilton View Post
    If the seller replaced it with after-market Chinese crap, it's likely a failure of a new part. O2 Sensors on a BMW should always be a Bosch part. After-market crap can have an out of box failure rate exceeding 50%.
    Apr 2014
    DFW TX USA
    I don't know how or why, but we drove the car up on oil change ramps and the CEL went off. We are going to drive it a bit and see if the CEL stays off. We tried getting it inspected, but the battery was dead when we got the car so we need to drive it 100 miles first.
    Dec 2013
    Chicagoland area
    EXOTICS
    Check for loose or shorted wiring connections hanging off the post-cat sensor under car.
    Oldham UK
    '00 330i Sprt '92 525i
    FWIW, I am working on two faults. Post cat heater doesn't throw the service light let alone CEL. But I know it is duff and am about to replace it. Lean on both banks just throws the occasional service light which I can turn off and it will not reappear for months. I have some new O rings to fix that. So maybe you need to read the fault codes and establish what the ECU thinks is wrong?
  1. o2 sensor question
    By cleoent in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-26-2003, 03:57 PM
  2. O2 Sensor Questions
    By Russ(Austin) in forum 1992 - 1999 M3 (E36)
    Last Post: 01-23-2003, 01:19 PM
  3. Exhaust Gaskets? And O2 sensor questions
    By owen in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-25-2002, 02:08 AM
  4. o2 sensor question
    By mpbmw318is in forum 1991 - 1999 (E36)
    Last Post: 03-14-2001, 03:07 AM
  5. O2 Sensor Questions
    By ///MCubed in forum 1992 - 1999 M3 (E36)
    Last Post: 02-27-2001, 02:08 AM
