Results 1 to 15 of 15
Thread: Long-Term Parts Roundup
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    I finally completed several miscellaneous, tedious tasks that I've been putting off for over a year:
    1) eBay front bumper with professional paint ($470)
    I learned that eBay bumpers require about an hour of prep work with a sharp blade to open up various slots and tabs, the result of sloppy molding. But the end result is indistinguishable from OEM. And for that price ($80), I'm not complaining.
    2) Upper windshield seal
    3) Window track bumpers (prevents "clunk" noise when window reaches its bottom stop)
    4) Headliner ($270)
    As I discussed in a previous post, this is actually a downgrade from OEM material. However, there is simply no other viable option.
    Frankie
    Texas, USA
    frankies-bmw.com
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    5) Reverse light polish
    6) Ash tray renovate (fully functional lid)
    7) Seat map pockets rebuild (with 3D printed parts)
    Frankie
    Texas, USA
    frankies-bmw.com
    Vincentown, NJ
    E46 M3 conv, E30 325iS, E39 M5
    Tell me about the 3d printed parts...
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    Quote Originally Posted by nmlss2006 View Post
    Seatback Pocket Repair Service
    Frankie
    Texas, USA
    frankies-bmw.com
    Jun 2015
    Takoma Park, MD
    01 BMW 740il
    Tell me about your method of polishing your tail lights.
    Feb 2004
    Redding, CT
    '01 740i sport, VW TDI
    I'll pile on to the requests How did you find the job of replacing that upper windshield seal? I'm assuming you didn't replace the glass..
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Must know about the ashtray renovation!
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by red740is View Post
    Good job, Frankie! When you get bored of this car the buyer will be a lucky guy.
    I have recently replaced that upper windshield trim, it was relatively easy. New seal cut down wind noise considerably. Probably took me 45 minutes, takes some effort to push in the new one. Getting out the old one is really easy, but mine was mostly missing. When you are there you probably should replace moon-roof seal as well, another one greatly reducing wind-noise. Takes more time to install though.
    But anyway, knowing Frankie we are due to a DIY on all of these including 20 pictures and helpful explanations
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    Quote Originally Posted by oatmealwithwate View Post
    Start with 1000 grit sandpaper and a 3" polisher. Then 2000. Then 3000. Finish with regular plastic polish. Nothing special.
    the job of replacing that upper windshield seal?...
    Easy. Carefully pry out left/right rain gutter trim strips to provide full access to rubber seal. Rip out old rubber seal. Using soapy water, press in new seal. Done. (No, I did not have a new windshield installed.)
    Quote Originally Posted by clarkitect View Post
    Ashtrays can be repaired one of two ways:
    1) Buy a new one (part #3 here, about $120).
    2) Repair it yourself using off-the-shelf hardware from Lowes Depot, etc, and with cannibalized parts from an eBay ashtray. And patience.
    If repairing it, take it apart completely to find out where the broken parts are. Typically, the retaining tabs which hold the lid return springs break off. They can be repaired using a small screw thru the frame to act as a retainer. If a lid support arm (which follows a cam) is broken, pry it out and replace it with one from an eBay ashtray.
    Ash tray mounting points often break as well. Remove the broken plastic mount point with a Dremel or file and replace with a very small metal bracket (sold in the small hardware parts drawers at Lowes, etc). Screw bracket into ashtray frame. While you have it all apart, polish the wood surfaces.
    Finish with storage bin (in place of ash tray) and USB power port (in place of lighter).
    Frankie
    Texas, USA
    frankies-bmw.com
    CT
    E38
    Quote Originally Posted by Frankie View Post
    Did you notice wind noise decrease with the new seal? Mine is actually gone, and my car seems a bit windy at speed.
    E38 M Sport 6 Speed MANUAL
    Vincentown, NJ
    Thank you sir.
    I'll have to finish what I'm doing to the two short wheelbase cars, then it's going to be time to tackle that.
    And, I recently replaced the upper windshield trim as well. I did it without replacing the glass - but getting the new seal STARTED was a pain. Once you manage to start it - in the centre worked best for me - the rest is easy. On the second one, because I mangled the first one trying to get it in.
    Cetaphil and heat gun non-negotiable.
    CT
    E38
    Did you detect noticeably less wind noise after that?
    Vincentown, NJ
    If you're asking me, TBH... not really. The existing gasket was sun-damaged but not awful, so it was more a matter of it looking bad.
    Is there less wind noise? Perhaps a bit. But not enough that I'd go through the exercise for that purpose.
    Feb 2015
    Phoenix, AZ
    1997 740iL (5/96 build)
    I understand that the windshield noise is mostly related to the positioning of the windshield during installation. There is a very precise procedure for installation.
    A test that I have used is to tape both my windshield and sunroof and then drive the car and then peel off one at a time to observe the contribution to air noise each is making. In my case, both are making a huge contribution to that noise.
    I am doing a muffler delete to solve that problem... lol
    1997 740iL; 5/96 build. Purchased 12/04. Off the road build project 2013 - 2021. back on road 3/2021. Became daily driver (only vehicle) 6/12/2021. Still not completed. Stay tuned as the adventure continues.
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by cyclops2 View Post
    Lol! Should have done that instead of replacing all these seals!
  1. Anyone with long term experience with Karlyn suspension parts
    By aythatblackguy in forum 1995 - 2001 (E38)
    Last Post: 07-30-2013, 04:17 PM
  2. Have a 633csi Long term project....need help locating parts!
    By UniqueBlack633 in forum 1976 - 1989 (E24)
    Last Post: 11-13-2006, 11:19 PM
  3. Long term health of a M3
    By norman in forum 1992 - 1999 M3 (E36)
    Last Post: 01-17-2003, 02:06 PM
  4. Long Term Wrap Up: Carbotech Panther Plus Brakes
    By Kevlar in forum 1992 - 1999 M3 (E36)
    Last Post: 07-28-2002, 12:34 AM
