N62 2008 BMW750i I have changed the coils and plugs checked injector spark to plugs fuel pressure all is good
but still misfires when driving rpm goes over 1500 to 2500 after that its okay if i slowly and gradually accelarate
no issues its fine no misfire what else could it be don't want to think about eccentric shaft big money there any
other suggestions or advice thanks in advance.
Welcome to the Forum!
You must be using something to read the codes, what is it and please type the exact info from the code. Also are there any other codes? When you say "Changed Coil and plugs" was this with brand new items, or just moved from 1 bank to the other?
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
Took the car to dealer came out there is problem with eccentric shaft on bank 2
i was just wondering could it be the sensor there or anything else i can check just to diganoise
this they replace two coils and plugs and 3.5 hours labour cost me 1300$ just wondering its 750i n62 2008 with 200000 km on is it worth repairing it there cost is 3500$ any help or suggection
would be great if there is easy way of fix.
I have a 2007 750Li, 145k miles and experiencing the exact same problem. SO frustrating, wish I could figure this out; tired of changing coils and injectors only for the problem to come back 300 miles later. Had the DME tested and updated; that cost $$$. Eff, why are these cars all experiencing the same problem but no one has a definitive answer to the root cause?
