Results 1 to 16 of 16
Thread: 2001 325i oil leak... help...
    Dec 2017
    Arizona
    2001 325i
    Hey guys, so I have a 2001 325i E46 (obviously) but Iíve had this oil leak for about 3 weeks since I bought it and canít figure it out at all.
    Iíve replaced the OFH gasket and oil pan gasket and yet it still leaks... a lot. Basically a puddle. I can get my hand around the ccv and hoses and they feel dry. I have not driven it for a week now and still see a little dripping. I can see itís coming right above the rack and dripping down the pan onto the floor. Any ideas or suggestions at this point?
    Jan 2016
    Ca
    2001 525it
    What about power steering hoses
    Dec 2017
    Arizona
    2001 325i
    No. Itís oil. ATF is a different color and in my opinion that would be an easier one to track down.
    Apr 2009
    Vancouver Isl, BC, Canada
    2007 335i
    Burnt/old atf can look like engine oil. Dont rule it out based on color alone.
    You need to get underneath the car and follow the wetness. Its impossible for us to tell you whats leaking.
    Current:
    - 07 328CI
    - 07 335i
    - 98 M3 Eurospec
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Check the ps reservoir. Just because.
    Dec 2017
    Arizona
    2001 325i
    I have brand new synthetic oil in it. Iím sure Iíd be able to tell the difference between that and ATF.
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    The original ATF used in the ZF and GM transmissions is not red, nor does it smell like ATF. But if you say its engine oil, then I don't doubt it. Can you see what area its dripping from (front, middle, back of engine?)
    Dec 2017
    Arizona
    2001 325i
    Basically middle of oil pan to the floor. I can see it leaking onto the front of the oil pan down then to the floor. Thing is Iíve already replaced the OFHG and not sure how often the housing actually cracks. I want to say itís coming from somewhere above the middle of the motor considering itís dripping on to the rack.
    Aug 2014
    Lawrence Kansas
    Check to see if its leaking from the intake vanos oil line or copper seals.
    Chicago, IL
    2001 330i and 2005 330i
    Also check the valve cover gasket. If you did not replace the grommets, you can get a leak even with a new gasket.
    Did you do the oil pan gasket? That's a hideous job (ask me how I know). Those bolts take almost no torque at all. I had to buy yet another wrench just for the low torque values. For the motor to drip onto the floor, you have a serious problem. Get under the car and look. Looking is free.
    Johnny Murray
    California
    325e 535i M5 325iT 330i
    "Looking is free." ROFL (under the car). Always remember that gravity is your friend. Put some newspaper or better yet, butcher paper, under the car. See the puddle. Look straight up. Trace it up to the leak. I'd wager it's the oil filter housing. Ask me how I know - I own more than one of these bloody cars.
    Mar 2017
    Norwich, Connecticut.
    E46,MB,Volvo,Audi,MG..
    It is very hard to make eye's on a source of leakage of oil for the 'inline' as we know.....Usual are for the 'inline' are "oil filter housing gasket" the twin-cam..valve cover...they are reported to LEAK oil......
    Dec 2013
    Chicagoland area
    EXOTICS
    Quote Originally Posted by dhurley34 View Post
    It's been posted once, I'll repeat it as the most probable cause, unless the OFHG was damaged or incorrectly installed.
    "It's not how you race your car, it's how you stand by your car, you better learn that".
    Edited version-F&F
    May 2017
    Maple Valley
    2001 BMW 325i
    I have a '01 325i and replaced the OFHG several months ago, but it still leaks. Get under the car, wipe every clean and use cardboard or something to catch the oil. Next day, check it and trace the leak. Most likely valve cover or OFHG. I know many E46 owners and they ALL say it's one / two of the most common leaks. Go luck!
    Aug 2013
    SÝborg, Denmark
    2001 E46 325ti Compact
    Cracked valvecover? Itís seen before and pretty hard to see if youíre not looking specifically for it....
    Mar 2017
    The most common oil leak issues I have researched for the 2.5 almost always involve the 'oil filter housing gasket'...almost always! It is the most common...Mine leaks, I add a cup of oil about every 2nd tank of fuel usage..700+ miles or so......I'm lazy...it is on my list for things to do coming spring...
  1. e30 325i 88' oil leak help
    By HappyE30 in forum 1983 - 1991 (E30)
    Last Post: 01-19-2016, 09:31 PM
  2. 1990 BMW 325is Oil leak help
    By Frederick325is in forum 1983 - 1991 (E30)
    Last Post: 09-06-2015, 03:45 PM
  3. 93 325i oil leak!!! need help!!!
    By tmnoonan in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-26-2005, 12:40 PM
  4. oil leak help
    By zombiebaby in forum 1983 - 1991 (E30)
    Last Post: 04-20-2004, 11:26 AM
  5. Oil leak...help
    By Ralbo147 in forum General BMW sponsored by Intercity Lines
    Last Post: 01-02-2004, 01:45 PM
