Results 1 to 12 of 12
Thread: Noisy timing belt tensioner
    Apr 2017
    Sc
    1987 325e, 1989 325i
    Ok, I have now replaced timing belts on two different cars and both of them have noisy tensioner bearings. One is conti, other is gates. The belts and accessories (alt, ac, ps) are all quiet and smooth and I verified the source of the noise with a stethoscope.
    do I just have really bad luck? Anyone else?
    Jun 2014
    Biloxi
    1987 bmw 325e coupe
    Had this happen not too long ago. I noticed a weird rattle at a certain rpm. Finally figured out it was the tensioner. Pulled it out and the bearing was shot. This was about a year and a half after putting it in. They can fail prematurely.
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    What's your method for setting the tension?
    I do this
    1. Install everything leaving the tensioner free to rotate. I replace the spring itself when I do the water pump.
    2. Rotate the engine clockwise to tension the top side.
    3. Snug the set bolts on the tensioner
    "Howdy, Folks!"
    May 2010
    Officially in Tampa
    87 Cabrio & 87 ETA
    When you change the water pump and not the belt you can lose the spring altogether. What's the point of replacing it when the tensioner stays locked until the next belt change ?
    87 Zinno Cabrio 98k Barn Find. Build thread http://www.r3vlimited.com/board/showthread.php?t=268987
    87 Lachsilber ETA Time Capsule. bought w 125k from 87yo original owner
    Cabrio deck lid & hinge struts (w sleeves) now for sale. See the link below for more info
    New "made in Europe" seat shocks. PM for details
    http://www.bimmerforums.com/forum/sh...ot-Seat-Shocks
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    If all you do is the water pump, it's not needed. I follow the practice of water pump every other belt change, so I always do them together. As the spring sets the initial tension, you want it pretty accurate. It's a cheap part, so I do it for peace of mind that the tension is accurate.
    "Howdy, Folks!"
    Apr 2017
    Sc
    Thanks for the input Richard. I’ve decided to just go back in there and redo the tensioner install like you suggest.
    i will say, I pulled the belt TIGHT between the Cam and oil pump sprockets, got that extra tooth in the belt. I wonder if I made it too tight. Probably not, but I’m opening her back up. The squeal is loud like a big supercharger sitting on top of the engine.
    1987 325e, coupe, 5speed
    1989 325i, sedan, 5speed
    Jul 2004
    Sid Knee
    325is, 96 M3 Euro
    excessive belt tension makes it sound like a supercharger, that is your problem.
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    Once you have it on, rotating the belt and allowing the spring to set the tensions makes sure everything has settled in place. You want to do 2 full rotations of the engine back to TDC and double check that the gears are on the marks.
    "Howdy, Folks!"
    Apr 2017
    Sc
    You think I should get a new belt since I stretched the current one too tight by 1 tooth?
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    It's good practice to replace the belt any time you release the tensioner.
    "Howdy, Folks!"
    Apr 2017
    Sc
    Thanks. Thanks for the clear suggestions and procedure.
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    You're welcome.
    "Howdy, Folks!"
  1. timing belt tensioner spring?
    By swelleriffic in forum 1983 - 1991 (E30)
    Last Post: 12-19-2007, 11:45 PM
  2. Timing Belt Tensioner - When to change?
    By E304ME in forum 1983 - 1991 (E30)
    Last Post: 09-30-2007, 12:01 AM
  3. How to adjust Timing belt tension on 88 325ix
    By Slow325i in forum 1983 - 1991 (E30)
    Last Post: 07-22-2006, 07:41 PM
  4. E21 323i timing belt tension adjustment
    By red78E21 in forum 1975 - 1983 (E21)
    Last Post: 11-04-2005, 10:52 AM
  5. Timing belt tensioner is the cause of my tapping engine noise but..
    By gota525i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-21-2005, 11:16 PM
