Results 1 to 7 of 7
Thread: Turbo size for 450-500whp M52
    Jan 2017
    Maryland
    E36
    What turbo is everyone running to get around 500whp that is not super laggy?
    Looking to get some recommendations on what size turbo for a m52 2.8L to make around 450-500whp. I have done some research on the forums, but I can not find an exact answer. Im running a t3 top mount manifold for now. Not worried about hood clearance issues.
    Thanks in advance!
    Frederick, MD
    '87 e30, '02 e39 Dinan
    Quote Originally Posted by lreeve06 View Post
    Thanks in advance!
    https://www.extremepsi.com/store/pro...at=1773&page=1
    with the small ar housing.
    Capital Driving Club Car # 102
    How to turbo your car:
    Step one. Install ecu and learn to tune and or have it tuned.
    Step two. Install injectors and retune.
    Step three. Install turbo parts and bits. get it running with out leaks. DO NOT DRIVE IT. Idling should be ok
    Step four. Retune car
    Step five enjoy
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I’d go for more like a 58-62mm impeller turbo and not one with a big turbine wheel like some BW, and not one with a big back housing — stock with something like a 0.63 or 0.82. I have not shopped anything smaller than a GT35R so I can’t recommend one but you can make a list from Precision, Garrett and BW of ones that are in your budget.
    Mar 2013
    Upstate NY
    M3
    I made 510whp on an s52 with the s257sxe from borg. 19psi @ 3600. Maybe coupled with a smaller back housing (mine was as big as it could get because 3.2) gl.
    Oct 2015
    San Rafael, California
    1996 bmw 328is turbo
    I'd recommend something with at least a 62mm wheel
    Jan 2017
    Maryland
    E36
    Thanks for the help! Im going to look around and hopefully order something in the next few days. Also if anyone has any recommendations on OBD2 tuning that would be great. I have seen a bunch of stuff on the forums about RK tunes, TRM, and a few other companies, but they were older. At this point I am leaning towards going with RK Tunes.
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    Quote Originally Posted by Mklock View Post
    That's what I'd go with. Can't beat the price and performance.
    If you're stuck on Garrett, I'd give a look at a GTX3576R, but it'll also have room to grow since the compressor can push way more than 500 rwhp if you lean on it. I wouldn't get a 62 mm+ inducer compressor for just 500 rwhp, that's crazy talk with modern compressor wheel technology.
  1. Traction prerequisite for 450-500whp?
    By raoke in forum Forced Induction
    Last Post: 08-03-2008, 12:14 AM
  2. What Turbo Size For M10
    By vintageholden in forum Forced Induction
    Last Post: 12-10-2006, 11:53 PM
  3. which turbo size for M42 engine?
    By I'masmackyou in forum Forced Induction
    Last Post: 05-11-2005, 06:24 PM
  4. Turbo size for 3.5 m30 motor
    By E9cslmadness in forum Forced Induction
    Last Post: 10-03-2004, 06:16 PM
  5. Turbo size for M3 S50
    By maurim3 in forum Forced Induction
    Last Post: 08-10-2004, 08:20 AM
