Results 1 to 3 of 3
Thread: Overheating? Or bad gauge?
    Dec 2017
    New Jersey
    1986 bmw 325es
    So since it just got cold out i decided to let my car idle a bit before i leave in the morning. I got started it up let it idle for about 5 minutes and just as the needle got passed the blue the gauge slowly but visibly moved from the blue to passed the red in about a minute and a half. I dont Know if my thermostat is stuck closed and the car is overheating or the gauge is bad because i just had the cluster out to do odometer gears. If anyone knows what’s happening let me know
    Sep 2016
    Belgrade
    Quote Originally Posted by Gloenser View Post
    When you notice this problem, first check engine temperature with some hand thermometer. If temperature fine, then check cluster and temperature gauge.
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    Assuming an otherwise good cooling system, a car that overheats at idle or sitting in traffic has a bad fan clutch. Use the newspaper test to check the fan clutch. Did you drive the car afterward? If so, did the temperature stay normal?
    "Howdy, Folks!"
  1. wanted. GAUGE cluster/s. good or bad
    By T77911S in forum E30 Parts Classifieds
    Last Post: 06-28-2010, 11:19 AM
  2. OR Poll: New Oregon Cell phone law: good thing or bad thing?
    By drsides in forum Pacific Northwest - US
    Last Post: 01-06-2010, 12:17 PM
  3. Bad Gauge or Bad sensor ??
    By Louiseven in forum 1988 - 1996 (E34)
    Last Post: 02-28-2008, 04:17 PM
  4. Used Chip good or bad idea ??
    By Austin in forum 1991 - 1999 (E36)
    Last Post: 06-19-2001, 10:03 PM
  5. Are Mozart exhausts good or bad?
    By Preppy in forum 1991 - 1999 (E36)
    Last Post: 05-10-2001, 11:11 PM
