Decided to put the M3 up for sale.
Details:
WBSBG9339XEY83875
-1999 BMW M3 Coupe sport package
-Titanium Silver over black leather interior
-125,xxx miles (will go up slightly as I drive it on occasion)
-Clean title; all vin stickers accounted for and original
-Lightly and tastefully modified
-Carfax Available upon request
Maintenance that I have done since I've purchased in 11/2016
-Cooling system overhaul (all known items to fail replaced- waterpump, radiator, hoses etc.)
-Drilled oil pump nut installed with safety wire along with a new oil pan gasket
-valve cover gasket and tube seals
-B2 oxygen sensor
-Oil changes done using BMW twin power turbo 5w30 synthetic
-New BMW A/C belt idle pulley
-Fixed the inop drivers seat recline by installing a new gear
-Fixed the sagging headliner by installing an alcantara foamed backed headliner material
-Alignments done every 3 months
*All receipts and printouts are available for the above listed items
Mods that I have done since I purchased in 11/2016
-Stromung catback exhaust
-APEX ARC-8 17x9+30 square setup
-245/40/17 Yokohoma ADVAN SPORT V105 tires (probably have 2k miles on them; all measured at 9/32")
-CAE shifter
-ABRAHAMS LTW wing
*I have some receipts for the above listed items
Mods that came with the car when I purchase in 11/2016
-TC KLINE racing SA coilovers
-VORSHLAG camber plates
-VORSHLAG Rear shock mounts
-UUC DSSR
-BMW E36 convertible X-brace
-Polyurethane RTAB bushings
-DEPO glass headlights with retrofitted universal HID kit and DRL.
-KENWOOD Head unit with bluetooth output and USB inputs (I hate aftermarket head units, but this one is actually kind of nice and matches the BMW AMBER interior lighting nicely)
*All paperwork along with a thorough maintenance journal from the previous owner is available. Routine maintenance was performed either by BMW or a reputable service repair shop.
Car shows extremely well. It is a good example of a very well kept drivers car. Given its 19 years on this planet, it is by no means perfect - usual rock chips on the front bumper and fascia, some blemishes on the body that really can only be seen or noticed if pointed out. The interior shows VERY well and is probably one of the best parts of the car as whole. Minimal bolster and leather wear on the drivers VADER seat. The passengers seat shows as a 9/10. Rear seats are near mint. Interior is very clean and has been meticulously cared for. It smells as an older BMW should *that leathery BMW smell that only BMW's get with time. The leather has been cleaned and conditioned regularly. Carpet is free of stains. If anything, the floor mats could be replaced; but it is not necessary. The glove box has the infamous sag... but I've learned to live with it. Door panels and everything else is free of blemishes or marks.
I've done what I feel was needed to bring the car up to snuff. The car needs nothing, and hasn't skipped a beat since I've owned it. Drives smoothly and pulls hard. The CAE shifter really enhances the driving experience and makes it very rewarding on spirited drives. PPi's are welcome, and if you're in the DC/MD/VA, I am able to put the car on a lift at my shop for any inspections wanted by any potential buyers. OEM BMW M contours in the 7.5+41 and 8.5+41 sizes will come with the car (rear tires are shot). OEM ZHP shift knob, boot and shifter insulator will come with the car. Should a factory shift assembly be desired, a new carrier and stalk will be needed to be purchased (old one was shot so it went in the garbage).
Bump. Flexible on removing part(s) to adjust price. Picture of the car equipped with LTW wing no risers for a less riced out look.
top
Decided not to sell. lock thread.
