Results 1 to 13 of 13
Thread: E46 325i to 3.0, Automatic, Worth It?
    Nov 2013
    United States
    2042 Flying Saucer
    Hi,
    As mentioned in another thread, the motor in my 03 325i is blown. I've dreamed of having the 330i since I bought the car. I figure since I'm already halfway through getting the old engine out, and have to buy an engine and do all of this work anyway, it could be a chance to upgrade. I can get the 2.5 motor from a local glorified junkyard for around $900 and the 3.0 for a few bucks more. My question is, it being an automatic, would it even be worth putting the bigger motor in, or will the transmission hold back the power, making it pointless?
    Also, I understand that this is easier if I get the DME flashed, as opposed to swapping out computer parts, since then I would have to get new keys, etc. Can anyone recommend a good place to get it flashed in the Tampa Bay area, or a place online, I can mail it in and have it sent back?
    Any other advice? Things I'm missing?
    Is this whole thing a dumb idea?
    Thanks.
    Jul 2004
    Houston, TX
    36 Cylinders
    Not a dumb idea. It will work fine if you do it correctly. You MUST use the 330i injectors, MAF, intake manifold and throttle body.
    I can flash the DME to 330 specifications, either on my desk, or remotely if you have a windows laptop with wifi connected to internet and a cheap INPA K+DCAN cable.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Nov 2013
    United States
    2042 Flying Saucer
    Jul 2004
    Houston, TX
    36 Cylinders
    Yes, looks like they're receiving the reliable green board ones.
    -Abel
    Nov 2013
    United States
    2042 Flying Saucer
    Ok, I will order it. I will PM you sometime about getting the flash done.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    More power is always good. I’d do it. Probably get rid of the auto as well.
    Nov 2013
    United States
    2042 Flying Saucer
    I'd like to, but the wife and I share the car, and she wouldn't be down. I'll one day give this car back to her and get and get a manual for myself. I miss driving manual.
    Nov 2013
    United States
    2042 Flying Saucer
    Erg, I can't get the driveshaft out. I see some people leave it attached in the rear and move it to the side, but I can't get it to come back for enough. I unscrewed the three bolts by the transmission but can't get it to slide out of the coupler. Whatever post is in the center of the coupler is keeping me from moving it aside. I was having trouble getting it undone in the rear, so was hoping to leave it attached there.
    Jun 2005
    New England
    I think there are 6 bolts at the trans end and it may give you more play if you undo all so the guibo can flip around or even be wiggled out. You also should undo the center support bearing. That increase play also. Then tie it up to the side so it is not overly stressing the rear CV or u joint. If you decide to pull the front section of shaft off, mark the sections first since they are balanced. Original there were 2 white dots marking the 2 sections.
    Nov 2013
    United States
    2042 Flying Saucer
    Got it, taking out the other three bolts, it was still a bit of a fight, but I got the wiggle room I needed. Thanks for the tips.
    Nov 2013
    United States
    2042 Flying Saucer
    This is what happens when your six year old finds your new engine picker.
    Nov 2013
    United States
    2042 Flying Saucer
    Is the DISA valve assembly the same on these two engines? The one that came in the engine I picked up looks to be on its last legs so I'd rather use the one from my 2.5, if possible.
    Jul 2004
    Houston, TX
    36 Cylinders
    Not the same. The 3.0 is larger.
    -Abel
  1. 325is to Euro m3 conversion, worth it?
    By Thames in forum 1991 - 1999 (E36)
    Last Post: 10-09-2010, 04:40 PM
  2. 1993 BMW 325is m3 kit $4.5k worth it?
    By TopLevel in forum 1991 - 1999 (E36)
    Last Post: 02-13-2006, 12:41 AM
  3. '96 to a '99 m3... worth it?
    By M3boarder in forum 1992 - 1999 M3 (E36)
    Last Post: 08-09-2005, 10:43 PM
  4. OBD-II to OBD-I swap worth it?
    By LUIS in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-26-2002, 02:23 AM
  5. OBD-II to OBD-I swap worth it?
    By LUIS in forum Forced Induction
    Last Post: 04-24-2002, 04:18 PM
