Results 1 to 5 of 5
Thread: Brake wear light
    Oct 2017
    Bartlesville Oklahoma
    1998 e36 1982 e21
    Brake wear light
    On my 1982 e21 I get an intermittent brake wear light that will come on and stay on. Then the next time I drive the car it will come on again after driving for a while. I replaced the wear sensor but still get the same results. Any help I would appreciate it. Thanks
    Feb 2016
    Sacramento, CA
    1979 E21 320i
    Check to see if you have a sticky brake fluid level sensor, or borderline low fluid?
    -John
    Oct 2017
    1998 e36 1982 e21
    Thanks John I will check this out when I get home.
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    The E-brake switch can do the same thing and is connected to the brake light like the fluid cap switch-Either can flicker the brake indicator light. The Brake Pad Wear Sensor Light is not connected to the brake light its connected to the circle of pie pieces or White Hash Marks-Red Plastic with White Light bulb in back of instrument cluster,,this system runs on a negative feed back loop and this is how its turned off. Once the key is on and all the indicator lights come on, the car starts and the brake pad wear sensor light goes off, like the alternator light. Check for wire break by continuity test.
    Your All Welcome
    Randy
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    e21 Wiring.JPGClick on the picture to enlarge, open in a new window/tab and enlarge.
  1. Brake wear light and ABS light on
    By circuiticon in forum 1991 - 1999 (E36)
    Last Post: 02-07-2022, 04:48 PM
  2. brake wear light
    By setho in forum 1992 - 1999 M3 (E36)
    Last Post: 11-02-2011, 12:36 AM
  3. brake wear light reset
    By robdanbreambsha in forum 1991 - 1999 (E36)
    Last Post: 08-04-2006, 08:59 PM
  4. brake wear light
    By Bones774 in forum 1991 - 1999 (E36)
    Last Post: 05-21-2003, 08:39 AM
  5. Brake wear warning light
    By knudsonm in forum 1991 - 1999 (E36)
    Last Post: 04-04-2003, 01:22 PM
