Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
Thread: EWS Signal??
  1. #26
    birmingham,al
    2001 3.0 Z-3 RD'STER
    Quote Originally Posted by Mr Bingley View Post
    When did you change the fob battery?
    3 days ago
    How do you figure this?
    The only sure fire way is to read key signal in diagnostics of EWS module itself. It still can be many other things.
    You wouldn't happen to own a Windows laptop and somewhat OK at computers?
    sorry but don't own a laptop....guess I will be taking it to a tech next week.
  2. #27
    Jul 2004
    Houston, TX
    36 Cylinders
    Let me know if you need any help with anything. I can clone EWS modules into used ones (if yours had an internal problem), thereby retaining starting and keys matched. Or more advanced stuff with the DME, etc.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  3. #28
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    On EWS3d? You've been busy.
  4. #29
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by rf900rkw View Post
    Yea, there are some simple tricks to read into their data:
    -Abel
  5. #30
    birmingham,al
  6. #31
    Jul 2004
    Houston, TX
    36 Cylinders
    Can't be sure until proper diagnostics. No way I would start throwing parts at it.
    Some EWS3 modules had a chip that overheated and eventually fails.. but it's still not the first thing I would blame.
    It may not even be the EWS module at all.
    You have EWS3 by the way, which gets much more complicated than EWS2 and earlier.
    -Abel
  7. #32
    Dec 2007
    Great Dismal Swamp
    NO! It does not apply to your car at all.
    /.randy
  8. #33
    Kent, Ohio
    1998 M Roadster
    Quote Originally Posted by MORRIE View Post
    3 days ago
    When did the start issue occur?
  9. #34
    birmingham,al
    I went to a BMW tech that has worked on my car before (not a dealer) and told him about my problem. He said the Electronic Immobilizer chip embedded in the key is probably not working or there is a problem with the ignition switch in the steering column. We both agreed that a new key would be the place to start. Although a pricey item (stickily a dealer item $247) it could save me from paying more $ for unnecessary parts and labor cost to deal with the ignition switch. I have been procrastinating about replacing my existing key (soft buttons and very worn) It sometimes works and sometimes it doesn't when locking/unlocking the door. I am thinking the chip has been damaged and is preventing a signal to be sent to the DME. Without this signal, the engine will not start. So, next week, off to the BMW dealer. I'll post the results on this thread. I hope it will be positive.
    I believe it started when I replaced the battery in the key. I could have accidentally damaged the chip inside the key FOB.
  10. #35
    Dec 2007
    Great Dismal Swamp
    After market key? You may have moved, or lost, the chip. Try tapping the key blade down on a table. You want to move the chip towards the blade end. I have on key that does that.
  11. #36
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    Could you have put the battery in backwards?
    2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
    2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
    2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
  12. #37
    Dec 2007
    Great Dismal Swamp
    That would not effect starting. The fob is only for the alarm and locks. EWS/starting is an entirely unrelated system.
  13. #38
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    A new key is not that expensive. I paid around $68 from the dealer. I think you've found the real problem
  14. #39
    Kent, Ohio
    1998 M Roadster
    So, if I understand it, the fob you changed the battery in is in fact the key handle in your picture, and the problem with the ews occurred simultaneous with changing the battery. Before buying a new key, try removing the battery you put in the handle and visually locating the transponder and confirming its location. It will look like this (photo sourced from Google images search):
    The transponder could have become dislodged when you swapped batteries, especially if yours is an aftermarket key (as it was moved once before). If it's not there, it may still be on the table or on the carpet around where you did the battery swap and you can find and reinsert it.
  15. #40
    birmingham,al
    I think the transponder fell out of the key when I put in the new battery, because it is not there now. Looks like I may have caused my own problem :-(
  16. #41
    Kent, Ohio
    1998 M Roadster
    That means all you have to do is find it and your problem is solved. It still exists and must be somewhere-don't give up.
  17. #42
    birmingham,al
    Thanks Ralph for the encouragement, but I went to dealer today and ordered a new key FOB....been meaning to do that for a long while. I did find that my particular key FOB can be ordered in separate parts...the removable tab that allows access to the 2 screws, the back side of the key FOB that allows access to the battery, and of course the electronic part. Also, BMW will only replace a key FOB exactly like the one that comes with the car. I was hoping for one with hard buttons...guess I will have accept what I have. So assuming the new key FOB resolves my problem, I will have a back-up key that will lock & unlock the car.... and that is a good thing.
  18. #43
    birmingham,al
    Picked up key from Dealer today....initialized the key so memory functions can be activated. Doors lock and unlock and engine starts. Yep, I am a happy driver again.
    Thanks to everyone for your comments/help.
  19. #44
    Jun 2016
    Odessa, TX
    2000 BMW Z3 2.8 Roadster
  1. Code 12 "EWS Signal" - Please help!
    By alexio senchez in forum 1996 - 2003 (E39)
    Last Post: 05-11-2009, 08:07 AM
  2. e36 - EWS Signal
    By masonohbmw in forum 1991 - 1999 (E36)
    Last Post: 12-19-2008, 03:33 PM
  3. EWS Signal...
    By duce110 in forum 1991 - 1999 (E36)
    Last Post: 04-14-2008, 12:55 PM
  4. O2 Sensor Adaptation Limit and EWS signal
    By mcw323is in forum 1991 - 1999 (E36)
    Last Post: 06-12-2007, 06:33 PM
  5. EWS Signal
    By uncle in forum 1991 - 1999 (E36)
    Last Post: 06-20-2006, 11:17 AM
