After the snow the other day, I turned on the ignition switch but nothing happened...no sound at all. I tried to jump start it, but still nothing. All the lights work and the volt meter shows good power from the battery. The CEL was on, so I took a reading with my peake diagnostic tool. It read 19 80. Page 19 selection 80 shows EWS Signal. I haven't a clue what this indicates. Since the lights are working and gauges are working, my guess is the starter. Before I plunk down the $$ for a starter, I thought I would run this by you guys. Anyone know what is causing my problem? Thanks in advance for the help.
Did you search first? EWS is a very common issue on these cars and the diagnostic process for establishing what went wrong is well reported. EWS is a system in the car relating to how the key communicates with the car... when the EWS is not syncing or operating properly, the car will not start. Nothing you mentioned suggest a starter is the problem. I'd run a quick search, or even search the peake code you have and your model, and read through some threads. You'll at least know where the problem is
PRICE CUT on ALL FABRICS
This is where you may need more than Peake. It simply does not give you enough data.
EWS is the vehicle immobilizer. But this may be an old code, or something new. It may even come up from low voltage. Hard to tell with Peake.
You may need a tool to read the EWS module errors, or see if it's even working.
I would make sure you have really good power to vehicle first.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
Internal volt meter may not be a good measure of what is going on.
How old is the battery?
When this happened to me, it was a fuse.
Wayne
1998 M Roadster
1994 Honda ST1100--sold
2017 Yamaha FJR1300ES
While checking fuses is always a good step, the M54 6cyl and S52 M are very different electrical systems with totally different EWS.
/.randy
• Built S52 w/Dinan ISR-3 kit, NickG Stage 2+ Tune, Dinan Vortech V2 Supercharger, Dinan Air to Air Intercooler, Dinan CAI, Porsche 803 HFM, Buldogge 6" crank pulley, Griptec 2.90" blower pulley, Eurosport UD pulleys, Dinan 3.38 Diff, Dinan front/rear Swaybars, Dinan springs, Koni Yellow Sport Struts, Ground Control end links, South Bend Clutch Stage 3 Organic, AASCO Light Weight Flywheel 18.5#, Zionsville Radiator & Oil Cooler, Riot Racing BBTB, Schrick Intake Manifold, 42# Injectors, Schrick cams 264/256, Forged Wiseco pistons 9.0 comp., Forged Eagle rods, Supertech dual valve springs & valves, VAC crank & bearings, Supersprint mufflers, Euro Z3 midpipe, Raceland euro headers, Walbro 255, Bevauto ignition coils, Vortech Mondo bypass, Bailey Diverter DV30, Ireland Rear Subframe Bushings, Mason Engineering Strut Brace, Mason Engineering Clutch Petal, Apex 18" EC-7 Wheels, Full Custom Sound System, two trunk lids (with & without OE spoiler), Hardtop, Trunk full of AK's...
So where is the fuse located?
31,45
-Abel
Yes and also the immobilizer
oops....didn't see that one. Thanks for the info....will check those 2 fuses tomorrow...hope that's the problem.
Checked both fuses....good. Engine still won't turn over. Taking battery to be checked. If battery is supplying enough voltage so that the lights, radio, clock still works fine, I think it could be the starter. Any thoughts??
If you still have EWS codes, it's likely not the starter.
EWS module itself controls starter relay. EWS needs power and a matched key to allow starter to spin.
(Then if starter spins and car won't fire, then the DME to EWS link is lost.. part 2 of vehicle immobilization)
-Abel
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
Before I have the car towed to the technician, is there anything I can do to resolve issue?.
I removed battery and took it to place of purchase where they charged it (12.57 volts) I installed it and still the engine does not turn over....just dead silence. All accessories still work.
Do you have a second key you can try? Has anyone been fooling around in the area of the column and ignition (where the key inserts)? Any recent messing about under the dash on the driver's side? Did anything happen to your key recently? Is your car an automatic, and if so, is it squarely in park? If not, are you fully stepping on the clutch?
No 2nd key...no messing around with column/ignition or under dash. I replaced the battery in the key FOB. Sometimes it unlocks/locks the car and have to manually unlock/lock... planning on getting a new one from dealer. Car isn't automatic and yes depressing clutch to floor.
Apparently, my car doesn't recognize the key and refuses to start the engine. I be damned if I know how this happened.
When did you change the fob battery?
-Abel
