Results 1 to 11 of 11
Thread: E36 unsafe after alignment
    Dec 2017
    Ohio
    96 BMW 328iC
    My rear end keeps wanting to slide out to the left when the road isn't dry. I had it done 2 months ago. They told me that they couldn't get the bolt off the right rear trailing arm. What should I do?
    Front:
    camber -1.5° on left -1.8° on right
    caster 3.6° on left 3.2° on right
    toe 0.13 on left 0.12 on right
    Rear:
    camber -1.1° on left -2.0° on right
    toe .53° on left 1.17° on right
    Overall thrust angle is -0.33° degrees (to the left)
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by Jkep91 View Post
    What should I do?
    Find a different shop and get it fixed!!!
    Dec 2013
    Chicagoland area
    EXOTICS
    Visit a competent BMW specialist shop to remove and possibly replace RTABS, along with any other worn suspension pieces.
    Once failed suspension pieces have been replaced ask for a recommendation of a good alignment shop.
    Dec 2017
    Ohio
    96 BMW 328iC
    Quote Originally Posted by MIKYZZ4 View Post
    I was going to get adjustable camber arms and the Fastrax gauge to do it myself. I replaced all the struts, springs and control arms already. If I remember correctly the RTABs were in decent shape. I just need to loosen the bolts and slide the arm over to get the right toe.
    Quote Originally Posted by bluptgm3 View Post
    For sure. Thank you!
    Dec 2017
    Ohio
    96 BMW 328iC
    I do almost all the part replacing myself because I don't trust any mechanic. I was thinking about getting the Fastrax camber/caster gauge. I already replaced all of the struts, springs, and tie rods. Good or bad idea?
    Dec 2013
    Chicagoland area
    EXOTICS
    If you get the gauge and have confidence in your skills-go for it!
    I'd say it's a good idea if you have a basic understanding of suspension geometry.
    Dec 2017
    Ohio
    96 BMW 328iC
    Im very mechanically inclined. I got this! Thanks MIKYZZ4!
    Aug 2013
    1999 BMW M3 Coupe
    I'd still suggest having an alignment shop dial everything in for you. You can get in the ballpark at home, but unless you have a full rack that is perfectly level with fin adjustment you just aren't going to have nearly the same precision as a shop with a professional rack. Plus, a good shop like the one I use will ask you your weight, whether you want it weighted for just the driver or for other passengers/cargo as well, and then align it under those weight conditions.
    That said, you can probably fix the trailing arm issue yourself. Douse it in PB blaster and use some heat if necessary and a lot of torque. It also looks like they couldn't get your left rear camber arm undone because they didn't touch that either. Both rear camber and toe should be equal side-to-side. You should be able to correct that at home and get a rudimentary rear alignment with a DIY tool or a straight edge, and then find a better shop who knows what they're doing.
    Dec 2013
    Chicagoland area
    EXOTICS
    I have more confidence that, he can do a better job, than the shop that couldn't get the bolt off the right rear trailing arm!
    Aug 2013
    1999 BMW M3 Coupe
    This is true, though I would prioritize finding a better shop. Did he take it to a Jiffy-Lube-esque chain or something? At least in my area there's plenty of independent BMW/German shops for general shop work, and for alignments there's plenty of specialty alignment/suspension shops which setup racecars and whatnot. In a pinch, most good tire retailers also usually do an ok job. I've used a Hankook tire near me for my wife's car.
    Oct 2012
    washington, dc
    96 E36 Vert 03 E39 M5
    You can do it!
    Maybe somethings' bent did you hit anything ?
    That rear toe is what's killing you bro. do the RTAB's anyway since you're in there.
    http://www.bmwmregistry.com/detail.php?id=13792
    * E39 M5 SterlingGray -RIP 11/2018
    * E36 328 vert Schwarz - ~TurboProject underway
    * E90 335i Sedan MonocoBlau - Daily ToddlerTaxi
  1. E36 E36 M3 After Market M front Bumper
    By ghambino in forum Exterior Lighting & Body Parts
    Last Post: 06-08-2014, 02:08 AM
  2. E36 rear toe after alignment
    By BrandonRoche in forum 1991 - 1999 (E36)
    Last Post: 09-20-2013, 04:30 PM
  3. Car pulls to the right after alignment (yoko ES100's)
    By Austin in forum 1991 - 1999 (E36)
    Last Post: 03-25-2004, 07:11 PM
  4. Tire Rubbing Issues After Alignment
    By slvrm3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-12-2003, 06:02 PM
  5. Toe in and handling issue after alignment
    By Sonic A in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-19-2003, 02:07 PM
